Trailer for 70lb dog mount to carbon frame thru axle?
Quoted: 426 Post(s)
Liked 274 Times
We adopted a puppy last friday. He is guesstimated to be about 70lbs. I purchased a trailer for him, it arrived today. Assembly went fine. After I filled both tires up one of them popped :/
How do I mount this trailer to my carbon Ibis gravel bike with thru axels. Looks like this trailer was meant quick release.
Is there a way to mount this trailer safely to my bike?
Buy a longer thru axel?
I want to mount some how on the bottom chain stay buy my hydraulic brake line is there. if I move forward past the brake line seems like the trailer is too close to my rear tire.
Is it safe to mount it on thin carbon bar that goes from the seat to the rear wheel? Seems to thin to me for that.
Buy an alloy hybrid bike ?
Buy a different trailer that has a better way to mount to the carbon bike with hydraulic brakes ?
Likes For Atlas Shrugged:
Quoted: 18424 Post(s)
Liked 15,581 Times
I’ll bite…
Is the trailer even rated for 70 lbs.?
And why would you buy a trailer without checking for attachment compatibility?
Likes For indyfabz:
Quoted: 6972 Post(s)
Liked 10,971 Times
I've got no advice on the trailer...But that is a sweet old Datsun in the first photo. Looks like a 260z.
Likes For sean.hwy:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Sweet Z!!! Did Robert Axle have anything?
Likes For cxwrench:
Quoted: 426 Post(s)
Liked 274 Times
Do you guys still spend money on your other hobbies once you started biking? lol My 240z and LS El Camino need some $$ <3 but it's just more fun, less expensive and better for my health when I dump time and $$ into the bikes.
yes, I think I need this one.
https://robertaxleproject.com/produc...mount-trailer/
Quoted: 426 Post(s)
Liked 274 Times
And I really appreciate that sooo much.
I actually did try and do some research but I did not get any response.
https://www.bikeforums.net/utility-c...avel-bike.html
If you want to see a picture of the puppy.
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,444 Times
I got that trailer from Costco when they briefly had it. Much better price. I put a 75 lb Golden Retriever in it, and he flipped the trailer, and the bike (with quick release), and me. Fortunately I realized I needed to cut my losses before I ordered a thru-axle from the Robert Axle Project, which we would have needed for hooking this thing up to an e-bike.
The trailer is rated for that weight, but the reality is that the dog has to be very sessile or it will quickly become a hazard.
Fortunately, Costco was good about taking it back.
Likes For Polaris OBark:
Liked 3,444 Times
MTBR forum has all sorts of dog/rider threads, advice, etc.
Quoted: 426 Post(s)
Liked 274 Times
Looking forward to when he gets a little older and I can take him hiking.
Likes For sean.hwy:
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,445 Times
You need to take some pictures of the 240Z and post them in the 'Beautiful Cars' thread in the 'Foo' forum.
FWIW: There was a business here in town that bought old Japanese cars from the 60s and 70s, fixed them up, then exported them to Japan. The Datsun 'Z' cars were the most sought after, and a 240Z with the carbureted engine (first two years of production IIRC) was worth its weight in gold on the Japanese collector market. Japanese motorcycles were also prized, I believe the Honda 650(?), the original 'big bike' was also a top moneymaker.
Liked 15,581 Times
Quoted: 4236 Post(s)
Liked 2,949 Times
Quoted: 2281 Post(s)
Liked 1,710 Times
My sister-in-law had a trailer like this when her children were younger, and I think it had some kind of special bracket or something which connected to the bike, then you connected the trailer hitch to that. I don't remember for sure, and they sold the trailer years ago so I can't check. Her kids are all riding bikes of their own now.
Quoted: 426 Post(s)
Liked 274 Times
Quoted: 426 Post(s)
Liked 274 Times
Since the axle is so expensive I only want to buy one of them. Should I buy it for Blur MTB bike or the Ibis gravel bike? I can't imaging ever going fast with a trailer even if it was empty and I was not worried about the safety of the dog.
Liked 15,581 Times
The screen shot reads that he is guesstimated to currently be about 70 lbs. Hence my question about the trailer weight rating. "To reach 70 lbs." or something similar would have worked.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
This is going to take a little bit of creativity or custom work. That Robert axle is something I've never seen, but it looks hopeful.
I have two bike trailers. They're both made by Burley. One is from the 1990s, designed for carrying children, and similar to yours (except for the hitch). The other is of more recent manufacture and designed for cargo, with a hitch more similar to what you have. Neither of them would work well with every possible style of axle and brake, but there are always workarounds. I know that isn't really much help.
I'd say you could safely attach the trailer hitch to your chain stay, if you also fabricate an extension to the trailer's arm, to make clearance for the bike wheel. One thing to watch closely before attempting this solution is your heel clearance. Your chain stays are not very long, and anything you attach forward of the axle and brake could interfere with your pedaling.
You could also perhaps attach it to the seat stay, but will have to keep the attachment point as low as possible, so the trailer rides level.
The important thing in either case will be to protect the carbon fiber frame from damage due to chafing or localized pressure/stress. Even a thin structure like the seat stay can take quite a bit of force on it, but could be easily damaged by direct contact with metal parts or by rubbing/scraping. Again, that extended through-axle might be your best bet.
If I were choosing between those two bikes for towing a trailer, I'd probably go with the mountain bike. It likely has geometry that will work better for this purpose, and I suspect will be more comfortable for the type of ride you will do while towing your pup around. It's really up to you, though. Either one could feasibly go well, assuming the axle extension works.
If you're planning on riding steep hills, you should take the bike's gearing into consideration. Towing a ~70 lb. dog plus the weight of the trailer itself is not easy. I have hauled about that much weight behind a few different bikes. It is doable, but it adds a new dimension to the biking experience.
Likes For Broctoon:
Quoted: 426 Post(s)
Liked 274 Times
Quoted: 426 Post(s)
Liked 274 Times
I contacted the vendor. Inner tube on it's way. going to take a few weeks with free shipping.
