Are limit screws JIS instead of Philips?
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
I have a theory. I've often noticed that derailleurs limit screws don't quite... work with Phillips screwdrivers. I've tried #1s and #2s, but they never seem to work right in those limit screws.
So, my theory is that those screws are the JIS heads and not Phillips. Am I right? I mean, Shimano is a Japanese company...
Quoted: 5763 Post(s)
Liked 2,537 Times
Actually most of the "Philips" screws you see in the USA haven't been Philips for years. The last stronghold for Philips was in the electronics trades and other applications calling for nice cosmetics.
Otherwise, most of those screws today are a variant of "Pozidriv". The key difference is that Philips drivers come to a point, and the more modern variations don't. Forming screws with the full depth to accommodate the pointy drivers is more difficult, so they don't bother.
There's an easy fix if you have a bunch of Philips screwdrivers that aren't working for you. Just grind the point back so the driver can settle deeper until it's supported on the blades. This isn't a technically correct conversion to Pozidrive or JIS, but it'll do the job.
FB
Chain-L site
FB
Chain-L site
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
A lot of limit screws will work with a bladed screwdriver as well, which gives you a better grip on the screw in my experience.
I generally abhor flat bladed screwdrivers. I get annoyed when I have to deal with a flat headed screw, especially if it's one that I have to turn a lot. They're remnants of the past, and should only be used when absolutely necessary. But if you say they work better than Phillips, I may have to try it haha.
Interesting. I've noticed that most of my #1 Phillips are sharp, where most of my #2s are blunt.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Ugh. I feel just wrong looking at that picture. I can hear the words in my head "Using the wrong tool for the job will just end up making more work for yourself." Then again, I guess the phillips screwdrivers are also the wrong tool so...
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 1062 Post(s)
Liked 665 Times
Philips (and variants) should not be used for screws that adjust something, because you have to push on the screw to make the adjustment. Much better to use an allen head. I understand not wanting to force everybody to adopt a new tool, but those tiny philips heads on derailers and vee-brakes are a weird throwback, when every other screw on the bike has been modernized.
Quoted: 258 Post(s)
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
Screws like the one in the picture are clearly made to use with either Phillips or bladed screwdrivers. I've never had a problem with a bladed screwdriver slipping or damaging the screw head. I've always found a Phillips to not fit right and honestly didn't know about the JIS standard for this. Learn something new every day here!
The dot in 1 quadrant is an indicator that it is a JIS screw and not a Phillips screw.
Randomhead
Liked 3,686 Times
Shimano used to put their logo on these Jis #2 screwdrivers:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Quoted: 263 Post(s)
Liked 9 Times
Your Theory is Goofy. Its a Metric screw.
Spend Up on a Quality screwdriver , whose tips dont round off and so make a weak connection..
https://www.phillips-screw.com/pozidriv.php
Quoted: 2026 Post(s)
Liked 1,095 Times
Most hardware store flat screwdrivers are ground with a taper and tend to cam-out of the screw slot. Gunsmith screwdrivers are hollow ground and the tips are parallel. They stay put in the screw slot and are far less likely to damage the screw head.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Whether a screw is metric or not has nothing to do with JIS. It has to do wit the shape of the screwdriver tip. The best phillips head screwdriver in the world will likely strip or "Cam out" the head of a JIS screw. Here is why...
Vessel makes outstanding JIS screwdrivers...
700/KIT-P123 | Screwdriver Sets | Screwdrivers | Hand Tools | VESSEL TOOLS
-Tim-
Likes For TimothyH:
Quoted: 140 Post(s)
Liked 162 Times
It's surprising that, AFAIK, Park doesn't make JIS screwdrivers. I've used a JIS screwdriver on Shimano limit screws, and it is clearly an "A" fit on Shimano limit screws, compared to the "B" fit with Phillips screwdrivers.
