V-brakes vs cantilever for touring bikes
Most older touring bikes I've seen have cantilever brakes. What's the logic behind this? Fender clearance?
The reason I ask is that I own a 1992-ish Trek 520. I came equipped with cantis originally but a previous owner converted to v-brakes. I'm going to modernize the bike with a 3x10 drivetrain and I'm wondering if I should go back to cantis. I know I have to switch the levers to short pull but I have those available as well.
Thoughts?
Thoughts?
Quoted: 3454 Post(s)
Liked 1,454 Times
Thoughts?
Thoughts?
V brakes came along later.
If what you have works well, no reason to change it in my opinion. If you have a reason other than it used to have different brakes, you could clarify your thinking.
Likes For Tourist in MSN:
You ask the logic behind canti brakes, they were considered a better brake than side pull or center pull brakes decades ago. I worked in a bike shop in the 70s, almost all brakes were sidepull or centerpull. The first time I ever saw canti brakes, they were on a tandem bike.
I also prefer working on cantis as opposed to V brakes.
There is a whole thread about this same question.
https://www.bikeforums.net/touring/1...s-touring.html
I do have a good reason. I have a set of Gevenalle shifters on my gravel bike. I'm considering converting the gravel bike to hydraulic and moving the shifters over to the Trek. They would not work with the V brakes but would work with canti because they are short pull.
why the need to crowdsource?
just do it.
Likes For saddlesores:
Liked 1,454 Times
But, if you want to use those shifters and short pull brake levers on V brakes, you can. You used to be able to buy Travel Agents, described here:
https://www.parktool.com/blog/repair...and-adjustment
Travel Agents are no longer appearing on the Problem Solvers web page, thus appear to be out of production. But, you can find on Ebay copies of them from asia. Shipping can take a month.
https://www.ebay.com/itm/1pcs-Black-...e/273706014859
I bought one as a spare. Appears to be just as good as the original.
I am using V brakes with Travel Agents on two bikes. You have to avoid getting dirt in them, that can cause more friction. But otherwise they appear to work well for me.
The previous owner probably just changed them because they stop better than cantilevers and they're easier to adjust. But as said, if you have levers you want to use and you prefer cantilevers(Because you're nuts? ), what are you asking about? Change them to what you want. And I say go for the hydraulic disks. I held out for a long time because cable disks work great, but once I got hydraulic disks(Avid Juicy 5), they are superior. The lever feel is fantastic and the stopping power is even better than cable disks. I'd Never recommend them on a touring bike, but they're nice on a bike where you can deal with the maintenance needs.
I have been living with hydraulic disc brakes on one of my bikes for a few years now and one of the things I love about them is that they have been almost completely maintenance free. Pretty much all I have had to do is replace the pads when they wear out. I have been maintaining the mechanical discs on my daughter's ebike and I did have to straighten a bent rotor, but otherwise they have been trouble free and maintenance as well.
I've said this before and I'll say it again. I really don't get it when I read this part about the maintenance. I see it again and again. What maintenance needs? I have found them to need less maintenance than rim brakes which tend to at the very least need pad adjustment tweaked now and then. Not that rim brakes are a big maintenance nightmare or anything, but they do require somewhat frequent attention IME.
Likes For hhk25:
I see catastrophic unfixable failure as one of those things that are possible but really pretty unlikely. On the order of things like a broken frame, but with more ability to limp along or find a work around. Absolute worst case I could see limping along with just a front or just a rear brake until a fix was available. That fix just might be a cable operated disc brake or in an extreme case a rim brake of some type, but I really don't see that happening for me since my touring has all been in the continental US and is unlikely to be in third world countries in the future since I am probably getting less adventurous at my advancing age.
As a result, I see it as an almost complete non issue for me. I guess it may be a different deal for someone else who tours in different settings or in different ways.
BTW:
My previous comments were more about comments that I have often read that seemed to imply that hydraulic brakes required a lot of effort in adjustment, setup, and routine maintenance of which I have seen the need for almost none. I took your comments to be in that category since you referenced "maintenance needs". If you are referring to a problem with fluid leakage that might be difficult to deal with in some countries, I confess that I have no experience either with that problem or with those countries. Still I think I personally would be willing to take my chances. If someone was really worried they might carry some spare parts, but I don't think I'd be that concerned. Just me though, and talk is cheap, especially since I am not heading off into some third world rainforest tomorrow.
Quoted: 5888 Post(s)
Liked 3,471 Times
I recently converted a vintage Trek mountain bike, a 1992 Trek 950, from v brakes to cantilevers. I bought the bike 2d hand. The v brakes that came on the bike were not very good; they were origin 8 brakes. I replaced them with Tektro CR 720, which are probably dollar for dollar the best cantilevers you can buy, and kool stop pads. The brakes work great.
Cantilevers are more fiddly to set up than v brakes which is why a lot of people like them. The Tektro CR 720s are easier than most cantilevers to set up and the price is good on them.
Liked 1,454 Times
Part of the switch from canti brakes to V brakes was that if your brake cable broke and your straddle cable on a canti brake got caught in the tread of the tire (think knobby tires) on a front wheel, a canti brake could cause the wheel to lock up. Not an issue with V brakes. So, part of the switch by manufacturers to switch from canti brakes to V brakes was to reduce lawsuits. I suspect that was part of the reason that Surly switched to V brakes.
If you have fenders, the straddle cable would not catch on a tire, so I never worry about my canti brakes catching on a tire if I snapped a cable.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
V brakes are superior to cantis - better and more linear stopping power, much easier to set up. Also, many bikes with cantis on the front and a headset-mounted cable hanger get terrible fork juddering under hard braking, and Vs do not do this.
The disadvantages, and likely reason why cantis are included on touring bikes, are better clearance for fenders and wider tires (and mud and stones and hay), and compatibility with most road-style brake levers. You can get mini-Vs that work with road levers, but then the clearance for tires and fenders is even tighter. And when set up properly, cantis are generally perfectly acceptable and stop the bike well.
Discs are better than both those. No tire clearance problems possible (maybe rack mounting issues, though), no effect on rims or problems caused by out-of-true rims, less maintenance (practically no maintenance for hydraulic discs), and better stopping in bad weather. Also generally easier to set up.
Mechanical disks are my choice for a touring bike. They're almost as good as hydraulic disks with practically zero maintenance other than an occasional pad adjustment as they wear. I like BB7s.
Quoted: 1324 Post(s)
Liked 927 Times
I also like that V-brakes don't protrude and get in the way of my panniers.
Cheers
