Rear derailleur weirdness
Old 10-27-19, 10:34 AM
dougphoto
Quoted: 130 Post(s)
Liked 24 Times in 12 Posts
all last week when I'd shift it would take a couple taps to get my rear derailleur to shift, then today it stopped shifting completely so I turned around headed home ( I was very sad) spinning at like a million revs per minute to go very slow. Then suddenly about a mile or two from home it started working almost perfectly again. Shimano 105 with about 8000 miles on it.
dougphoto is offline
Old 10-27-19, 10:44 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
I’d guess the cable is fraying and has started binding up somewhere.
dabac is offline
Old 10-27-19, 10:46 AM
Jack Tone
Quoted: 389 Post(s)
Liked 255 Times in 165 Posts
I would turn the bike upside down and spray some WD40 or Triflow into the brifter.
Jack Tone is offline
Likes For Jack Tone:
Old 10-27-19, 10:58 AM
dougphoto
Quoted: 130 Post(s)
wd40 fixes most stuff
Old 10-28-19, 06:39 AM
Zaskar
Quoted: 479 Post(s)
Liked 277 Times in 156 Posts
When was the last time you re-cabled? Just replace the cable AND housing. Always a good place to start. When the shifter starts needing continual adjustment - MORE tension - that's a sign the cable is about to snap. The individual strands are snapping. This will leave you stranded. Worse - the final failure is typically in the shifter, making the repair a bigger pain in the ass.
Oh, and WD40 shouldn't be used on shifters... it's for bottom brackets and brake pads.
Zaskar is offline
Likes For Zaskar:
Old 10-28-19, 06:48 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
Do you sweat a lot? I've seen sweat buildup and corrosion disable a rear derailleur.
jadocs is offline
Old 10-28-19, 10:31 AM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
+1
The OP didn't say which version 105 he has, but based on the low mileage, I'd guess it's 5800 or 7000 series 105. Fraying cables inside the shifter sounds like the cause of his issues.
noodle soup is offline
Old 10-28-19, 12:03 PM
Zaskar
Quoted: 479 Post(s)
So disappointed in you guys. No one got the "stranded" reference ;-)
Zaskar is offline
Likes For Zaskar:
Old 10-28-19, 12:22 PM
TheDudeIsHere
Registered User
Quoted: 188 Post(s)
Liked 276 Times in 161 Posts
YES this may explain the "weirdness" the OP mentions.
I had RSX shifters back in the mid 90's. Brifters were acting strange, shift but no shift at times. Read about the WD 40. Used it after the bike sat a while and wouldn't shift. Now I have and Ultegra bike that has this weirdness. All new cables. I believe it is a mechanism inside the shifter.
After the spray, the shifter worked perfectly fine. Once it works, it works. If it sits for a long period without riding, it will act this way.
But once it starts working, it works fine. I bet the OP just happened to get it working, luckily, then it was fine after that. WEIRD!
TheDudeIsHere is offline
Old 10-28-19, 09:47 PM
MidTNBrad
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 159 Post(s)
Liked 138 Times in 79 Posts
I had this happen on my old bike. The ratcheting mechanism in the shifter wouldn't catch. Follow
MidTNBrad is offline
Likes For MidTNBrad:
Old 10-29-19, 05:48 AM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 986 Post(s)
Liked 583 Times in 438 Posts
It def. needs maintenance...or replacement of parts.
Tell us what was wrong.
eduskator is offline
Old 10-29-19, 06:00 AM
Zaskar
Quoted: 479 Post(s)
Let me see if I have this right... "flood" or wash the shifter with WD40 then add lube. That's it? I see a couple issues with this...
- The WD40 is now in the cable housing and under the tape, etc.
- Adding the chainlube to the shifter either makes a diluted solvent or a diluted lube... with solvent
Wouldn't it be better to:
- Remove the shifters
- Clean the shifters - with WD40 or another solvent
- Flush out the cleaner/solvent
- Relube the shifter
- Reinstall the shifter
Zaskar is offline
Old 10-29-19, 08:44 AM
AndyK
AndyK's Avatar
Bikes: '11 TIME NXR Instinct, '03 De Rosa Planet '79 Paris Sport (Moulton)
Quoted: 17 Post(s)
Liked 15 Times in 11 Posts
Maybe a small spray of dry-lube onto the brifter gears, instead of flooding them with WD40?
'11 Time NXR Instinct / '79 Paris Sport by Moulton
AndyK is offline
Old 10-29-19, 08:59 AM
noodle soup
I spray clean streak into the shifter, and then use compressor to blow out the junk. Repeat this process until it shifts well, and then apply Tri-Flow and blow lightly with a compressor.
Old 10-30-19, 07:13 AM
dougphoto
Quoted: 130 Post(s)
Turns out the cable at the shifter end was frayed, new cable and all better.
Likes For dougphoto:
