Your Most Recent Cycling-related Repair
Old 10-23-17, 06:32 PM
  #51
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times in 163 Posts
I replaced my rear derailleur cable last week. It broke while I was going up a rather steep hill...leading to a brief walk of shame followed by another 15 miles in 50x11.
I've also now learned the trick for keeping the derailleur in a more reasonable gear, should I ever snap the cable again.
wipekitty is offline
Old 10-23-17, 07:43 PM
  #52
timtak
timtak's Avatar
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 404 Post(s)
Liked 85 Times in 73 Posts
I would like to know. Google is my friend. Thanks for making me think about this possibility.
https://www.artscyclery.com/learning...rcablefix.html
I have been thinking about bar tape. I don't even need it any more. I feel my handle grip covers to be greatly superior, cheaper, easier to fit, and less bother to remove and replace when replacing cables than bar tape. This makes me wonder why road bikes have bar tape at all? What is bar tape's raison d'etre? Could it be that it is because bar tape is a nice little earner for lBS rather than actually being useful?!?
timtak is offline
Old 10-23-17, 08:22 PM
  #53
f4rrest
Farmer tan
f4rrest's Avatar
Bikes: Allez, SuperSix Evo
Quoted: 2870 Post(s)
Liked 28 Times in 23 Posts
I snap one every few months with my massive index finger guads.
f4rrest is offline
Old 10-24-17, 07:21 AM
  #54
Bob Ross
your god hates me
Bob Ross's Avatar
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1242 Post(s)
Liked 1,271 Times in 702 Posts
I replaced some uncooperative DTSwiss rim strips with Stan's Tubeless Tape on my wife's wheels last night.
Bob Ross is offline
Old 10-24-17, 07:38 AM
  #55
bikecrate
bikecrate's Avatar
Quoted: 623 Post(s)
Liked 397 Times in 226 Posts
I'm not a big bike wrencher, but I'm proud of my accomplishments this past weekend. After my last ride on my road bike I noticed the crank was wobbling. I ordered the appropriate Park tool to remove the bottom bracket. Then I found a Youtube video describing the process. This past weekend I successfully removed the bottom bracket, greased the parts and reassembled. It is all tight now. While on the stand I took out the rear brake cable and retouched some of the paint. I just need to return the cable and adjust the back brakes.
bikecrate is offline
Old 10-24-17, 02:29 PM
  #56
dmanthree
dmanthree's Avatar
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times in 191 Posts
Front brake and pads on my Roubaix were replaced. The original had an oil leak that quickly contaminated the pads causing loss of effectiveness and tons of noise. Shimano paid for the replacement.
dmanthree is offline
Old 10-24-17, 02:30 PM
  #57
dmanthree
dmanthree's Avatar
Quoted: 646 Post(s)
Funny, I just had a tube pop due to that stuff. It's flimsy stuff.
Old 10-24-17, 03:02 PM
  #58
Bob Ross
your god hates me
Bob Ross's Avatar
It's definitely thin! But I've been running it on one of my wheels for ~18 months without incident, so I'm hoping that's the norm.
Bob Ross is offline
Old 10-24-17, 03:13 PM
  #59
dmanthree
dmanthree's Avatar
Quoted: 646 Post(s)
I'm a creature of habit, I guess. I broke down the tires and installed Velox. I've used it for decades without any issues. Someone mentioned Stan's No Tubes rim tape, and if I had thought of it I might have given that a try. It's designed for tubeless, but no doubt would work well with tubes.
Old 11-21-17, 02:24 AM
  #60
timtak
timtak's Avatar
Quoted: 404 Post(s)
The handle bar fairings are on and I will try them out soon.
Bar Fairings by Timothy Takemoto, on Flickr
I have put reflective tape on my downtube and top tube - red in the picture above, yellow on my other bike for carbon protection and visibility at night. It is reasonably priced.
https://www.aliexpress.com/item/http...808845586.html
timtak is offline
Old 11-21-17, 03:05 AM
  #61
SethAZ
SethAZ's Avatar
Bikes: 2018 Lynskey R260, 2005 Diamondback 29er, 2003 Trek 2300
Quoted: 564 Post(s)
Liked 334 Times in 182 Posts
Tonight I pulled a latex tube out of my rear wheel that had developed a slow leak over the weekend, and then was leaking somewhat quicker during this morning's ride so that I had to refill it during the ride to make it back home.
It appears that I micro-pinched it a little with a tire iron while swapping the stock tire that came on my new bike for this new Compass 32mm tire. Kind of wierd that it took a week to really turn into something. I patched it and put it back in. The tire had stretched out enough after a week of riding that I was able to get it on, albeit with difficulty, using just my hands.
SethAZ is offline
Old 11-21-17, 03:01 PM
  #62
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times in 39 Posts
Rebuild (as in overhaul)one of the Lyotard pedals on my Peugeot.
Jon
Jon T is offline
Old 11-25-17, 10:44 AM
  #63
timtak
timtak's Avatar
Quoted: 404 Post(s)
The motor cycle handlebar fairings rattled but they are warm so I persevered. Today I drilled a 6mm hole through the front top of both of my hoods and screwed an M6 stainless steel bolt into the hard plastic of the hood through the fairings which tapped a thread for itself in the plastic of the hood and now makes them rock solid.
Bolted to Hoods
I feel like I am riding a motorcycle, or a Rolls Royce.
timtak is offline
Old 11-25-17, 01:19 PM
  #64
Wileyrat
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 335 Post(s)
Liked 220 Times in 133 Posts
I wiped down and lubed my chain, then cleaned the gunk off my pulley wheels.
Wileyrat is offline
Old 11-25-17, 06:46 PM
  #65
cyclebycle13
Super WW
Bikes: A really light one and a really heavy one.
Quoted: 70 Post(s)
Liked 43 Times in 15 Posts
5:17 am commuting to work (on my road bike). 28 degrees, dark and the rear tire gets really squishy (flat) halfway in. Find the cut, boot the tire and change out the tube in 7 minutes (with gloves on) and get to work only 5 minutes later than usual.
cyclebycle13 is offline
Likes For cyclebycle13:
Old 12-18-17, 07:58 PM
  #66
timtak
timtak's Avatar
Quoted: 404 Post(s)
Another pair of Shimano Carbon soled shoes SIDI-fied with heel pads. I got them for 20USD when looking for a cheaper way to purchase cleats (on second hand shoes - sometimes they are cheaper than the cleats on the) for 20USD including postage. I now have 4 pairs of Shimano pro-level hollow carbon soled shoes! The previous owner had shoe gooed the heel (a cosmetic repair) but I did not bother to carbon patch them because the base of the heel is not critical, but a heel pad is, lest you wear all the carbon away.
The process of SIDI-fying (adding a replacable rubber heel) to a pair of carbon sole shoes is
1) Purchase some M5 claw nuts for a bout 1USD
https://www.aliexpress.com/item/10pc...833008717.html
2) Put a M5 bolt into your vice, protruding about 4mm, and screw the claw nut down onto it and then use your angle grinder to grind away 4-5mm of nut to about the height of the claws, and the bolt protruding from your vice.
Grinding Down a Claw Nut by Timothy Takemoto, on Flickr
You have to use the grinder upside down I think so that the nut is not twisted off the bolt. This means that sparks come in your own direction so old clothes are a good idea.
The shorter claw nuts can be used to repair cleat nuts too.
3) Drill a 7mm hole in the heel of your shoes. Do NOT drill the hole as shown in the picture below from the inside because the heel lining can get caught in the chuck and pulled off your shoes! Drill from the outside in, at about the place where there is a Shimano non-replaceable heel pad rivet.
Don't do this by Timothy Takemoto, on Flickr
4) Bed the nut in the inside of the sole in a two/three stage process (this is the only bit that is not obvious) by first bolting down using a cleat nut on the outside. Then, when the cleat bolt starts to turn the claw nut on the interior of the shoe (this can twist the claws cutting a circle in your sole) use a hammer and steel rod to bash the nuts claws into the carbon. Tighten with a cleat bolt again to embed the nut into the interior of the shoe so that you can't feel it when you replace the insole.
5) Bolt a piece of rubber onto your heel with a cleat bolt (I drill a 6mm hole through, and 12mm partial hole first) or purchase a SIDI replacement heel if you want it to look nice.
Adicted to SIDIfying by Timothy Takemoto, on Flickr
Replace the rubber, and the cleat bolt periodically. The super-stiff Shimano shoes, which were ready to go in the dustbin, are good for another decade.
timtak is offline
Likes For timtak:
Old 12-19-17, 12:17 AM
  #67
a1penguin
a1penguin's Avatar
Quoted: 139 Post(s)
Liked 33 Times in 20 Posts
Dang timtak, that's hard core!
a1penguin is offline
Old 12-19-17, 09:27 AM
  #68
Hunterdog
Bikes: 2018 Specialized Roubaix Expert. 2015 Specialized Roubaix SL4
Quoted: 58 Post(s)
Replaced broken rear derailleur cable last week.
Hunterdog is offline
Old 12-20-17, 09:40 PM
  #69
1.weasel
Quoted: 9 Post(s)
Swapped frame sets.
1.weasel is offline
Old 12-24-17, 12:19 AM
  #70
Jon T
Quoted: 397 Post(s)
1 broken spoke replacement and wheel trueing.
Jon
Jon T is offline
Old 12-24-17, 12:26 AM
  #71
SethAZ
SethAZ's Avatar
Quoted: 564 Post(s)
How many layers? I'm just curious because when I've run tubes over two layers of Stans tape and then looked at the tape over the spoke holes, I just get a very little indenting downward, and nothing that could conceivably pop a tube.
SethAZ is offline
Old 12-24-17, 12:03 PM
  #72
dmanthree
dmanthree's Avatar
Quoted: 646 Post(s)
Just one layer, but the tube popped because the rim strip moved. When I pulled the wheel and tire the strip exposed a spoke hole, and well...
Old 12-24-17, 02:35 PM
  #73
SethAZ
SethAZ's Avatar
Quoted: 564 Post(s)
Ah, that sucks. I have experienced Stans tape getting wrinkled a bit on the very edge where a tire bead that was squished between it and the bead hook was pulled out. Ended up having to pull the tape, clean up the rim, and lay down some new tape. I'm not sure if that's a Stans thing or more like any tape would have suffered similarly under similar circumstances.
SethAZ is offline
Old 01-05-18, 07:35 PM
  #74
dmanthree
dmanthree's Avatar
Quoted: 646 Post(s)
Stan's is good stuff, so I think that could happen to any tape. Right now I'm running Schwalbe rim tape, and all has been good since that install. Honestly, if I buy a new set of hoops I'll consider the lack of a need for any tape a big plus. Looking at the new Reynolds Aero 46db.
Old 03-26-18, 07:36 PM
  #75
timtak
timtak's Avatar
Quoted: 404 Post(s)
I removed the handlebar covers from my bike after a great winter of riding with warm hands.
Winter is over
I also replaced my brake pads with Discobrake red pads (at about 24USD for 4 pairs) but I will be replacing them with Kingstop reds at about 10USD for for pairs, since I can't tell the difference. I sewed my gloves up again, and replaced a Sidi-like pad that I had attached to my shoes.
Replacement Replacement Heel
It is important to use a flat wood drill bit
to cut the recess for the head of the (cleat) bolt use to attach the pad to the sole. If you use a normal steel twist drill then it cuts a conical hole, weakening the rubber pad. I use a 11 or 12 mm drill not 22mm as shown.
timtak is offline
