Intermittant Fasting 🍴
#126
Quoted: 18883 Post(s)
Liked 10,646 Times
Recall that IF is not a diet, rather, a diet protocol to help your body achieve improved exercise efficiency and nutritional benefit from whatever diet and training routine you choose. Its multi pronged approach that places the body in a higher bio-active state for maximum nutritional uptake, and exercise recuperation. He makes some great points for many of the diet ills of western society, but I think Dr. David Reuben beat him to it. By the time I finished his book, I was afraid to drink water.
#127
A naysayer? Just so that we're clear, I don't make anything up. All of my posts are the result of what I've researched or experienced. If you disagree feel free to post a counterpoint (that's the point of these threads), but don't just case aspersions without any support or validation.
#128
just another gosling
Quoted: 3881 Post(s)
Liked 1,933 Times
Um, no. But even if I did it wouldn't pass on anything that biased and esoteric. The *studies and research I quote* are a lot more reliable and with less biased than that. Maybe if you rephrase the question if I misunderstand what you're asking?First, its an adaptive process. So it takes time to build up to the point of best utilization.
Second, I've expressed on multiple occasions, that I'm not an advocate of fasted cycling, nor do I intent to be anytime soon. I don't think that's the best application for IF.
Also we need to keep in mind that IF is a protocol, not a diet. Nevertheless, if you have any information about its effectiveness, I wouldn't mind hearing it. Which is one reason I'm not an advocate.
1) will "achieve improved exercise efficiency and nutritional benefit from whatever diet and training routine you choose "
2) "places the body in a higher bio-active state for maximum nutritional uptake, and exercise recuperation"
3) "I choose to use IF, predominantly as an anaerobic training tool" (studies to back up that this works, i.e. IF improves anaerobic performance)
4) "increased muscle hypertrophy"
"Also, some people are anomalies, but that's not science. There's not necessarily a right or wrong, but it has to be something that works for the majority, and is repeatable under similar circumstances to be valid." Since you admit that, there must be RCTs which support your contentions.
Results matter
Results matter
#129
Quoted: 1027 Post(s)
Liked 325 Times
#130
Liked 10,646 Times
I don't doubt that there's something there in IF for a lot of people, but some of the hype surrounding it ...
#131
I think I missed seeing any studies and research among your posts. By those two words, I mean research papers published in peer-reviewed scientific journals. You know, equivalent to the studies I've posted in this thread. Since as you say, there are zillions of studies out there, it shouldn't be too hard for you to find and post studies that support your contentions that IF:
Just keep in mind I didn't invent the concept, so don't shoot the messenger. If you disagree, focus on the author. I do learn from these sites, but this presents my opportunity to give something back. At least to the limit of what I've leaned. This thread is also my attempt to learn more. So some ulterior motive too
I do my best to summarize and put things into more widely understood terms. If I'm doing it wrong, then I can learn something. The idea is to leave more knowledgeable than when we came in. Which is, I hope, everyone's goal.
#132
The Rise of Intermittent Fasting: Relevant or Fad? 🍽️
Some additional data I found on IF. Note that although these are not clinical trials, many have been used to compile the data, and/or are highlighted within the articles.
- On-and-off fasting helps fight obesity, study finds
- Five-day fasting diet could fight disease, slow aging
- Study Shows Intermittent Fasting Promotes Health and Longevity
- Does Intermittent Fasting Boost Your Metabolism
- Boost Anabolic Hormones With Intermittent Fasting
- How To Boost HGH 1300-2000% Through Intermittent Fasting
- Are There Any Proven Benefits to Fasting?
#133
Liked 10,646 Times
My hunch is that IF probably has two main things to offer most people: a psychological benefit like being in control of your hunger along with a schedule, and it probably helps control insulin levels in people who don't exercise. There could be more, I don't know, it's a bit of an open question, but those two seem to be real.
#134
Either this is an unusually tough audience, or I need to do a better job on my mocking? Reference your database on snake oil salesman. On the other hand, maybe you're still dubious about IF?
#135
Two new vids I discovered on IF. The first is on fasted training. Some folks might find 4:00 of particular interest where he discusses the hormonal benefits of IF during training. The second, specifies some of the classic mistakes of IF.
- Thomas DeLauer has so pretty credible perspective -- based on research -- on most issues.
#136
What is going on in this thread?
#137
Liked 325 Times
In general I think KraneXL is trying to convince the rest of us of the "magic" of IF. But, I suspect most of the other posters on here have seen enough fad diet trends in the past to buy into the idea that it is somehow superior to other forms of calorie restriction.
#138
If you're referring to the links (I assume you're not just a naysayer), I'm not sure. I test them once I submit. They were work at that point but I will try to resubmitt. I'm trying to help you become a more educated consumer. If the information presented here appeals to you then you leave the thread with useful information. If not, you simply unsubscribe and move on to the next thread that gives your the answers you want to hear.
#139
High-Intensity Interval Training and Intermittent Fasting - A Winning Combo for Fat Reduction and Optimal Fitness
https://fitness.mercola.com/sites/fi...t-fasting.aspx
GSP - Intermittent Fasting Changed My Life - Joe Rogan Podcast
#140
Liked 10,646 Times
#141
Liked 325 Times
Simply put, HIIT is the best way to get shredded. A lot of people think they need to put in long, boring hours doing stupid cardio like riding a bike, but I’m here to say if YOUR fitness plan isn’t built around HIIT, you’re wasting your time. You have to shock your metabolites into submission if you want to torch fat. Keep the body guessing – one day it’s sprint intervals the next day you dress like a clown! Look, it’s not about endless hours of cardio, HIIT does more for your fitness in 45 short minutes than a lifetime of riding a bike. It unlocks weight loss hormones, jump starts your metabolism, and incinerates calories. You even get a 3 % boost for EPOC. Combined with the anabolic magic of IF, HIIT will have any couch potato looking like Arnold inside of a week! Plus if you really want results you have to take a fat burner and I review the best 3 of them here.
#143
Quoted: 4227 Post(s)
Liked 2,488 Times
That's great nothing wrong with that .... but keep in mind that there are a lot of very experienced people posting on this forum. Some have many years of experience and have experimented with all types of different nutritional and training protocols and they have figured out what works for them and what doesn't....I have my own system which works great for me. I space my meals 5-6 hours apart. This includes an early morning breakfast, a lunch at noon hour, late afternoon snack or post workout drink and late evening dinner before bedtime, that's what works best for me.
#144
Liked 2,488 Times
https://www.youtube.com/watch?v=W_KS3RQbB5g
#145
#146
My personal experience with IF is that for me it'd require quite strange timings to work. I need breakfast, not because I'm hungry in the mornings but because if I don't eat breakfast my insulin sensitivity will just go away for the rest of the day. I know IF is supposed to increase insulin sensitivity but for me in some cases it causes the opposite. The effects of breakfast on insulin sensitivity have also been studied and it would seem especially for diabetics like me eating breakfast is a viable choice to control insulin sensitivity for the rest of the day
#147
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
If you really wanna fast intermittently, try living on SNAP only.
#148
The people I know that are on snap are gargantuan, so maybe they're not doing it right?
This is a perfect example of times when IF may not be the correct choice. Although, the "I" does offer even a special case such as yours some latitude if you thought it was something you could really benefit from.
#149
It seems to me the Taubes / Attia "are hacks" crowd of critics mimic the 'Hillary child slavery' / 'govt. delivering chemicals through jet contrails' / 'deep state' attack dog style in their scientific commentary. Leave me out of it, both of these gentlemen do a fine job of representing themselves in the books & articles, TED talks, etc.
Personally, Attis' history as an open water endurance swimmer, boxer, marathon runner gives him more credibly in my eyes. He is very much a proof of concept guy, as I see it.
#150
Quoted: 1975 Post(s)
Liked 232 Times
Like him or not, agree with him or not (I don't agree with everything he says), you can't ignore his results or dismiss the science. Which is at this moment, as reliable as it gets. Here's he is on Joe Rogan's podcast with 7 minutes on the uptake of nutrients and the role of insulin (and other hormones) manipulated through fasting.
Joe Rogan - Why Obese People Can't Lose Weight
https://www.webscorer.com/racedetail...9521&did=34182
I’m at peace with the fact that I can’t FTP at more than 4 watts/kg and probably never will again
that's like high Cat4 level at best. Are we really going to use that as the standard? There are literally thousands of cyclists with better fitness using no particular diet at all.
