Prep for paint
Randomhead
Liked 3,698 Times
the big advantage of rattlecan enamel versus automotive paint is safety. Unless someone is willing to invest in equipment, rattlecan is much safer. I have wondered if my asthma is related to my use of isocyanates under less than perfect conditions. I was probably one of the first people to use urethane clear in the bike industry, the autoparts guy recommended it. Said the local NASCAR team used it over lacquer. That was back when catalyzed acrylic enamel was meant to be a topcoat. You can still get paints like that for a single topcoat application, I have considered it.
Got to thinking about the quality of the air around me when I rattlecanned the frame. Was choking on the fumes and was outside with a slight breeze, too. Seriously considering brush on paint next time around. Likely better for my lungs.
Quoted: 897 Post(s)
Liked 9 Times
Yeah, but the buzz is not as good, doesn't last as long. I didn't think the stuff was bad when I was spraying it at all, it was the gassing out period where the fumes really got to me, when I left the drying frame in an enclosed area. I just about passed out from those.
Randomhead
Liked 3,698 Times
a mask good enough for rattlecan paint jobs is not that expensive. 3m sells a really nice mask with many options for filtering. They will work for catalyzed urethane for a while. The fact that they fail silently after some period of use is problematic.
You want a mask that will take filters for VOC, they have activated charcoal
Quoted: 2338 Post(s)
Liked 2,824 Times
may be too late, I am no expert (I have painted 2 frames one rattle can and one automotive paint) Auto paint is hugely more durable
I did a lot of research and it suggested that an acid etch primer first coat (rattle can from autopaint) will help end result longevity, followed by sandable primer, then color, then clear
I don't use spray paint of any kind without out a basic 40/50 dollar mask with replaceable filters
Quoted: 8 Post(s)
Thanks for the responses and after rattle can painting a set of car wheels and pricing various rattle can solutions I'm leaning toward Spray Max 2k rattle cans of epoxy primer, color and clear from 66autocolor.com. I might include a sandable primer too, not sure.
Those who prefer enamel from rattle cans, where do you find interesting colors? Unfortunately I'm only finding basic colors in enamel.
Thanks again.
Thanks again.
Randomhead
Liked 3,698 Times
Tractor Supply seems to have the widest variety of colors, but none of them exactly excited me either.
Finished the paint job this weekend. 3 coats of primer, 4 coats of color, 3 coats of clear. Super easy to chip the frame. I bumped the drop out against a board and off came some paint. Put the rear wheel in and removed the paint from the slot. Will go with a brush next time just to see the difference. Will use the boat poly urethane paint, too.
Quoted: 8 Post(s)
When I painted my frame build I used 2 spray cans of primer, 2 spray cans of color and used the HF gun to spray the 2-3 coats of 2K clear coat at $40 a quart with hardener, I used about 4oz of clear total. As it was my first build I didn't want to invest a lot in the paint until I figured out if I liked the ride or not. The price you were quoted is probably pretty standard for an all automotive quality finish. The finish actually turned out pretty good and more than likely I will not be refinishing it.
Thanks
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have dozens of friends who have had really good results with https://us.spray.bike/ . My friends at Squid have done some amazing spray jobs with it.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
I sprayed my first frame with Spray Bike. I think that for the most part it came out really good. I had a few interesting things happen that I can't exactly explain with one of my colors and the clear coat. The blue is considered a flouro and because of that it has more power in the paint. It is/was certainly more finicky. The orange came out beautiful. I don't think I'd use a flouro color again but I'm getting ready to paint my second frame and have already got my paint.
The clear seemed to take forever to cure, like weeks. Even many days afterward, the frame was sticky to the touch in places. I live in a very dry area and humidity is almost non-existent, but almost think it was more humid than I thought. Not sure. Maybe I'm an idiot too. Could be.
Overall I'm happy with the results as a first time user. Second frame will be done once it cools down here.
Quoted: 8 Post(s)
Because I don't want to spend the extra money on a proper respirator for spraying automotive paint I checked into the spray.bike guys. Unfortunately they're currently out of primer. I sent them an email asking when it will be available again and if they had any suggestions for other primers that will play well with their paint. Hopefully I get an answer soon, I need to get this frame painted already.
Liked 2,824 Times
Quoted: 8 Post(s)
Randomhead
Liked 3,698 Times
I wouldn't feel comfortable using isocyanate-based paints without a supplied air mask. When I was looking into DIY solutions, I found Breathe-cool. They sell a system for about $400
Liked 2,824 Times
got it ......all of this is why if I need to redo a frame it will be powder coated or painted by someone else
Please let us know what they say regarding other primers. I'd like to know as well.
Quoted: 8 Post(s)
We are probably at least two weeks out on having the primer back in stock.
We have painted quite a bit with rustoleum primer from the hardware store and had pretty good luck. Definitely no reactions with Spray.Bike that we have run into.
Randomhead
Liked 3,698 Times
now that it's getting colder here, finding a place to spray is going to be a problem. I was looking at spray tents in the garage, but there is no ventilation other than opening the door, which would get back to the temperature problem
Quoted: 4207 Post(s)
Liked 3,872 Times
Doug Fattic, in SW MI, faces this temp issue by trying to not paint when it's cold out. With good/healthy venting it's impossible to keep the booth warm enough. And IIRC the additives to help the paint's flow out/curing also take away from the paint's final finish and durability, Andy
AndrewRStewart
AndrewRStewart
