Real loud creaking sound??
So i have a really annoying problem. Imagine riding your bike and everytime you pedal you hear an old rocking chair. Thats what i hear 24/7 and i can't figure out what it is. Ive greased both rims and checked them for any damages and i ended up with nothing. Its not the pedals because ive tried multiple different pedals. Everything is tight, no loose bolts or anything. The back rim in aligned near perfectly. It only does it when i pedal (or spin it backwards) but it needs to have pressure on it, like someones on it.
I suppose a little more detail would help. Its a 24in mcs (before you say scrap it, i plan on using the parts to build a 24 in diamondback), 3 peice crank with a European bottom bracket (cant be changed to anything else). I dont know what else you need to know but like ANY suggestions at this point would be amazing.
-ps the chain ring is NOT bent. It came off an old bike and it worked just fine and i made sure there wasnt a bend in it
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
Creaks can be a number of things so a few things to check.
1) Loose hubs or worn out bearings
2) Loose spokes
3) Loose crank arms or worn out crank bearings
4) Loose headset or stem
When you pedal you are applying torque which is why something loose is creaking. BTW MCS is an awesome bike especially if it's an older one.
2) Loose spokes
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
The most common creaking experiences I've had with cranks on BMX bikes is aluminum crank works loose and will strip if not tightened. Chromo cranks will get cracks that creak.
Typically those types are from jumping, 180/360 type stuff where your weight drops while pedals are horizontal.
This is a fairlly recent one for me. Doing some BMX type stuff on a PK Ripper fixed.
This is
This is
Quoted: 92 Post(s)
Liked 12 Times
