Keeping bosses straight
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
This is my second attempt at brazing on such delicate material and I have a question. To keep the bosses straight do you use a jig or did it get better with practice? I made the holes so I had to push in the bosses rather than just fall in, I filed out the holes on the strengthening diamonds so they fit around the head of the boss and then proceed to braze everything. I am mostly pleased except for one of the bosses if off a little. Not that it will be noticed but I will know it is there. I even managed to fill in a couple dings on the top tube.
Quoted: 4205 Post(s)
Liked 3,864 Times
Are the axis of the bosses off? Or are the tangs of the reinforcements off?
I don't bother with reinforcing "plates" although when I have used them I remember that care in their forming (the curve needs to be spot on) and care during the brazing are essential. Touching the reinforcement with the filler rod can be a help or hinderance, here practice certainly helps.
I do use a home made jig to insure the verticalness of the boss axis. The pilots are Al so they don't bond to the silver and are smooth to not become flux frozen in the boss. I did use my sloppy and small lathe. Here's a shot. Lastly is that I will file the top end of the boss square and flat to the tube regardless of how things turn out. Usually this is only a tiny "correction" given my piloted jig. Andy
AndrewRStewart
AndrewRStewart
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Dave
Liked 3,864 Times
The jig I use doesn't do much to insure that the bosses are on the centerline of the tube. The drilled holes do that. Before I got an Alex Meade drilling jig I would drill a tad undersized and touch up the holes' locations with a chainsaw file. Then round off with the right size drill bit. This way I could correct for off center initial holes. Andy
AndrewRStewart
AndrewRStewart
