How to cinch '82 Miyata Seatpost Bolt
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
The nut isn't keyed and turns with the bolt. I filed the bolt down in length so I could get a coin on the nut side, but that doesn't work to my satisfaction. And that requires a third hand to hold up the seatpost in the process.
JB Weld?
JB Weld?
Quoted: 1641 Post(s)
Liked 831 Times
Easy, just tape the seatpost in the right position to the seat lug, and you will have two hands to work the bolt with....
Tighten, remove tape, and you are done!
That sure looks like a chain ring nut. Perhaps a nut holder for chain rings would work.
señor miembro
Liked 6,488 Times
Two good ideas: tape and a better tool on the nut side. It would be nice to acquire an allen keyed nut, so I could just use two 5mm wrenches.
Quoted: 1627 Post(s)
Liked 630 Times
I have a big-ass flat blade screw driver that would be perfect for that application. Chain ring tool would be my second thought/
Quoted: 472 Post(s)
Liked 1,028 Times
I've made several such tools by a) creating a bin of odd steel bits "too small to throw away". As in this case pick one that's his third carbon spring steel or an old tool or piece of banding then b) cut to width and grind a notch in each edge, leaving a nub in the center to key into the nut. Sort of a DIY chain ring nut tool.
But ifn it were me, I'd try to find or fit a classic dual ended pinch bolt there. I have found that there is no better design than the dual ended (hex key socket on each end) steel pinch bolt assembly. And regardless of the condition of the key on the NDS end or the notch in the frame, I always use two hex keys. I've seen too many of those notches stripped out by folks only using a hex key on the DS bolt head. I never understood the need for the wee bit of confidence that key/notch idea delivered. Doomed to failure.
señor miembro
Liked 6,488 Times
^ Thanks for the ideas, guys.
A longer bolt, stacked spacers and a standard 8 or 10 mm nut will fix that. Done it a few times on those old Miyatas. Beautiful frames.
Passista
Quoted: 867 Post(s)
Liked 721 Times
Some seatpost nuts have a splined section that is a press fit on the frame.
señor miembro
Liked 6,488 Times
^ Ooh, that would be perfecto.
I like that this bolt all fits inside the lug, so I'm trying to keep that bit of the sleek originality.
In the pic, the nut does look like one used on a chainring. It's not, though, and is far thicker and without a lip.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Had a Univega Super Strada set up the same way. I would tighten it just enough to hold the seatpost in place (it's a fine line) with my left thumb on the bolt and fingers keeping the post more or less in position while the right hand used the hex wrench. Once things were where I needed them to be I switched to a wide screwdriver as mentioned above and was able to tighten appropriately.
It never failed to irritate.
señor miembro
Liked 6,488 Times
señor miembro
Liked 6,488 Times
señor miembro
Liked 6,488 Times
señor miembro
Liked 6,488 Times
I used a tiny, tiny bit of JB Weld on the nut, just like i was greasing it. Then waited ten hours. I didn't think it would hold, but it works great. I'm pretty sure I could hammer it out if needed, but I hope it's there for the dur.
Quoted: 41 Post(s)
Liked 51 Times
I'm encountering the same thing on an '83 Miyata 1200 I recently purchased. How could the factory have been so blind to this? I figured a wide flat tip screwdriver would do the trick also, but the bolt protrudes just enough that that doesn't work.
I'll try spacers, and possibly a lock nut washer if I can find one to fit and see if that works.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
Maybe you coul sneak a small star washer in there...
Quoted: 41 Post(s)
Liked 51 Times
UNREAL! You can't make this up.
For whatever reason, in my standard tool box, I kept a new 10'' long piece of rubber vaccuum hose from a 1986 Trans Am I had a looong time ago. After determining it was a bit to wide, I cut off a piece about 1/16'' long. I then cut off about a 1/8'' piece off the circumference and wedged it in so it made a nice tight fit on the nut side.
I then put the bolt through pushing it past the rubber "washer" I made and threaded on the nut. I used a screwdriver in the groves of the nut to hold it in place, and voila!! I nice, tight fit!!! Seatpost is a solid as can be!
Moral of the story...don't throw anything out, lol!!
Fred
Fred
