Help With Frame ID
Quoted: 147 Post(s)
Liked 331 Times
Help With Frame ID
A friend had this frame given to them,the fork is supposed to be original. Forgot to measure BB as i am new to this C And V. It is my size.I have ideas as to what it is but i am sure you folks could nail it down,thanks
Bad example
Quoted: 825 Post(s)
Liked 208 Times
I would be surprised if that fork was original, but I am willing to be educated.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Looks very much like a Carlton to me. From what I've read Carltons could be ordered pretty much how you wanted them, so Nervex lugs and a Davis fork crown would not be too strange.
Quoted: 4722 Post(s)
Liked 3,036 Times
I don't think the fork is OEM because the blade end treatment is not the same as the stays. The stays have domed ends where they transition to the dropouts, while the fork ends are bevelled. Frame characteristic look like a higher end product from a mass manufacturer. The Portacatena dropouts date it circa 1978-1983. It's probably towards the earlier end of the range given the exposed nut brake bridge and apparent lack of braze-ons. It does look British to me, with the wrap-over stays and top tube, cable stops.
Seńor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
That powder coat is quite generously applied. Might make it difficult to get a serial number from it - but getting it would help the identification. Also seeing if frame serial and one stamped on the steerer don't match (or if there is none on the steerer) could confirm T-Mar's suspicion about the originality of the fork.
Quoted: 3241 Post(s)
Liked 2,512 Times
Do the headbadge holes offer any clues?
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,061 Times
Agree the fork is probably a replacement but not only the transition treatments (domed, flattened vs beveled) but also strong hints of a rifled steerer so most likely a Columbus fork and betting this Nervex-lugged frame is Reynolds 531. Also the long campy DOs don't have portacatena holes (2) but a single return spring hole for the Sport or Gran Sport RD, so it's not a late '70s/early '80s frame, except maybe the FORK is about that era.
If OP will measure the headbadge hole spacing there might be a clue in that, too.
Bikes: Some Schwinns, Raleighs, Centurions, Crescent, Bianchi
Quoted: 248 Post(s)
Liked 289 Times
The head tube lugs are the very early type before they changed to the fishtail type in the 50s. I have a frame with the identical lugs, and that is the info I've been told while researching the maker of my frame.
Nervex pro
Nervex pro
Quoted: 4510 Post(s)
Liked 6,377 Times
Holdsworth?
Quoted: 147 Post(s)
Liked 331 Times
I will have to go visit and get some measurements,hell, i will probably just go buy it from him. I have never built a bike up from a frame but it looks like a good candidate.Thanks for the input so far.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
If the powdercoat is a solid color (no metal flake or pearl), you can wet sand it so it doesn't look so much like it was dipped in frosting.
Liked 3,036 Times
This is correct. I erred in my earlier post, though for the life of me, I don't know how I messed that one up.
Bad example
Quoted: 825 Post(s)
Liked 208 Times
Quoted: 147 Post(s)
Liked 331 Times
I bought the mystery frame because,well you folks know why,there is still room in the garage.BB is 68mm , rear spacing is 120, distance between head badge holes is 5omm. There is a serial number on bb i think it is 23261 T. I may never know for sure who made this bike but i should learn a thing or two building it up. Thanks for all your replies.
Quoted: 3811 Post(s)
Liked 3,336 Times
Liked 3,336 Times
