Racer Tech Thread
#5676
W**** B*
Bikes: Several
Quoted: 103 Post(s)
I've since switched to a handful of tubeless compatible (instead of tubeless ready; WTF is there a distinction there?) wheels and mounting has been much easier, if I can't do it by hand, a bead jack makes it simple/quick.
The soap and water recommendation I thought is usually for 'seating' rather than mounting.
I bought one of those AirShot things. It works surprisingly well with the 6 Hutchinson Road tubeless and 2 WTB 650b tires I've seated.
Coat bead with soapy water, mount tires, pour a little bit of soapy water on the rim bed, just enough to lubricate, then remove core, attach Airshot (pre-pumped to 120+psi), hit the switch, and boom. Seated.
Remove airshot carefully, add sealant, replace core, pump with regular floor pump. The shake the crap out of it and do the normal tubeless dance of letting it sit horizontal on each side for a bit.
#5677
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Is it A Thing that "tubeless ready" rims are SUPER f-ing hard to mount non-tubeless tires on to?
I got some DT Switss P1600's for training wheels - they're "tubeless ready" but I just want to run them with gp4000s & tubes.
I gave up after five minutes of struggling to get the tire on.. I could maybe get it done, but really wondering if I want to repeat that struggle on the side of the road. Much less on the side of the road in the rain..
Perusing the user manual, it says to use "soap & water" to mount the tires... wtf.
Maybe it's just these wheels, maybe the tire, maybe it's just me, dunno.
Anyway anyone have experience with these? Or mounting regular tires on "tubeless ready" rims in general?
Un-****ing-believable. I don't have the patience for that. Turned the ENVE 7.7 into the zipps which I can mount tires on without levers.
#5678
¯\_(ツ)_/¯
Quoted: 967 Post(s)
tbf I think it's possible, I just suck at rollers and have bad nerves in general so I avoid it. much easier to hook up a nice trainer and focus on the warmup rather than trying to not fall.
#5679
Cat 2
I'm getting a deal on spec through my team this year on a new bike and I'm heavily debating a venge vs a tarmac. Both similar builds but venge is a few hundred bucks more. I'd put an aero road bar on the tarmac because I prefer that feeling and it would close down the aero gap between the two bikes.
What do others think?
#5680
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I work in a Specialized shop and we've sold a few '19 Venges. The consensus is that they're notably faster than the Tarmacs. I haven't ridden either, just reporting what the riders said.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#5681
i'd take a tarmac over a venge any day although that's probably a decision driven by aesthetics more than anything else.
speaking of aero bars, has anyone tried the aluminum bontrager ones? i need new bars regardless and they also offer these in 38cm so I figure it's a worthwhile investment.
https://www.trekbikes.com/za/en_ZA/e...lebar/p/23238/
#5683
¯\_(ツ)_/¯
Quoted: 967 Post(s)
Given your size I wouldn't imagine much flex or anything.
#5684
Quoted: 1852 Post(s)
Liked 679 Times
I've heard two complaints about those Bontrager bars:
1. They're heavy.
2. The internal routing is not great and the metal edges on the routing holes kind of cuts into the housing. (Which really shouldn't cause a performance issue.)
1. They're heavy.
#5685
thanks for the comments. do you all happen to know if they're heavy compared to other aluminums bars or heavy compared to carbon bars? it's either those or some standard round tubing aluminum bars. i feel like it'd be pretty easy to file down the edges of the routing holes to dull the edges?
#5686
Liked 679 Times
From Bontrager's website: 380mm = 320g 400mm = 330g 420mm = 340g 440mm = 350g
I feel like I had seen reports though that they were closer to 390g for a 42.
#5687
Quoted: 842 Post(s)
Liked 469 Times
I've used a set for a few years now, I'm more or less indifferent about them. Would I buy them again, sure.
Both are true, its dug in a bit into the plastic cover of the cables. The weight is a compromise (and I don't know the exact numbers but its not a carbon bar so its heavy). This is a bar $100 lighter than other aero bars (because carbon) and you're still saving 5 watts or so over a round tube handlebar.
#5688
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Any tips on using a silca disc wheel adapter? Keeps leaking. I can’t hold it and pump 100 psi at the same time.
Maybe I should cut up an old tube and squeeze some of that under the adapter while it is seated.
#5689
#5690
Cat 2
Good luck. I hate pumping up tires on my disc or tri spoke. My crack pipe just hates me. I used a friend's ENVE one and it was nicer but I deal with it for the money savings lol
#5692
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
What wheels are you running? I know my 25's match up with my HED Ardennes rims better for more aero. And also, are the roads smooth near you?
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
24.4mm wide rims with a 25mm wide tires sounds aerodynamically delicious. Have fun playing around with tire pressures.
Newbie racer
Liked 1,569 Times
I got so pissed at my Silca press on chuck, I went and spent $5, bastardized an old tube for the presta valve, and came up with this. Now, I can screw on the hose and inflate the disc/trispoke without cussing and without needing 4 hands.
Also, I wasn't going to buy a $65 chuck to get something that actually works hands free.
#5696
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2673 Post(s)
Liked 3,190 Times
nice
"Your beauty is an aeroplane;
#5697
Firm but gentle
Nobody seems to be talking about rotational weight anymore. Am I mistaken here? A cyclist puts power out in very punchy pulses, and a light tire and rim accelerate to a higher speed faster than a bigger tire and rim. A lighter tire is generally a faster tire. Discuss!
#5698
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,307 Times
No one gave 2 craps. It never turned into anything for me and no one ever mentioned the weight or inertia results. *shrug*.
Yet every single person who was racing on my wheels at the time would talk about the feel in comparison to industry big guys like Zipp. Saying how much they loved ours. Then I went out to Colorado for a USGP race and ran across Leonard Zinn. This was at least a year or two after that testing Caley had done. Zinn remarked how he distinctly remembered my wheels and was genuinely impressed and loved the ride. This was before his heart issues obviously.
So sure - I am sure someone will link to all sorts of pseudo studies and articles that look at the physics involved using 4 or 5 different perspectives that will sometimes conflict with each other or not give a definitive answer or a completely biased one but yes - Rotational weight and the mass moment of inertia greatly affect how the wheel feels in acceleration, cornering and general performance. It's immensely under valued but we will keep looking at it.
The rest of the industry has jumped the shark - it's all disc and gravel and adventure. Road is Dead and these products have added so much weight to the equation that in 10 years when someone who is coming into the sport now goes and tries riding a "vintage" race rim brake setup they'll be amazed at the feeling. There will be a resurgence of light rim brake setups in 10-20 years from now.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#5699
Firm but gentle
When aero wheels and low spoke count wheels started to take over there was only mention of all-up weight of a wheelset. Rim weight was never mentioned. Mr. Zinn came up with a way to compare the inertia of one wheel to another: a slender, long threaded rod was attached to the ceiling, the wheel was bolted firmly to the bottom of the rod with the rod taking up the place of the axle. The wheel was rotated 90 degrees and the number of back and forth cycles was noted. Heavier rim equals more cycles.
Even time trialing at a "constant speed" a racer is trying to accelerate his bike twice with each crank revolution. Excuse me if this is obvious but no test data ever takes this into account. I ride on roads in good condition for the most part, and the only thing I have ever noticed about "bigger, faster, better rolling" tires is their increased weight.
#5700
I tried to go with the aero > weight, spent a lot of money on heavier aero training wheels. I was imagining myself doing steadier training rides and perhaps training races (with mostly Cat 1s and 2s, who just motor along like they're on motorcycles, so not much pace change). With tires etc my aero training wheels are 3 lbs (1500g) heavier than my aero race wheels, and they have the same hubs and spokes! I was wondering why, in the best year of my recent racing life 2010, I simply couldn't last very long in the local Tues races. I switched to using my aero race wheels (remember, 3 lbs lighter) and was immediately vying for the sprint win, versus getting shelled 15 min in.
I have no science to back it up, and it may be more me (Craig thinks higher wheel weight isn't bad), but when it comes to how I do, I've literally never done well on the aero training wheels, even in my best form.
I'm definitely a punchy kind of rider. I do short 1/4 pedal strokes to close small gaps. I learned that when riding a tandem in a group and it took 5 pedal strokes to do the same thing - we got shelled a couple miles into an easy Monday ride. After that tandem ride I realized I do a little punch down to close slight gaps. Lighter wheels would help with that, and that may be a "me" thing.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
