Give me your best gearing recommendations
Quoted: 128 Post(s)
My Raleigh RXM comes with 46/36 and 11-28t, all 105. This seems like a pretty lame combo. The overlap is huge and the range is small. My chicken legs can't pump out 400w like others' here can.
I'm doing primarily road riding with some dirt trails and gravel. In Maryland, so it can be rolling but no mountains. I don't think I need anything crazy but I would like to be able to spin up inclines rather than grind up them. Would I be better off changing the rings or the cassette?
It sounds like Roadlink only works with medium cage and I have short cage. So if I'm getting a medium cage anyway, can I skip the Roadlink and just put a 11-36t back there? It sounds like others have had success with a 105 GS and this cassette without a Roadlink.
Non omnino gravis
Pick up a 34T for the front, and throw on an 11-32 in the back. Will work fine. Now that I think of it, this is the exact setup on my wife's road bike-- 46/34 with an 11-32, 105 short cage. Will even go full cross-chain without issue, because of the 46T up front.
I don't care for 36T small rings. I got her the 34T Ultegra chainring for like $12.
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1975 Post(s)
Liked 232 Times
36/46 11-28 is perfect cyclocross gearing, which is what the RXM is. You can manage in either ring in tricky situations and anything steeper you should be running, and descending you should be catching your breath and concentrating on a good line. Since you aren't going to be using it for that purpose, the suggestion for a 34T and 11-32 or even an 11-36 is great.
Quoted: 128 Post(s)
Liked 692 Times
Technically there can be issues but a lot of us here have done it without issue, including myself. If you find issue with it for whatever reason then getting a GS rd is like $40 so it's no big deal.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
I’m going 30/46 on the new bike (at least, today), and 11-36 in back.
Some groups that can do this:
r8000 ultegra
r7000 105
4700 tiagra
10 or 11 speed SRAM with the gx 2x10 rear derailleur (99% sure this works with either the newer 11s stuff)
anyway, the r7000 105 rd medium cage should get you to 11-36
r8000 ultegra
r7000 105
4700 tiagra
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Get a 46/30 crank for more range...get a wider cassette if you're willing to sacrifice gear spacing for more range.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Shouldn't be an issue, despite Shimano's specs. I've been running my 5800 short cage RD with 11-32 for about a month now with no problems.
Quoted: 128 Post(s)
Having never changed up my gearing before, what do I need to know about buying a new chain?
Of course, this will have to wait while I see what Raleigh does about the fact that I just noticed my derailleur hanger is bent, and it must have happened in packing/shipping.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Nah any chain you buy at the shop will be long enough. Just do the "run it around the big chainring and biggest cog plus one link" thing like you'd do normally. Go to the Park Tool website or just do a search on youtube for better details.
Liked 692 Times
Mine came bent too. I wouldn't screw around with Raleigh, it's likely to be a waste of time. Besides, what can they actually do? Take it to a shop with the proper tools and get it straightened out. It doesn't take long.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 128 Post(s)
What does a shop charge for straightening a derailleur hanger? Wondering if it would make sense to buy a DAG tool and do it myself and have it on hand for the future.
Liked 692 Times
Let me know if they get back to you. I have been meaning to contact them about getting new wheel bearings. My rear wheel bearings went to crap after only a few hundred miles of good weather riding. Not impressed.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Agreed, don't go 34 in the front. 36->34 chainring is almost trivial. get a 30 to go with your 46. much less overlap too.
Liked 692 Times
Definitely worth the $20. I did it for me, my mom, and my dad and it provided just enough low end with the 34-32 combo to get up the short, steep hills around here without grinding.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 232 Times
You can go the other way too. I swap the 34 for a 36 on a compact crankset on all my road bikes for better front shifting and a more useable small ring usually paired with an 11-28 which makes for close jumps perfect for group riding
Quoted: 128 Post(s)
Is the Shimano 105 5750 34t compatible with my Shimano RS500 crankset? They're both 110 BCD and 5 bolt but it looks like the 5750 is 10-speed?
Quoted: 1218 Post(s)
Liked 298 Times
best "gearing" (for you) is new crank 46/30 and 11-32
best "cost" 'gearing' for you is do the 36 to 34 swap and go 11-32 rear
