Favorite Brompton chain oil
Bikes: 2017 Brompton Nickel H6L Superlight
What's your favourite chain oil? The manual recommends a dry oil with good penetrating properties. So far I've tried the following.
Muc-off C3 Ceramic Wet (used for first part of Autumn/Winter until I switched to dry oil)- made the drive chain a mess over winter very quickly, couldn't change sprocket gears easily by the end of each week. Back pedalling when folding also nearly made the chain come off a few times when it was mucked up. Degreasing was a nightmare.
Muc-off C3 Ceramic Dry - pretty good but washes off easily in the rain. In the dry weather we've had here for a while it has been really good. Off putting a little is the warning about wearing gloves when using it (not always handy when I'm halfway around the country). Bit expensive and comes with a waste of money light for checking the chain when applied (I'd rather not have this and save a few £)
Squirt Dry oil. Seems okay so far, no special "wear gloves" requirement. First week it seemed to come off quickly and noticed a bit of a squeak towards the end of week (note that I had degreased the chain and applied this on clean chain) but I think it's meant to work better as you build up layers. Second week even with a little rain it lasted well all week . Need to continue using it for 3 months at least.
Interested to hear what others use. As mine has to be packed in car for my commute on Monday's *(130 miles - then return on Friday), I like something that's easy to apply, ideally lasts a week even with an occasional rain shower and helps keep the chain fairly clean.
see the 1000 prior 'what chain lube' threads created in , say, the mechanics section..
I use whatever I have handy
keeping it clean and well lubricated is a bit of an oxymoron.*
wipe off the sides of the chain after applying lube to the rollers.
it is the pins and rollers and the bushing surfaces between them that needs lubrication ,
not the outside faces of the plates.
*waxes, a bit cleaner, have been used, melted, but are you willing to take the chain off frequently to do this?
[note the Brompton advantage; when folded, the front wheel covers the drivetrain, well..]
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
Are you applying your Squirt lube and letting it dry overnight? I found if I apply at the end of my ride and let it dry overnight, not only does it remain cleaner it also lasts longer.
Btw....is there something specific about a brompton chain that makes lube unique to it????
Bikes: Brompton, Dahon Vitesse D5
Quoted: 55 Post(s)
Chain-L. It's thick and stays on a long time. I bought a sample pack 4 years ago and I'm still using it, i.e. I still haven't needed to purchase the normal sized bottle.
...Is there something specific about a Brompton chain that makes lube unique to it?
with my 3 speed next cog and chain will be 1/8"..
have an old style 3/32" on it now..
Yet another post pointing to...
...the silo and cult mentality, the La-La Land in which some, though far too many, Brompton owners live. Brompton is alone and above in a class by itself, right? It's no mundane, regular chain. It's a Brompton chain.
Hello
None of your Beeswax
The chain should ONLY be lubricated with Brompton's Beeswax. Use of any other lubricant voids the warranty. Available at your authorized dealer.
To this discussion, perhaps not. But then there is little to add to the tens, perhaps hundreds of threads about chain lubrication on this forum. To the other, long-running discussion, yes. I can understand, though, why my challemge would discomfort you. Over & out.
I always try to remember that participation in all things internet is 100% voluntary.
Nobody forces anybody to read every single thing.
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
As the OP was specifically asking fellow Brompton owners about what they used, Abu's comments were unnecessary, especially as no-one claimed it was a Brompton-made chain, it's merely one that came with the bike.
As mentioned, I use WD 40 which is also a solvent and can be used for cleaning. As it happens, because my Brompton is getting so little use, it hasn't needed oil for months. Having used all sorts of different oils, I think the key is to keep the chain and the derailleurs clean, the oil itself doesn't matter so much.
yes, of course. If a Dahon owner asks other Dahon owners what chain lube to use, no one but Dahon owners may chime in, right? If a Tern owner wants a new wheelset for his rig, only Tern owners may answer. Unless ypu believe Brompton to be on a different league or higher plane. Apologies for barging in on your exclusive club, elitist silo. No one said-including myself- it was a Brompton-made chain. It's called sarcasm, mate.
Quoted: 598 Post(s)
Liked 5 Times
Abu, you did not reply to the questions in the original post, you didn't recommend any type of lubrication, you just went into you usual rant. I don't know why you have this chip on your shoulder, but it is wearing thin.
Recommendations of chain lubricants? There are likely 100s of threads, thousads of posts and recommendations on the subject. Wow, WD40, such an expert you are. What would this channel do without your expert input?
You don't like my spiel, it's growing thin? Put me on your ignore list already. It's really as simple as that, mate.
Quoted: 598 Post(s)
Liked 5 Times
The question was about lubricant for chains, absolutely nothing to do with any phenomenon.
Back on topic - which oil do you use on your Dahon chains, and why?
No, it was actually about Brompton chain oil. Of course, the OP wasn't about the phenmenon itself. As insightful an input as the WD40. Deliberately dense, or outright dim-witted.
Stardust
Hey guys, abu is right. Any oil op wants will do the job in a better or worst ways...and some time after chain will wear and will need to a change. No big deal.
its most overdiscussed topic.
stop harasment against abu.
Quoted: 598 Post(s)
Liked 5 Times
No, abu isn't right. He has a chip on his shoulder which clouds his judgement. Look at his first response, and you'll see what I mean. I also said the oil doesn't matter so much.
This is a harassment free zone .
Once every year or two, I wander into a bike shop and buy some oil. I could wander downstairs and see what brand is on the bottle, but I only bought it because that is what they carried. I put it on my bicycles, folding and non-folding. It seems to work.
Some comments may be snarky, but the subject of "folding oil" might make it too tempting. If I do come across some Vegan Extra-Virgin Folding Bicycle Oil, I will return to this thread and apologize (and share the source.)
Thanks for info
About the question along the lines of "special Brompton oil", there's nothing "superior" thinking in my question so move on . It always amazes me however how that people jump to quick conclusions, make assumptions. The OP (meeeeee) has no idea about other bikes. I do remember a year ago when I bought the bike reading it was galvanised which made me think maybe others are not. So the question was not trying to make it sound special, it was a simple question to put to people from someone who bought a Brompton for commuting but has no idea what chains are on other bikes, if they're any different, but I mentioned "Brompton chain" in case there was a difference.
Someone who doesn't know about car engines might wrongly assume they all use the same oil.
Liked 374 Times
Imo the only time lube matters on a folder is if it is the kind that folds with the chain on the outside - in which case dry wax is probably a better choice as it will be less messy to carry. Since that doesn't apply to bromptons, any decent chain lube will get the job done. I'd say use the one best suited to your weather and call it a day.
