Need suggestions cutting brake housings
Quoted: 366 Post(s)
Liked 275 Times
Suggestions, please. Noobie question.
Last night, I changed out the cables and housings on my 8-year-old daughter's bike, mostly to make them pink, but there were some issues as well.
I'd successfully changed, if I recall correctly, 5 other bike cables in the past year. I use a new Park cable cutter, so I don't figure that is my problem.
Anyhow, the shift cables cut just fine, but I had problems not crushing the thicker short sections of brake housing. I ended up throwing one fresh-cut section away because it had crappy cuts on both ends. I've learned that a bad cut can cause a lot of drag on the cable.
Putting a section of cable into the housing before cutting the housing and cutting both helps substantially. Is that the best practice? How do you make the short sections of housing and then extract the bit of cable left inside if you go that route?
Quoted: 514 Post(s)
Liked 451 Times
Just open up the ends using a pick or awl, and clean up the jaggies with a file, sandpaper, or bench grinder.
Likes For oldbobcat:
Sr Member on Sr bikes
I use my Park cable cutter to cut the housing also (without the cable in it). Then I file the cut to remove and burrs or barbs. Sometimes I use a handheld file. Sometimes I use the grinding wheel.
Dan
Dan
Likes For _ForceD_:
Quoted: 3515 Post(s)
Liked 2,929 Times
Are you suggesting that you cut the cable housing with the cable inside?
Quoted: 626 Post(s)
Liked 401 Times
I use the side cutting pliers for regular brake housing. I use my knipex cable cutters for compressionless housing. I like your idea of shoving in a piece of inner wire for a supported cut to keep the shape of the housing and will try this.
Likes For Rick:
Likes For ScottCommutes:
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Cutting the spiral brake cable housing with my nice Park Tool cutters always left a mangled spur of the spiral metal. I usually try for a fast, hard squeeze on the cutter, instead of a slow cut.
I have a bench grinder, which grinds it flat and perfect in no time. (dip in water to keep it cool so the liner doesn't melt.)
A Dremel or a file works too.
I have a fat sewing needle (maybe for darning?) that opens up the liner hole easily.
Likes For rm -rf:
Likes For choddo:
Likes For Mr. 66:
Clark W. Griswold
Quoted: 4368 Post(s)
Liked 4,008 Times
You wouldn't want to cut the cables and housing together anyway but in this case it can cause more problems. In terms of cutting some cutters will have a awl at the end but you could do it with a separate awl. If you have good housing cutters you are less likely to have to do anything beyond maybe using an awl. Sometimes cutting can not be even so you might need to file it.
Quoted: 541 Post(s)
Liked 416 Times
Despite that Park Tool claims, I only use my CN-10 for cutting shift cables.
Brake housing is a hard spiral code, not like the strands in shift cables.
I don't want to dull my pretty tool that I depend a lot on cutting cables flawlessly.
A grinder makes a flat cut all the time.
Sometimes I use my dremel too when I want a "nicer" cut.
Likes For soyabean:
Liked 2,929 Times
With high quality cutter you shouldn’t have to do that. If absolutely square ends are required you could use a grinder as suggested. I’ve never had such a requirement, personally. I have the Park cutters and they seem sufficient, but I too prefer the older Shimano TL-CT 10. If the internal liner is getting crushed closed, some people use an old spoke sharpened to a point to open up the liner.
Likes For smd4:
Liked 2,929 Times
That definitely isn’t necessary. The housing shouldn’t crush with quality cutters, which should mostly slide between the coils of the housing before slicing through.
Likes For smd4:
Likes For Ryan_M:
Quoted: 514 Post(s)
Liked 451 Times
Never ever cut a new cable before you're finished threading it through everything it needs to be threaded through, and attached it with a pinch bolt. And always cap it when you're done.
Quoted: 1944 Post(s)
Liked 2,167 Times
I’ve moved away from them, but still have some new ones lying around.
John
Liked 2,929 Times
Clark W. Griswold
Liked 4,008 Times
Quoted: 514 Post(s)
Liked 451 Times
My gosh, it's been so long since I've seen those that I forgot they existed. There also were shift cables with different barrel styles on each end. Such were the days.
Liked 2,929 Times
Quoted: 366 Post(s)
Liked 275 Times
Interesting you say that. The cables I installed that got me started on this thread were that exact style where step one is to cut off the style of end you don't want. Seemed like a genius idea to me.
