Dropout adjuster screws, yay or nay?
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I'm pretty sure those little doodads are useful, for some situations, but to me, they just seem to complicate things. I have far better results, when I just remove them, then the rear wheel just aligns itself, every time. Anyone else do this, or am I just a weirdo?
Likes For stardognine:
I've never really used them. I always keep a greased bolt in the hole though, I think they are prone to breaking.
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
Yay!!!
Tune-able chainstays.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
They are useful as you set the axle position relative to the upper pivot bolt of the rear deraillleur, as some RDS shift better with the right distance dialed in.
But once you set it you pretty much "forget it" but when it comes to taking the rear wheel off and back on, you will be sure that the axle is in the right place for best shifting and that your wheel will be straight between the stays.
Likes For Chombi:
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
When changing a wheel in a race, you need speed. Being able to slap the wheel in and go is very important.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
+1 on the derailleur tuning. Vintage derailleurs lack the "B screw" that helps set the chain distance from the top pulley to the cog. You use the axle position in the dropout to decrease the chain gap without hitting the cog and it's set then with the dropout screw.
Likes For poprad:
I like using them, plus I really like the looks. A small part of why I like vintage steel frames.
Semper fi
Semper fi
Quoted: 1609 Post(s)
Liked 2,216 Times
Although I have used bikes without them, usually lower end, I can't imagine not having them. Getting the SS running has reinforced this perspective.
Cyclist
Love them. All my dropouts are usually a little borked, so it makes it easy to center the rear wheel.
Quoted: 659 Post(s)
Liked 595 Times
I find them useful for the tuning of the rear derailleur between using the positioning (as was stated) to the RD and using the B screw. When you use a vintage corncob FW it's important to tune the shifting.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
They're a good way to put correct tension on your SS or IGH chain without fussing with it every time.
Quoted: 4722 Post(s)
Liked 3,039 Times
Adjustment screws were originally developed to compensate for unequal chainstay length. As stated, they also expedite wheel centring when changing wheels, particularly during races. Toying around with them too much can adversely affect derailleur performance, particularly with indexed systems. Consequently, most manufacturers have gone to vertical dropouts which tamperproofs one characteristic critical to optimum shifting performance.
They are something else that the new generation of cyclist haven't got a clue about.
Quoted: 176 Post(s)
Liked 245 Times
I like the look of them and functionality of pulling the wheel right in place but so many times they are a little tweaked when I get a bike. But, recently, I scored this tiny hammer, about 6" long, from Grandpa's old tool stash. I've used it a number of times to gently tap the screws back to straight. I'm sure I'll find other uses but so far, it's the "Dropout Adjuster Screw Straightener." A very specific tool!
The Simplicity of Vintage Cycles
I'm a Classic Man.
Bikes: Anything with a full record group.
The point of having a vintage pedigree is to have it completely dialed in. With-out this specific tune, there are several factors that will cause your bike to ride like a huffy aerowind.
Quoted: 100 Post(s)
Liked 57 Times
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
with a properly dished wheel in there, they can also show if your rear triangle is off center.
Quoted: 4806 Post(s)
Liked 3,933 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Here's one contradictory opinion about horizontal dropouts. They are the one thing that I don't like much about C&V bikes. The plentitude of Campy 1010 type dropouts on vintage bikes is something I have to fight with when trying to fit a larger tire size and fenders on a bike from the decades when horizontal dropouts were de rigueur. They masked unequal length chainstays.
What they do work well for are fixie and IGH conversions. In that case they are an advantage. The ability to adjust chain tension makes them desirable.
Back to the OP's question, if I have a bike with horizontal dropouts, I much prefer them to have adjustment screws for all the reasons others have already stated on this thread.
Quoted: 1324 Post(s)
Liked 927 Times
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 199 Times
Yay
Quoted: 378 Post(s)
Liked 1,410 Times
Not all frames are perfectly aligned for the rear wheel to be dead center just by slamming it up into the dropouts.
Combine that with some QR's that don't always grip, and it's a nice way to stop in your tracks on an uphill climb. If often makes itself apparent much earlier than that, though.
I like being able to put the rear wheel in, back up, and adjust the dropout screws to a nice centered rear wheel.
Plus, they're shiny.
