Crank Position For Photographs
Quoted: 1079 Post(s)
Liked 1,900 Times
When photographing your classic and/or vintage bicycle, what position should the cranks be at?
Let's see what the holy trinity thought.
Bianchi circa 1985 had them aligned with the seat tube (note no bothersome tyre valves):
Colnago circa 1988 had them at 6 o'clock:
Pinarello circa 1985 had them at 2:30:
All with gravity defying pedals that stay upright.
So who was right?
Noting that this is obviously a critically important thread and any incorrect responses will have the poster permanently banned.
So who was right?
Likes For P!N20:
Likes For hose:
Quoted: 3015 Post(s)
Liked 3,805 Times
Should be aligned with chain stay. Seat tube alignment isn't terrible. And at least Bianchi hid the tube valve behind the seat stays & fork blades. I don't know wtf Colnago & Pinarello were thinking.
Likes For iab:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Bikes: 1991 Centurion Oxygen, 1997 Centurion Invincible, 1995+- Fondriest Wind, 1982 Grand Master Nissan Pro 2000, 1992 Olmo Racing (The racing part of the name HAS to be a joke).
Quoted: 34 Post(s)
Liked 30 Times
In my opinion, they cranks should be aligned in a way, that makes it possible to read the writing on the crankarms, if any such writing is present. As an example, a first generation Suntour Superbe crank, should be aligned with the left arm over the chainstay, and the driveside crankarm pointing straight ahead. If for some strange reason the writing is made in such a way, that it is readable with the crankarms pointing forwads on BOTH sides (Stupid!) as Shimano 7100 series Dura Ace, then it should of course be the driveside cranarm that is readable.
Quoted: 472 Post(s)
Liked 1,028 Times
As I don't really care, I usually set the DS crank at about 1:00 as Gazelle did (above). 1:00 since the bikes are in the wild and the NDS pedal is my bike stand, propped on a log or beer can or curb or rock. I then ensure its in bad light, out of focus and neither centered properly nor cropped to fix that. Wadda ell, I am good at mowing the lawn.
Likes For Prowler:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
When people post their bikes here, I don't think I give a hot fudge where the crank arms or valve stems are or even if the picture is drive side out. I usually enjoy the backdrops of where they rode the bike, the perfectly organized home shop or chaotically cluttered basement or garage workbench.
Long story short, someone enjoying their bike is better than trying to recreate a vintage advertisement.
Likes For Chuck M:
Quoted: 1830 Post(s)
Liked 3,382 Times
clearly, the cranks should be aligned with the seat tube!
However, as far as other OCD details are concerned, the valve stem should be at the bottom, wingnuts aligned,and the spokes should be hidden/removed....
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Quoted: 1609 Post(s)
Liked 2,216 Times
OH Fun!
Tire ID should be on the DS and centered on the valve for ease of finding the valve (tubulars don't have an option). If you have colored spokes then the spokes adjacent to the valve should be a contrasting color.
P1030014 on Flickr
Crank position should be with the DS pedal down and the cranks aligned with the ST.
P1030584 on Flickr
We have not discussed where the chain should be! Large ring, middle sprocket, single sprocket bikes excepted!
P1030591 on Flickr
One of the reasons I take so many pictures is that I forget about the "settings!" The order of improvement is cranks, valve stem and now working on the drive train.
Another issues is camera location. I am liking the camera to be in the plane of the top of the tires. Gives you that golden section kinda vibe.
P1030014 on Flickr
P1030584 on Flickr
P1030591 on Flickr
Liked 1,900 Times
Those superconductor rims never really took off.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Wow, and I thought Porsche owners were compulsive about the details!
Best, Ben
Best, Ben
Voltaire
Voltaire
Liked 3,382 Times
but as far as the Schwinn corporate standard for bike photos... there does seem to be a consistent policy, at least based on how my 1976 Schwinn catalog uses the same practices.....
Steve in Peoria
Quoted: 581 Post(s)
Liked 921 Times
If you watch GCN videos you might be led to think this is much more crucial than it really is.
The annoying reality is that half of online ads for used bikes have multiple photos of the all-important non-drive side of the bike, and none of the drivetrain. Cranks not aligned or valves visible? Derailleurs not in 53-11? Not an issue.
Quoted: 969 Post(s)
Liked 1,632 Times
Pedals should always be in a position that allows you to step into them. It just seems to be a more inviting position. Hey... I'm ready... Lets go for a ride...
Likes For zandoval:
Likes For Roger M:
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 377 Post(s)
Liked 1,090 Times
This a most important topic...
I tend to always place mine in what I belive is the most dynamic position - between chainstay and seattube angles. It gives a certain stance and impression of movement - and speed. And when I remember - on the big ring for even more power.
Likes For styggno1:
In a world where drive side pics are rare you are asking a lot!
Be where your feet are.......Lisa Bluder
Liked 2,182 Times
A few other things of note.....TDC with both valves closed, be certain that the timing mark is visible on the balance wheel with the distributor placed correctly, rotor pointing to #1and corresponding wires placed in the recommended firing order. J.A.T.
Best, Ben
Best, Ben
Voltaire
Voltaire
Last edited by xiaoman1; 09-15-21 at 01:01 PM. Reason: Checking for TDC and closed valves ;)
Likes For xiaoman1:
Quoted: 2588 Post(s)
Liked 4,825 Times
Although I usually go with crankarms parallel to the ground, here's a slightly different take:
DD
DD
Likes For Drillium Dude:
Liked 2,182 Times
Ben
Voltaire
Voltaire
Likes For xiaoman1:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
When I'm intentionally staging a bike for a picture, I try to put the cranks at 3 o'clock and position the valve stems according to where I want the tire labels, usually either top center or bottom center. I want to emphasize that I "try" to do this, but I generally fail and don't bother to correct it when I look at the picture and see that I failed, so you get what you get, typically something very slightly, but definitely noticeably, off from what I attempted.
Crank arm at about 3:08, valve stems at 5:53 and 5:46.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 1088 Post(s)
Liked 1,205 Times
I like the idea of the seasoned professional with a set of oral tradition rules and quirky tools going from photo shoot to photo shoot in the early 80's catalog heyday. "Fix the pedals like so, hide the valve stems, and brighten the sidewall." Sort of like the food photographer using a blowtorch to brown the skin on a raw turkey.
Likes For noobinsf:
