TORQUE Based E-Assist with THROTTLE?
Old 08-10-22, 07:06 AM
newbert
Quoted: 47 Post(s)
Liked 17 Times in 16 Posts
I presently ride a Catrike Villager recumbent trike with cadence based e-assist. While I'm very happy with the trike, I find that i'm not as happy with the cadence based system that I have (although I DO like that it has a throttle). So, I'm wondering whether there are any TORQUE-based e-Assist systems that also have a throttle?
If so, could anyone provide some info on it, or a link?
Also, if such a system does exist, would anyone know of a trike shop where I could test-ride such a system, and that would be able to do the conversion of my present system to the new one if I decide to go that route? I live in upstate New York, about 40 miles north of Albany but would be willing to travel to the Hudson Valley, Vermont, Western Mass, and Central NY State - and perhaps even to New Hampshire.
Any info would be appreciated.
Thanks!
Bert
newbert is offline
Old 08-10-22, 07:35 AM
Robert C
Robert C's Avatar
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times in 48 Posts
The TSDZ2 motor allows for both. I don't use it much anymore but I would sometimes use the throttle to boost a little in strong headwinds.
This motor is found on a few low-end eBikes, the type where someone throws some parts on a regular bike and then sells it as an eBike. It is also easily sourced and used on a lot of homemade eBikes. It is a pretty easy system to install. I eventually stopped using it due to the poor performance and I just liked the way the bike I replaced it with looked.
Robert C is offline
Old 08-10-22, 09:07 AM
newbert
Quoted: 47 Post(s)
Thanks for the response, Robert. I never heard of the TSDZ2 motor. But if you experienced poor performance from it (Could you define exactly what you mean?), I doubt that it would interest me. And while it may be considered easy to install, I'm sure it would be hard for me, since I'm "mechanically-challenged".
newbert is offline
Old 08-10-22, 10:04 AM
fooferdoggie
Quoted: 680 Post(s)
Liked 949 Times in 556 Posts
the upper end bafang mid drives will have torque sensing. not sure if the smaller motors do
fooferdoggie is offline
Old 08-10-22, 11:36 AM
Robert C
Robert C's Avatar
Quoted: 363 Post(s)
The BBS02 is cadence sensing instead of torque sensing.
Robert C is offline
Old 08-10-22, 02:57 PM
fooferdoggie
Quoted: 680 Post(s)
looks like this is the only one. I thought more had it Bafang, Ultra Mid Drive
Old 08-11-22, 02:27 PM
mclewis1
Quoted: 8 Post(s)
Liked 28 Times in 20 Posts
Bert, A Grin Cycle Analyst control/display ( https://ebikes.ca/shop/electric-bicy...-analysts.html ) could very likely be added to your existing setup to provide either a power based PAS configuration (which feels MUCH more natural than most other PAS setups) or using one of a wide variety of torque sensors (most are replacements for your bottom bracket). The CA would be placed (electrically) in between your existing controller and the PAS/torque sensor. The CA also handles the throttle input. It basically takes input from a variety of devices, determines what you want to do and outputs a throttle like signal to your existing controller.
Not entirely simple but it would allow you to keep your existing trike setup.
mclewis1 is offline
Old 08-15-22, 08:50 AM
BiciMan
Bikes: '97 Bianchi CDI, '97 Specialized RockHopper, '13 Specialized Sirrus Pro, '13 Trek 8.5 DS, '13 BH EasyMotion NeoXtrem, '14 Trek Domane, '86 Schwinn AirDyne ;)
Quoted: 39 Post(s)
Liked 23 Times in 21 Posts
FWIW, my 2013 BH EasyMotion Neo Xtrem was/is a "TORQUE-based e-Assist (system) that also (has) a throttle"; and I've required nothing else. Good luck in your quest.
BiciMan is offline
