Storing bike with hydraulic brakes
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
I need to store a bike with Shimano GRX brakes. It's most convenient to hang it vertically by the rear wheel. Is this likely to mess up the brakes? I think I've read you shouldn't turn the bike upside down but otherwise I haven't a clue. Thanks.
Likes For headasunder:
Quoted: 559 Post(s)
Liked 648 Times
This will vary greatly on manufacturer and model.
Quoted: 5793 Post(s)
Liked 2,584 Times
There are no guarantees. Even brakes that should not leak might, though most won't.
Rather than worrying possibly needlessly, go ahead and hang the bike, putting a drop cloth below just in case. Then check on it from time to time letting the results guide you for the long term.
FB
Chain-L site
FB
Chain-L site
Expired Member
Liked 5,438 Times
Thanks all, it's hanging.
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
A hydraulic brake system should not have air bubbles in the system, and storage position should not cause new bubbles to form.
Likes For Eric F:
Likes For well biked:
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Yeah if you get air in the system it is likely already there or there is a problem which you will notice. Typically after hanging a while you might need to pump the brakes a bit but they should "spring" back just fine. We hang bikes by the front wheels all the time with disc brakes of varying styles to no issue and at my old shop we had some that could hang for months and be fine.
Likes For veganbikes:
Never had an issue hanging a bike with hydraulic disc by the wheels. As mentioned before several times, if your brakes are soft from hanging, there was air already in the system. Air will always graduate towards the highest point in the system. It's just more notable when a bike is hung.
Likes For frdfandc:
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
I found that after I transported a bike, wiith hydraulic brakes, on its side, I had to bleed the brakes to make it work right. No, it shouldn't have happened, but it did.
Likes For Robert C:
