topeak survival gear box
Halocon
Bikes: Orbea Onix (105)
i was wondering if any of you owns a Topeak survival gear box. i want to know if it has a "5/64" hex. i need it for my brake alignment screw during the rides. and i want to know if the tools inside the box rattles of not during a ride.
Tête de Limace
Don't know if anything in that box rattles, but I have the survival wedge pack and everything fits pretty snug...
as for the thing about wheter it has a 5/64 hex... a 2 second google search will give you the answers you seek... if you find it difficult, here's a shorcut (you click on the previous link, and it'll take you there). If that's too much, it doesn't have a '5/64' in allen wrench
Out of curiosity, what type of bike do you have that doesn't use metric bolts?
Halocon
Keep on climbing
How did you measure this thing to be a 5/64" hex bolt? A little conversion shows that to be almost exactly 2mm, which the Topeak SGB does have. I've never heard of a decent-quality bike (which a Giant OCR certainly is) having non-metric sized bolts. There's a reason all the various multi-tool kits out there use metric-sized wrenches.
Fuji Shill
Bikes: Fuji Roubaix
I had one. There was a lot of stuff in there but the allen wrenches were 50% useless, because they were double sided. If you needed to torque something with the short side, you are screwed.
Get a multi-tool instead. You'll be happier.
And no...nothing rattled around....when I first got it. After it was used for the first time, it was nearly impossible to get everything back into the box due to the way it was stuffed in there. I ended up getting rid of the patch kit (it was junk) and taking the chain tool out.
hello
I bought one back about a dozen years ago (surprising it's still being sold) and haven't really used it all that much. As suggested, you'll be much happier with a mini multi-tool.
Halocon
can you guys recommend me a multi-tool that has the 2mm hex wrench, a flat, and a philips screwdriver as well.
Orbea Crayola Rider
Bikes: '05 Orbea Onix
https://www.topeak.com/2006/products/tools/hexus16.php
mscycler
