Drillium Dude's work, properly displayed
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
Wow!
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Mostly Mischief
That's going to be a shop a few levels above mine...
Now you merely need one or two of embankmentlb's handpainted banners. Another C&V artisan of considerable talent.
my name is Jim
Speechless!
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
+1 I assumed they were polished Bullseye wheels.
Bikes on Flickr
Bikes on Flickr
Quoted: 87 Post(s)
Liked 923 Times
Yeah, he put on the bull's eyes he had that were non-operational. Perfect for this display-only custom. He does some fine work, and once I saw it I knew just setting on a shelf wasn't going to cut it.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
I remember when we had drilled parts mounted on bikes and used them! Course it snowed more back than, everyone walked to school, uphill both ways, gasoline was full of lead and we played with lawn darts.
Nice work and display.....makes me yearn for a bike to drill.
Quoted: 2588 Post(s)
Liked 4,826 Times
^ And we didn't wear helmets when we rode our bikes. In fact, the only kid in the neighborhood who had a helmet was the...
Oops. Don't go there.
Poprad, that display case came out beautifully - the brushed aluminum goes perfectly with the derailleur. But you're too modest; you should relate your talents as regards this particular derailleur! I am still amazed at that story...
DD
DD
Quoted: 87 Post(s)
Liked 923 Times
DD refers to my ham-handed mishap with his creation; despite ordering it as a display-only piece I just had to see if it would articulate. When I tried to move it through the normal range of motion the outer plate which has been so heavily modified bent under the pressure where the spring hits it, literally at a 90 degree angle. Now the spring was wedged into the bend and the whole thing wouldn't move and just looked, well, bizarre. Unfortunatley I didn't take pics.
So, having some exeprience with metal work I decided I had nothing to lose, and that it would likely be going back to DD for repair anyway. I chose to try bending the outer plate back into shape myself. I managed to finagle the spring out of the thing, but now how to make the bend back into the original shape? I used a very small 6" glue clamp, like the kind for glueing woodwork, to ever-so-slowly encourage the metal to bend back. Fortunately for me, the aluminum was ductile enough to accept this without failing and it bent back completely. I was now left with two small bumps on the "rails" of the outer plate where the highest spot had been. To remedy this I took a couple of nesting tire levers, put them through the derailleur sideways with the little high spots right on the bumps, and then used a channel lock pair of pliers to exert enough pressure to flatten the bumps.
At this point the thing looked pretty damn close to what DD had sent me (albeit with some highlight paint loss), but I was worried about putting the spring back in under tension with the now-weakened outer plate. To fix this I cut about 1/16" off the indexing end of the spring, which was enough to allow it to rotate and index against the rivet tunnel instead of the hole it normally inserted into. This effectively reduced the spring tension considerably. All that was left was some minor work with an ignition file and emery cloth, then a bit of detail paint with a perfect match for the orange I found in the nail polish section.
After all that, I wish I had taken a few pics of the process. When the outer plate buckled along the two modified "rails" I thought for sure the thing was toast. Happily Campy used a very soft and forgiving alloy, and it now looks as you see it in the pics, as DD intended. Moral of the story, if you spec something for display only, don't go trying to use it!
I suppose it's all about personal taste and in this area my taste buds are missing.
I do understand the urge to customize things and modify them to serve a need or to gain a cool look.
It was such a cool derailleur stock!
To me drilling out that part is like taking a van Gogh and adding glitter.
Polishing, painting, and framing the undrilled part would make sense to me.
Help me understand why making this part non-functioning is asceticly pleasing.
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
I just noticed Jan's comment & it is true! Fun stuff!
Quoted: 87 Post(s)
Liked 923 Times
That, or he just likes drilling sh*t. Either way, I much prefer to hang DD's derailleur than a huge red dot on a canvas.
Oh, and Jan, I will be doing something like that banner myself when my home shop comes to fruition. I'm somewhat of a rank amateur artist myself, and plan to paint something cycling directly onto the shop wall. Playing with the idea of an iconic B&W TdF type scene with a ghosted Campy logo background, but that's just one idea.
