Chains submerged in Diesel fuel
I use 2 chains SRAM Force 22, alternatively changed after around 1000 km. The latest “used” chain stays submerged in Diesel fuel until the other one reaches 1000 km, then I make the switch. I ride 18-20000 km with a pair of chains (plus other thousands km per year on trainer with a lower-level bike and a third chain). Thus, it is easy to estimate that each chain used for road riding stays totally submerged in Diesel for more than 1.5 years over its useful life.
I heard people saying that a bike chain should not be submerged for a long time in Diesel fuel, due to its corrosive impact. However, I never had issues with this, and the chains look very good even when I retire them.
Thoughts?
Thoughts?
aged to perfection
Quoted: 850 Post(s)
Liked 1,278 Times
I think it's a waste of diesel fuel.
/markp
/markp
Likes For mpetry912:
Why? It takes 250-300 grams of Diesel to submerge a bike chain in a PET bottle. Then, 80-90% of this quantity is reused after the dirt is settled at the bottom. A few kg of Diesel cover many years of chain cleaning. Even the plastic bottle can be reused, if I want to.
Quoted: 982 Post(s)
Liked 587 Times
Diesel fuel is basically kerosene, and is not corrosive to metals. If it were, diesel engines would require a heck of a lot more maintenance. This is consistent with your experience.
Likes For sweeks:
I have a 1 gallon sealed plastic tank of Diesel fuel that I use for cleaning chains. I had forgotten about a chain I dropped in about 2 years ago. Upon remoal it was quite rusted, to the point of being ruined.
I.C.
I.C.
Likes For Insidious C.:
Quoted: 982 Post(s)
Liked 587 Times
Water is denser than diesel fuel, so it sinks to the bottom. The two liquids are immiscible. I'd guess there was some water in the chain when it went into the container.
Likes For sweeks:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 741 Times
do you know why diesel fuel systems have WATER Separators in them?
because diesel fuel almost ALWAYS has WATER in it.
signed: a retired TRACTOR MECHANIC.
to redbullet.
WHY do you soak your chains in diesel fuel?
it is LOUSY as a Lubricant and will move off of most surfaces with gravity assisting.
to redbullet.
to redbullet.
to redbullet.
I use Diesel because it is very easy to shake the bottle with the chain, then simply forget it. The dirt settles at the bottom. No mechanical cleaning needed. Before using the chain, I wipe it with paper towel and leave it in fresh air for 12-24 hours.
Lubricating the chain is another story: I just use PTFE lube. One application is enough for 1000 km of normal riding (that means no rain or mud).
Liked 741 Times
Not sure I understand.
got it.
thanks for clarifying.
i use mineral spirits(AKA: Paint thinner) for grease removal... it's a much more effective cleaner, and the smell is a lot easier to rid from my area too.
PS.. "shaking" is mechanical cleaning
and i hope you're using a plastic container.. i've seen the bottom break out of a glass jar from "shaking" bearings in solvent.
Likes For maddog34:
Quoted: 2333 Post(s)
Liked 2,097 Times
Thoughts?
Why?
Diesel stinks and stains clothing. There are much better alternatives.
Why?
Likes For GhostRider62:
Liked 741 Times
the result may not perfectly fit your chosen description, but the water does mix into the diesel.... diesel with water mixed in turns cloudy in appearance.
I've seen it too many times.
water separators use both gravity and centrifugal force to remove the offending water from diesel fuel.
Quoted: 4474 Post(s)
Liked 1,613 Times
Why not use MEK? It is even worse for your health than diesel. There is no real upside to diesel.
Even really dirty citrus solvent will do a great job cleaning a chain, and you can wash it off with water.
Quoted: 1087 Post(s)
Liked 694 Times
Mineral spirits do a better job of cleaning than diesel fuel or kerosene, and dries cleanly and completely. I soak a new chain in mineral spirits overnight to remove the shipping grease, but I see no reason to store chains submerged in anything.
Likes For Jeff Neese:
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 373 Post(s)
Liked 471 Times
No idea what kind of conditions the OP rides in, but this sounds like a lot of work to squeeze 6,000 miles out of a chain.
I never ever cleaned a chain. Just lube and wipe. And always lightweight KMC or Dura Ace brands to extract over 5,000 each time.
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,111 Times
There are better things.
I’m not sure why in the modern world you’d put diesel anywhere besides the truck’s fuel tank. No one is selling it for any other purpose. To use it on a bike chain you have to decide to be contrary
or desperate
or desperate
Quoted: 983 Post(s)
Liked 1,648 Times
Bravo on diesel as a cleaner. Much safer then gasoline, even if it is more expensive now days...
Used to use it in the Army as a weapons pre-cleaner de-greaser. Of course I don't know if that holds true for modern day weapons made with mystery materials or even modern bikes made of composites.
I consider bike chains a disposable item. Once they get worn I never use them again on bicycles. I just drop them off at our local welding shop where they go in the spare materials bin. There they sit till needed for muffler hangers, bar-b-q pits, field jacks, fence pulleys, and all kinds of stuff. Good steel should not go to waste.
Quoted: 982 Post(s)
Liked 587 Times
HERE and HERE are what two fuel distributors have to say about water in diesel fuel (scroll down a bit on the first site)... which pretty much is what the OP is describing.
EDIT: I was wrong about diesel fuel being the same as kerosene. They are *close* (CLARIFICATION) but not exactly the same.
ignominious poltroon
Quoted: 2255 Post(s)
Liked 3,471 Times
I'll stick with wax.
Quoted: 1147 Post(s)
Liked 1,773 Times
put a teaspoon of water in a cup of diesel...shake well... watch the result.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
OP.
If it works for you that is all that matters.
I’ve never heard of diesel being corrosive.
The one person that said they forgot about the chain and it was rusted probably put a wet chain in the diesel can.
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times
As someone who lives in a rural area and have multiple mowing tractors that run on diesel, hence we have our own dispensing tank, I can relate to using it for degreasing. The idea that you specific-use products for literally everything is utter nonsense. Where do you think these ideas come from ? Those selling you the specific-use products of course ! Hahahahahahaa !!!
Likes For Garthr:
Mad bike riding scientist
Quoted: 6238 Post(s)
Liked 4,246 Times
to redbullet.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,246 Times
Thoughts?
Thoughts?
Stuart Black
Stuart Black
Liked 4,246 Times
Mineral spirits is a good choice because it’s not too flammable, evaporates quickly, is very effective, and is readily and cheaply available.
Stuart Black
Stuart Black
Liked 4,246 Times
This is a process called "emulsification", which happens when two immiscible liquids are shaken together. This might happen in a FUEL system, but not so much in a one-gallon container.
Stuart Black
Stuart Black
