Will Fix-a-flat get you home?
Quoted: 366 Post(s)
Liked 275 Times
I was in Home Depot and noticed the cans of Fix-a-flat. If it is designed to fix up a car tire, it seems like it might fix a flat bike tire pretty easily. Does anyone have experience with this product? It is available in lots of stores. I have tubes and schrader valves on my bike, but I am open to any thoughts.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I think a co2 inflator will take up less room in a saddle bag.
Quoted: 6202 Post(s)
Liked 4,816 Times
Are you having a lot of flats? A new inner tube and CO2 inflator or good frame pump will probably serve you better. There is a limit to how big a hole that stuff can fix. And while a new tube won't fix a tire with a big cut or hole in it, a new tube and a improvised boot will.
Quoted: 823 Post(s)
Liked 1,962 Times
Please do.
We need a pre and post video account of its effectiveness.
Who knows?
For the record, I would not even use this product on a flat car tire without a tube because of the mess it makes and getting a tire shop to patch/plug the puncture will not happen. You will be advised to purchase a new tire.
Who knows?
Quoted: 366 Post(s)
Liked 275 Times
I see Fix-a-flat as a potential emergency solution. Not to carry around, but if you need it, it's available at a big box store, gas station, convenience store - lots of places.
Clark W. Griswold
Quoted: 4369 Post(s)
Liked 4,009 Times
I would recommend first off getting good tires and making sure you have a good rim strip and all of that. Then before my ride I would make sure my tire is properly inflated and in my saddle bag I have a tube and a tire lever (or however many you desire) and a pump or at least some method of inflation. Then I wouldn't worry about messes or gimmicks from a place that doesn't actually deal in bicycles and bicycle equipment on a serious level (yes I know wally-mart sells Bell branded crap and things that look like bikes...)
I have a feeling that if I used that product on a car tire it would be an unmitigated disaster and a huge mess and would cost me more money having to replace the tire or remove it and clean it and all of that it isn't worth it.
Likes For veganbikes:
Quoted: 440 Post(s)
Liked 264 Times
They make a similar product to fix a flat for cycling. I can’t remember the name, sorry
edit to add
sized for cycling
edit to add
sized for cycling
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2592 Post(s)
Liked 5,663 Times
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 122 Post(s)
Liked 222 Times
I used "Slime" filled inner tubes when i lived in goathead infested Bakersfield, Cal. The stuff was great. There were times, mostly in the fall when a fresh crop of goathead thorns littered the roads, when I would get a dozen hypodermic needle sized punctures. "Slime" fixed it in a jiff. It was a life saver. I don't live there now so it is not the issue it was.
Quoted: 18431 Post(s)
Liked 15,585 Times
I'm not having a lot of flats, and I carry spare tubes and a pump. That, as you say, a better solution.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Quoted: 366 Post(s)
Liked 275 Times
I'm not sure why that matters. You flat both tires, your pump breaks, you packed the wrong size spare tube, you can't find the bit of staple because it's cold and dark and you keep getting flats, somebody messed with your stuff - whatever. I can just see a situation where you don't have what you need and you're not close to a bike store, but you are close to someplace that sells Fix-a-flat.
Liked 4,816 Times
Liked 15,585 Times
Heh. I finally figured out what flim clip your post reminds me of.
Quoted: 505 Post(s)
Liked 641 Times
Emergency? near a big box store? I'm sure there is cell service and UBER. I once had to fill a 26x2 tire full of twigs and leaves to get me back from the middle of nowhere (it's amazing how nuch it takes to fill that little void) I tried grass first, but that only made pulpy wheat grass juice after a mile or two.
Likes For wheelreason:
Quoted: 366 Post(s)
Liked 275 Times
I would scrap the tube anyway after a puncture - many don't. The tire isn't likely to be ruined because the gunk is supposed to seal the puncture and stay in the tube. Having never tried it, I don't know. Scrapping a tube isn't a big deal.
Quoted: 505 Post(s)
Liked 641 Times
The issue is that it may or may not seal based on the size and shape of the hole(s) on the tire, and you won't know until you try, and if it doesn't, then what? If you are near a big box (or just as thought experiment), you could use expanding foam, allowing for it to vent, and then trim with a blade, in either case, don't bring it to a LBS after and not mention what you did, makes mechanic turn green and rip out of his clothes.
Clark W. Griswold
Liked 4,009 Times
Liked 15,585 Times
BTW...See edit.
Sunshine
Quoted: 10971 Post(s)
Liked 7,499 Times
Whatever the potential situation may be, a clearly better flat fix solution is to use the finger of a nitrile glove and some tape.
https://www.bikeforums.net/general-c...-patchjob.html
Smart riders that use a sealant in their mountain bike tires also carry a spare tube and a way to inflate it. The sealant can burp and not provide a good seal and the best recourse is to insert a tube and add air. I started with sewup tires but I have always preferred to fix a flat in a hotel room or at my house and not sitting beside the road.
