Good Chain Lube??? Mines WD40. :P
Quoted: 58 Post(s)
Haha, I use WD40. I was looking at Finish Line's Dry stuff. Not sure though. What's good and price conscious?
The WD40 drips all over the rim and frame when things get spinning. Then I have to clean those up afterwards. This happens even if I towel the chain down.
I want something that's not making a splatter mess all over my cleaning work on the bike. LOL
junior
Bikes: 2020 Surly ECR / 2018 Norco Search XR steel gravel bike with GRX / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's)
Quoted: 72 Post(s)
Liked 12 Times
Check with your favorite LBS, and buy from them.
eric/fresno, ca.
eric/fresno, ca.
Quoted: 3352 Post(s)
Liked 1,056 Times
Again WD-40 is NOT a lube. Besides that is it making a mess for you. Just use plain motor oil, Mobil 1 is probably the best.
Likes For rydabent:
I've been using the Finish Line Dry stuff for awhile now. I only use WD40 for cleaning chain prior to re-lubing with the Finish Line- it's definitely less messy than some, seems to work fine.
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
I've been a fan of this:
Eco Sheep Oil
You can get them on Amazon for around $8. Heck, you can even email them to see if they can ship you a free can to try.
I prefer the mountain sheep oil since I ride many gravel trails:
Eco Sheep Oil
Quoted: 6972 Post(s)
Liked 10,970 Times
You can spray WD-40 all over your bike, if you want to. But it's not a lubricant.
Likes For Koyote:
Quoted: 913 Post(s)
Liked 515 Times
You can't make such blanket statements about WD-40 any more, positive or negative. The brand markets dozens of specific use products in addition to the original multi-purpose spray. Including several specific cycling chain lubes. It's all "WD-40".
Likes For FBOATSB:
A chain lube thread. Can't wait to hear all of the new developments and advancements since the last one a few days ago. There should be new sub forum dedicated to chain lube.
Likes For u235:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Well, of course the original WD40 has some lubricant in the formulation, just not much. Better than nothing for some bike applications.
Their line of cycling products - none of which I have tried: https://www.wd40bike.com/
I've used ProGold ProLink Chain Lube for more than a few years.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I've been using my old supply of Motul motorcycle chain lube. It's super tacky and doesn't sling off.
Are bicycle specific chain lubes tacky as well?
Quoted: 1020 Post(s)
Liked 463 Times
On an unrelated note, I am watching the 2019 Paris-Roubaix race.
Phill Ligget, without Paul Sherwen sounds sad. Those two were the Dynamic Duo of cycling broadcasting.
Quoted: 4227 Post(s)
Liked 2,488 Times
I use a mixture of WD 40 and motor oil...or 3-in-1 oil.
As others have said WD-40 is NOT a lubricant. WD = Water Displacement.
I use Tri-Flow on my chain, and Boeshield T-9 everywhere else. It is a "waterproof" lubricant. So I assume it has properties of WD-40, but also with a lubricant. Best of both worlds.
Quoted: 3376 Post(s)
Liked 5,522 Times
And again: WD40 is a brand, not just one product (the penetrating oil).
And it's products include actual lubes made for bicycles: https://www.wd40bike.com/products/
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
Anyway, the bicycle lube market is as big a sham as the gun lube market (and their forums are just as polluted with redundant lube threads, as the bike forums are.) The important thing, with bikes and firearms, is to HAVE some form of an actual lubricant (which, of course, excludes WD40's Original Recipe).
Exactly which one is far less critical, and highly subjective. The tiny $10 bottles of liquid unobtanium from your local bike shop are likely good stuff, but.........they're $10+ bucks, and still not significantly better than most anything else.
For the money, (as mentioned above), it's hard to beat something like Mobil1 automotive oil ( coincidentally, also highly popular with firearm enthusiasts). But in my experience, it tends to sling off pretty badly onto the rim and spokes (though I've yet to try a higher viscosity).
I'm currently still running on a couple old bottles of Pro-Link, but I've also used Tri-Flo, Boeshield, Pedros, Dupont teflon multi-purpose, White Lightining and other dry lubes, etc.etc.etc.etc.
Though I still read these threads, out of some irrepressible streak of masochism, I've grown weary of the endless search for the Holy Grail of bike (and firearm) lubricants, and am content to use pretty much anything that's handy......and cheap..
Likes For Brocephus:
As others have said ...
But , by now the big company wd 40 Corporation. has a broad offering of different products,
https://www.wd40bike.com/products/ including a bike chain lube..
and owns several other companies in addition
such as Carpet Fresh & Lava bar hand soap. for mechanic's grime..
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
Chemically, I would take that “water displacement” with a large grain of salt. Every component of the mixture is hydrophobic. Spraying it on to something that is wet will result in a layer of oil on top of the water. There are lots and lots of other chemicals that would do a far better job of “displacing water”.
Stuart Black
Stuart Black
Quoted: 36 Post(s)
Liked 26 Times
Not that it really matters but did you mean to say Mobil1 transmission fluid? I've never used it for bicycles or firearms (nor will I) but, as you said, it is popular with firearms folks.
Quoted: 4806 Post(s)
Liked 3,932 Times
Sr Member on Sr bikes
Here’s one. It’s not great but is much better than original WD-40, and an actual lube.
Quoted: 1034 Post(s)
Liked 1,292 Times
No, not like Motul motorcycle chain lube. I have some in the garage, but I'd never use it on the bicycle, too tacky and dirt would accumulate too much. It is necessary for motorcycles due to the speed the chain moves, but overkill for bicycles.
Quoted: 302 Post(s)
Liked 136 Times
So, yeah, i was talking about plain (synthetic) motor oil, not transmission fluid. But, both of them are popular as gun lubricants, and presumably would be as effective on bike chains.
Not trying to be argumentative, but I'm curious why you felt compelled to inject the, "nor will I".
Quoted: 302 Post(s)
Liked 136 Times
Yep, I've thought the same thing. I have a can of some highly popular motorcycle chain lube, that i hung on to after selling my motorcycle, intending to try it out as a bicycle chain lube, but then recalled how dry,thick and tacky it got on my Honda XR, and had second thoughts.
Quoted: 663 Post(s)
Liked 496 Times
It may well be that one chain oil is better than others but the main thing, such as in brushing your teeth, the important part of the process is to do it frequently.
