View Poll Results: What PSI would you run? ENVE says 60, Conti says 80-109. Details in first post.
60-64
5
17.86%
65-69
4
14.29%
70-74
5
17.86%
75-79
2
7.14%
80-84
3
10.71%
85-89
2
7.14%
90+
7
25.00%
Voters: 28. You may not vote on this poll
Poll: ENVE says 60psi, Continental says 80-109psi. What to do...
I know. "Test out the different PSIs and ride what feels best for you". That is exactly what I'm doing. Today's ride will be at 70psi. Rode it at 80 the other day. Later on will try 60. But I'm just curious what the rest of you err towards when the recommended psi by the wheel and tire manufacturers are so different.
For background, I've mounted 25c Continental GP5000 TLs on ENVE SES 5.6 wheels on my Cervelo S3. The Conti site for 25c GP5K TLs gives a range of 80-109psi. The ENVE website for the 5.6, with tubeless 25c tires, at my rider weight, gives a recommended pressure of 60psi with the caveat of:
Note: Tire pressures are intended as a starting recommendation based on the listed wheel being set up with tubeless tire. The pressure value is calculated considering a tubeless set up, intended road surface, rider's weight, average bike weight, inner rim width, and tire volume.
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,933 Times
Likes For datlas:
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Throwing more info to the mix, this chart at bottom, from mavic suggests a max of 6.35 bar for a 20c rim (Enve SES5.6), which is about 92psi.
I assume since you're quoting Enve as recommending 60psi, that you are about 150lbs.
It's a conundrum when a tire maker says minimum safe inflation is one thing (80psi), and the rim maker says the max for any weight rider (250lbs on Enve site) can only be 80psi.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Bikes: SL8 Pro, TCR beater
Quoted: 990 Post(s)
Liked 586 Times
Ride whatever pressure that floats your boat As long as your tire isn't underinflated to a point where it'll pinch the rim if you roll over a bump or something... Keep mind that there is an optimized pressure to reduce rolling resistance as well. You just need to find out which one!
Likes For eduskator:
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
No way I'd run 60. That's crazy low.
At 165 lbs, I run a minimum of 90psi for 25s, but I've also pinch flatted numerous times in important situations under 90 psi, so others may have differing experiences. But even with tubeless, I don't go below that as I hate the mushy feeling when standing.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Speaking of manufacturer recommendations, it’s interesting how Conti’s lower psi recommendation for the 5K TL is 65psi for both 28c and 32c sizes but jumps up to 80psi for 25c.
The new 2020 Schwalbe Pro One TL Easy (the one with “souplesse” whatever that means but it is getting good early press) has a 70-110psi range for its 25c size. It drops down to 55-95 for 28c and 55-80 for 30c
I have greatly preferred the GP5K TL to any other tire I’ve ridden (Bontrager, Mavic Yksion UST, grand sport race). But I’m tempted to try out the new Pro Ones when they become more widely available and come down from their $81 per tire price. Seems they’re too new for anyone to mark them down just yet. I pay about $55 per tire for the 5K TL and that’s about right in my view for the price/performance ratio.
Quoted: 20810 Post(s)
Liked 9,456 Times
Quoted: 18382 Post(s)
Liked 4,515 Times
See this thread from earlier this year.
https://www.bikeforums.net/road-cycl...a-dispute.html
I think an issue with at least some of the Enve rims is that they are wide rims, and are designed for use with wide, low pressure tires.
Liked 8,933 Times
Say what you will about the downsides of tubeless, but give the devil his due. Pinch flats don’t happen with them.
Liked 4,515 Times
Not that big of a rock either, but probably rather sharp.
I have wondered if I had let the pressure get too low, and it did, in fact bottom out when I hit the rock causing damage that would not have occurred if I had the pressure higher.
Advocatus Diaboli
Liked 1,533 Times
The ENVEs are optimized for 25c and that's the largest I will mount on them for the foreseeable future for one simple reason: 25c is the widest the S3 will safely accommodate per ISO safety rule of 4mm clearance on each side. And the 25c need to measure pretty close to it to maintain that clearance. Currently my 25c 5K TL measure 25.93 and that leaves about 4mm clearance on one side of the chainstay and about 3.8mm clearance on the other side. If I buy and mount the 25c Pro Ones and they measure large, like 27mm, I'll really be cutting it too close for comfort. However if the new Schwalbes are spec'd for 19mm rims, then hopefully they won't expand too much on a 20mm internal rim width wheel.
Just returned from 20+ miles with the 5K TLs at 70psi...I think I'll keep them there. They're comfortable enough when I roll on bad roads, so I don't feel the need to dip down into the 60s. Might experiment going slightly higher next ride, maybe 75, to see if I gain a little bit in reduced RR without giving up too much comfort.
Quoted: 850 Post(s)
Liked 344 Times
Wait... how heavy are you, OP? 150lbs?
If you have the cojones for it, you can run your tires very, very low. I weigh between 135 and 145 (read: I am fat for now). I use 25mm tires on an ultra wide 23mm rim. With a super supple tires, I run less than 50psi front and 55 psi rear. If I don’t care too much about responsiveness, I’ll go 45psi F and 50R. It’s spooky when I hit potholes or whatever, so I wouldn’t recommend this to anyone in a truly crappy area... but you definitely have room to experiment with. Personally, I think 60F/70R is practically rock hard. I’ve gone as low as 35 psi front (rainy super technical crit. 9 people crashed in a field of ~25. I did not) with no adverse effects.
Jan Heine wrote an article at some point that the “goldilocks” zone that everyone really likes for their tires is actually the slowest because it doesn’t let you float over rough tarmac as with ultra-low pressures, nor do the tires absorb little energy like with rock hard pressures. Try to think to yourself “smoother is faster” and see how low you can go. Bonus if you have a power meter and a calm, flat section of road.
Advocatus Diaboli
Liked 1,533 Times
Why does it seem a bit funny to me to invest in $2500 wheelsets, and then to need to run your nice tires at inflation pressures resembling molasses?
Has there been an updated "15% deflection" or whatnot study using tubeless. Enve says 63psi is optimal for a 150lb rider and 23mm tire running tubeless on asphalt. That just seems kinda weird to me.
Quoted: 850 Post(s)
Liked 344 Times
Nicer tires are nicer regardless of what pressure you run them at, but they broaden the gap when run low.
Likes For Dean V:
Liked 406 Times
Correct...instead of ruining a $5 inner tube...you bottom out and bend or break a rim that costs $100-1,000USD retail plus cost of rebuilding the wheel. Great economy.
Likes For Marcus_Ti:
Advocatus Diaboli
Liked 1,533 Times
https://www.enve.com/en/journal/pinc...mate-buzzkill/
Quoted: 1217 Post(s)
Liked 187 Times
I've pinch flatted two tubeless road tires. It sucks more than tubed tires because pinch flatting a tubeless tire is a terminal event for that tire. Lower pressures + wider rims = much higher propensity to pinch flat regardless of what's inside the tire.
Likes For Spoonrobot:
