Checkpoint=1 Cadence Sensor=0
Love my bike, but hate trying to fit a cadence sensor on it. Won't clear on the cranks, so I read about putting it on the outside of the chain ring. That worked for about 400 miles, but the sensor went adrift somewhere on a bouncy decent this weekend. I'm almost ready to try epoxying it on. I have straps, not laces on the shoes, so that doesn't look like a good option.
What have you found works?
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 272 Post(s)
Liked 243 Times
I run mine (3 of them on 3 bikes) on the non drive crank. Due to clearance, I run them about 1/2" from the bottom bracket.
To be safe, all my sensors (cadence and wheel speed) are attached using either garmin or wahoo mounting system but for added safety, I alway add a cable zip tie all around to secure the lots.
Quoted: 123 Post(s)
Liked 54 Times
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 271 Post(s)
Liked 448 Times
I assume your using the Bontrager Duotrap sensor for speed and cadence that fits in the stay. I have that on my Domane SL. The magnet holders that came with it did not fit and looked unsightly. I used 3M double stick take to attached the the larger magnet to the inside of the crank. Or if you lost the magnet, pickup a rare earth magnet at the store or on the web.
The 3M tape is a gray foam. Thin and comes with red backing. Made for outside use. Attach and trim the excess before removing the red backing. Clean the place you plan to attach. I used painter tape I had to hold it in place and make sure to worked before and attaching. It almost would work just stuck to pedal spindle without the tape.
Here are a couple of pictures. The larger sensor I think is the Garmin attached with double stick tape.
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
I have a cadence sensor happily attached to a crankset spider arm. On the inside of NDS crank the sensor rubbed the chainstay.
Quoted: 271 Post(s)
Liked 448 Times
I see the OPs attached to the chain ring so cannot be the cool 😎 Duotrap. In that case like above says inside the spider if there is room.
My new sensor is IGPSport, and seems a whisker thinner than my dearly departed one. I tucked this one on the NDS arm, almost touching the BB. Just have 10 miles so far, may add some tape, or I am thinking of fabricating a wide rubber band from an old road inner tube for a bit more security, if there's enough clearance. Yeah it's a snug fit. Not near the bike for a picture.
Quoted: 272 Post(s)
Liked 243 Times
obviously, take the pedal off while you fit the sleeve
https://www.ebay.co.uk/itm/203043868...mis&media=COPY
https://www.ebay.co.uk/itm/142449455...mis&media=COPY
Quoted: 2976 Post(s)
Liked 1,182 Times
Likes For prj71:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I zip tie them to my shoes (to the boa straps actually). Since I use multiple bikes, this works great for me.
