89 Schwinn Tempo rear tire max width?
Bikes: Easy Racers Fold Rush 1987 Miyata 215 ST Rans Dynamik 1987 Schwinn Sierra Burley Duet
Quoted: 30 Post(s)
Liked 18 Times
Would anyone be able to tell me the maximum rear tire width that would fit on a 1989 Schwinn Tempo. I am looking to purchase a Tempo but would like to fit it with the maximum width tires front and rear. I am hoping that a 32mm will work.
Thanks!
Thanks!
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,662 Times
I don't think it will fit 32
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
Former Tempo owner here.
27mm is likely the maximum, and only if your rims are absolutely true and hop-free. 32mm might work for the fork, but won't work for the rear triangle.
A friend has a tempo as a beater/commuter. I'm pretty sure they are running cheap 25c nashbar tires (they refuse to buy "nice tires." don't ask, lol.) Most of the "race" frames in that market segment/time period are going to max out at 25mm or 26mm. Any larger, and you risk getting road debris jammed up between your tire and brake caliper. The only way you're going to get 32mm is through a classic touring frame, or a mid-90s hybrid. I'd recommend the latter; there are some hybrid frames that had nicer tubing and more aggressive geometry.
ambulatory senior
Liked 3,662 Times
It might make a nice 650b conversion where you possibly could run 38s.
Likes For 52telecaster:
Quoted: 30 Post(s)
Liked 18 Times
Thank you everybody. Glad I asked.
