Splice cables?
Splice cables?
Old 09-20-23, 08:41 AM
juntjoo
juntjoo's Avatar
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times in 6 Posts
Splice cables?
Anyone here ever use any kind of electrical wire connectors to join pieces of brake and shifter cables?
juntjoo is offline
Old 09-20-23, 08:55 AM
Iride01
Iride01's Avatar
Quoted: 6199 Post(s)
Liked 4,816 Times in 3,323 Posts
For artistic things that don't require the tension a brake lever might put on them? Yes. For things that my life might depend on when I squeeze the brake lever to avoid that Mac Truck at a intersection? No!
Iride01 is offline
Old 09-20-23, 09:07 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
If you're planning to use them for their intended purpose, forget soldering and go straight to welding.
But really, these things are not expensive. Get some tandem length shifter cables if that's what you're dealing with. Or get some cable couplers, like the DaVinci or Jtek to lengthen them even further.
S&S: DaVinci Cable Splitters — TI CYCLES FABRICATION
Shift and Brake Cable Splitters - Co-Motion Cycles
Jtek Cable Splitter (jtekengineering.com)
pdlamb is offline
Old 09-20-23, 11:10 AM
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 538 Post(s)
Liked 1,846 Times in 835 Posts
Cable splitters work well if set up properly, but are much more expensive than long cables.
Crimp connectors might work for shift cables, but as noted above may not be sufficiently fail-safe for brake cables. In either case, I'd replace the cable instead, even if it's an oddball cable such as for old Huret or Suntour X-Press.
RCMoeur is offline
Old 09-20-23, 11:42 AM
pdlamb
I was about to push Submit with a blanket "replace the cable" recommendation, then the thought of something like a tall bike popped into my head. If one tandem length cable won't do it, string two or three of them together!
pdlamb is offline
Likes For pdlamb:
Old 09-20-23, 12:33 PM
squirtdad
squirtdad's Avatar
Quoted: 2339 Post(s)
Liked 2,831 Times in 1,545 Posts
not a good idea, false economy
squirtdad is offline
Old 09-20-23, 12:35 PM
Iride01
Iride01's Avatar
Common electrical cables/wires that you find crimp connectors for aren't meant to have tension loads on them. And they only get crimped in one place. So that is something to consider too for how long you think it'd last with repeated tugging and pulling.
Iride01 is offline
Old 09-20-23, 01:28 PM
Eric F
Habitual User
Eric F's Avatar
Quoted: 4957 Post(s)
Liked 8,100 Times in 3,833 Posts
No, because it’s a bad idea. Electrical wires are designed to carry current, not transfer pulling force. Likewise, with connectors.
Eric F is offline
Old 09-20-23, 01:46 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,933 Times in 2,558 Posts
98% of the sailboats out there have masts held up with steel cables and cable ends that are in effect half of a splice. My two small sailboats used cables with a breaking strength of 2000 lbs. Ends were made with standard telephone linesman nicro presses. Done right, there is absolutely no reason spices cannot be done on brake cables. But - that done right bit is important, even life-saving critical. Before I spliced a brake cable I would learn the breaking strength of a new cable and look up the strength of the slicing method. I would take real pains to do that splice right. And no, I have no idea what couplers are available for brake cable diameter cable. If it is 1/16" I believe there is a common nicropress sleeve and I think my press tool can do it. But I am guessing the brake cable is smaller and I wouldn't use an oversize sleeve! (Haven't thought about rigging a sailboat in many years. That phase of my life is done.)
79pmooney is offline
Likes For 79pmooney:
Old 09-20-23, 02:15 PM
Iride01
Iride01's Avatar
Are you saying a electrical butt splice is good enough to hold the rigging on your sailboat? I don't think they crimped those splices or ends on your standing rigging with just a simple pair of pliers and the pressure you can develop with one hand squeeze. And for certain they were not electrical connectors.
The OP's question was specifically about electrical connectors as the splice connector. If you are recommending the stuff used for boat rigging then maybe it's not apparent in your post. And I don't know of any sail boat rigging that is as small a diameter as shift or brake cable.
I don't think any of us doubt that you can't splice them successfully with splices or connectors made for the purpose. But again, that's not what the OP ask.
Iride01 is offline
Old 09-20-23, 02:17 PM
maddog34
maddog34's Avatar
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times in 534 Posts
the reason we never hear of spliced brake cables is because THE SPLICER DIED while counting on his cable splice to hold.
Get a new, longer cable and live, ok?
See: "Tandem bike brake cable"
maddog34 is offline
Old 09-20-23, 03:20 PM
grumpus
grumpus's Avatar
Quoted: 504 Post(s)
Liked 437 Times in 336 Posts
Why would you want to?
grumpus is offline
Old 09-20-23, 05:27 PM
CliffordK
CliffordK's Avatar
Quoted: 18382 Post(s)
Liked 4,515 Times in 3,355 Posts
I TIG weld my cable ends to keep them from fraying. However, I wouldn't do that for a splice. Too much chance for problems with the weld or heat affected zone. Consider that a cable is dozens or hundreds of really thin wires that need to stay intact.
Keep in mind that modern brake cables are typically larger in diameter than shift cables.
CliffordK is offline
Old 09-20-23, 10:07 PM
kommisar
Quoted: 69 Post(s)
Liked 66 Times in 33 Posts
Sheldon Brown (or John Allen) says splicing a cable is easy and does not require any extra hardware:
https://www.sheldonbrown.com/heroic-repairs.html
scroll down to the "splicing cables" section
kommisar is offline
Likes For kommisar:
Old 09-21-23, 07:13 AM
pdlamb
Definitely Shade Tree Mechanic kind of thing. But you know, that's the kind of entertaining/outrageous/MacGyver thing Sheldon did every so often!
pdlamb is offline
Old 09-21-23, 07:30 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4212 Post(s)
Liked 3,883 Times in 2,318 Posts
Perhaps the second best reply yet. We don't know why the OP is considering this.
One issue with a splice is that it will likely have to be done in situ. Once the cable is joined to another the joint's diameter will likely be greater than that of the base cables and thus not be able to run in housing or through cable stops and adjusters. This is another reason to consider proper cable splitters. Andy
AndrewRStewart
Andrew R Stewart is offline
spclark
spclark's Avatar
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 158 Post(s)
Liked 146 Times in 107 Posts
True, and there are many more out there doing just fine thanks with wire rope splices that are just the two ends being woven together to effect a proper and strong join.
It's a skill, one that takes some practice as well as knowledge about how to accomplish the join in a reliable manner.
Done all the time with traditional (3-strand) and braded rope too, rather than metal strands.
Doing a splice on bicycle brake cable? Why? The stuff's cheap enough, given the risks of splice failure.
I had a small sailboat fifty years ago too. The mast stays were 7x19 SS wire, I had SS turnbuckles on the bottom ends with swaged connections at their upper ends. Those stays were 1/8" dia. wire rope and the swaged connections were about 1-1/2" long.
Elsewhere I had NICOpress connectors where I'd fashioned eyes for connecting wire rope to various hardware too. I did those at home with a visegrip & a couple of nails, never had one fail.
I look upon splicing brake or shifter cable as a fool's gambit, little else.
EDIT - Posted that before reading later comments about Sheldon's emergency repair, the venerable square knot to reconnect two parted cable's ends. That'd work too, an effective means for temporary fix but not something I'd trust for permanence.
spclark is offline
Old 09-21-23, 07:37 AM
spclark
spclark's Avatar
Quoted: 158 Post(s)
Nice skill.
I used to solder mine back 60 years ago, long before I ever knew there were things like (electrical) crimp-connectors or bicycle cable caps. Soldering the cable into a solid made cutting them vastly easier with what I had at hand back then.
spclark is offline
Old 09-21-23, 08:06 AM
_ForceD_
Sr Member on Sr bikes
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 1019 Post(s)
Liked 785 Times in 414 Posts
I wish the OP would respond to let us know why/how they intend to use this spliced cable. For the life of me I can’t imagine (safely) actually using it on bike with the stress put on it from shifting/braking.
Dan
_ForceD_ is offline
Old 09-21-23, 08:25 AM
Steel Charlie
Steel Charlie's Avatar
Quoted: 380 Post(s)
Liked 541 Times in 286 Posts
I say, Go For It ! ! And let us know how it works if you're able.
Steel Charlie is offline
Old 09-21-23, 09:15 AM
juntjoo
juntjoo's Avatar
Quoted: 103 Post(s)
Thanks!
juntjoo is offline
Old 09-21-23, 09:18 AM
juntjoo
juntjoo's Avatar
Quoted: 103 Post(s)
https://a.co/d/dB1GXQ0
These are more what I had in mind.
juntjoo is offline
Old 09-21-23, 09:21 AM
juntjoo
juntjoo's Avatar
Quoted: 103 Post(s)
Dan
Save money. I was hoping there might be a secure method of doing so more so than standard butt connectors or that someone would have a creative idea
juntjoo is offline
Old 09-21-23, 09:26 AM
spclark
spclark's Avatar
Quoted: 158 Post(s)
Be a might capacious for bike cables methinks.
Brakes're what, 0.062" dia.? #10 AWG's 0.102" where 14's closer @ 0.0641 but even that leaves you a couple thou short of snugged set-screws. Shift cables need not apply.
Try one of these instead maybe!
spclark is offline
Old 09-21-23, 09:38 AM
Eric F
Habitual User
Eric F's Avatar
No. Stop. This is a bad idea. These are designed for making a connection between wires for carrying electrical current, NOT for making a secure connection that will withstand repeated pulling forces, including ones that might be necessary to keep you alive.
Also, you're not saving money. Those connectors are more expensive than new cables... https://a.co/d/3rjbYwF
Use the right parts. Your life is worth it.
Eric F is offline
