Totally Tubular
Totally Tubular
Old 02-29-24, 09:08 AM
  #3201
L134
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times in 107 Posts
Originally Posted by pastorbobnlnh
I just checked the pressure after a 20 hour wait. It dropped from 100psi to just below 20psi. So not the valve core.
I'll try to find time today to pull the wheel off, dunk in water to see if a leak is detectable and will add sealant. The current condition of the tread and sidewall doesn't merit a full-blown repair. This tire has given me nine years of use with no issues until now. Tubular life is good!
Another low risk attempt might be to replace the 9 year old core with a new one?
L134 is offline
Old 02-29-24, 11:46 PM
  #3202
seagrade
Making up the numbers
seagrade's Avatar
Quoted: 107 Post(s)
Liked 502 Times in 161 Posts
Couldn’t possibly use anything other than an Italian-made engraver/scriber for keying the tyre bed of my Record Pave rims. Always scribed parallel lines on new rims back in the 80s/90s and never should have neglected that step last year when sandpaper didn’t scratch the surface…
Nothing quite says wall hanger like drillium toe straps
seagrade is offline
Old 03-01-24, 06:56 AM
  #3203
Classtime
Classtime's Avatar
Quoted: 1952 Post(s)
Liked 2,013 Times in 1,112 Posts
^The Horror!
Classtime is offline
Likes For Classtime:
Old 03-01-24, 08:32 AM
  #3204
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1453 Post(s)
Liked 2,196 Times in 963 Posts
Final report on my very slow leaking Schwalbe One tubular:
Sealant took care of the leak. The tire was still holding at 100psi this morning after adding Effetto Mariposa Caffelatex sealant yesterday morning and pumping to the same. Now I just have to ride the Paramount every week to keep the sealant from pooling at the bottom and hardening.
Bob
pastorbobnlnh is offline
Likes For pastorbobnlnh:
Old 03-01-24, 11:51 AM
  #3205
MooneyBloke
MooneyBloke's Avatar
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 228 Post(s)
Liked 294 Times in 161 Posts
Originally Posted by L134
First, make sure the valve core is tight. If that doesn't do it, sealant. I've not had good luck locating a puncture by putting tire in water as the bubbles are really only indicating where the air is escaping from the casing and that may not coincide with where it is escaping the tube.
Interesting. In four decades on sew-ups both garbage and excellent, I've never seen displaced bubbles if the tire is in good shape. The path of least resistance is through the puncture or at least very close. I do pinch the tire to look for tread cuts in the area to be doubly sure though.
MooneyBloke is offline
Old 03-01-24, 11:54 AM
  #3206
MooneyBloke
Quoted: 228 Post(s)
Originally Posted by SJX426
Stick it in water to find the leak. Although I haven't seen a leaky stem, it is worth checking out.
i have seen some slow leaks from punctures that required digging in the tread. Here is an example:
A small vessel of water and dish soap is even better I think. You brush it on generously, and where the air escapes, there is a large and obvious bubble.
Old 03-01-24, 11:56 AM
  #3207
MooneyBloke
Quoted: 228 Post(s)
Nine years?!?!?!?! You're not riding that nearly enough. You should eat a tire in no more than two seasons.
Old 03-01-24, 04:13 PM
  #3208
L134
Quoted: 346 Post(s)
Originally Posted by MooneyBloke
Interesting. In four decades on sew-ups both garbage and excellent, I've never seen a displaced bubbles if the tire is in good shape. The path of least resistance is through the puncture or at least very close. I do pinch the tire to look for tread cuts in the area to be doubly sure though.
I will defer to your far greater experience. Perhaps I had one bad experience and never went back. I do have a tire right now that I could have another go at it with.
L134 is offline
Old 03-04-24, 06:35 PM
  #3209
gaucho777
gaucho777's Avatar
Quoted: 835 Post(s)
Liked 2,135 Times in 558 Posts
I've been riding tubulars since the 80s and I have also experienced what @L134 is describing. Not often, but more than a couple times. I have submerged a tubular to find small bubbles emanating from a general area of the sidewall (say a few inches long), and not always exactly where the puncture is. This seems to me more likely with a well-used tubular, especially when the sidewall has been scuffed in a particular area. Some people apply a sealant such on the sidewalls (I use barge cement on the sidewalls of my Dugast cyclocross tubulars) which might also affect where the bubbles exit. I've also experienced air coming out from the casing in the gap around the valve only to find--after peeling back the base tape and opening up the casing--that the puncture is not at the valve.
gaucho777 is offline
Old 03-04-24, 09:02 PM
  #3210
MooneyBloke
Quoted: 228 Post(s)
A dried out casing may indeed give a false indication, but I try to touch up areas like that with latex emulsion because the bare casing is more prone to abrasion damage. In any case, pinching the tread around the bubbles should give you an idea where the damage lies.
Valve hole bubbling might indeed be displaced, but when I've had that, it was leading to an irreparable failure of the stem on some Vitt CXes.
Old 03-06-24, 09:47 AM
  #3211
obrentharris
obrentharris's Avatar
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times in 1,133 Posts
Please share your source for liquid latex. In decades gone by I used the Jevelot product which came in a small jar that was good for many applications. Alas, Jevelot and Hugh Enochs are no more. I'd appreciate any lead on a substitute. I tried using tire sealant but it didn't adhere as well as my memory of the Jevelot product.
Brent
"I have a tendency to meander sometimes." B.G.
obrentharris is offline
Old 03-06-24, 10:34 AM
  #3212
MooneyBloke
Quoted: 228 Post(s)
Brent
The stuff I use is Val-A Tear Mender which is a light natural latex emulsion much like the Tire Life product.
I also use this to stick the base tape back down after restitching cotton sew-ups. The main issue with either of these is the rather short shelf life once opened; in my experience, the rubber tends to fall out of suspension over time. Evidently carpet layers use some sort of latex emulsion as well, but I've not had any experience here. If you investigate this and can let me know of a good brand, I'd be very interested especially if it's cheaper than the Tear Mender.
Let me state loudly that I've never found a good base tape repair adhesive for Conti Sprinters. Those seem to be a one-and-done tire unless you like riding on dicey base tape.
Likes For MooneyBloke:
Old 03-06-24, 05:31 PM
  #3213
pastorbobnlnh
Freewheel Medic
I finally had a chance to test-ride my sealant filled Schwalbe One tubular. 20 miles and no air loss! The ride also gave me a chance to check the road worthiness of the leather handlebar bag I just completed. More on the new bag can be found in the DIY Bag thread.
As mounted on my '71 P13 Paramount with other leather projects.
Old 03-06-24, 06:26 PM
  #3214
smontanaro
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times in 762 Posts
This was news to me. I couldn't find it with a few searches. Got a link?
Monti Special
smontanaro is offline
Old 03-06-24, 06:56 PM
  #3215
pastorbobnlnh
Freewheel Medic
DYI bag making thread.
Bob
Old 03-07-24, 08:42 AM
  #3216
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
Brent
Here's one option:
https://www.amazon.com/Liquid-Latex-...r_1_18?sr=8-18
JohnDThompson is offline
Likes For JohnDThompson:
Old 03-07-24, 05:38 PM
  #3217
MooneyBloke
Quoted: 228 Post(s)
I suspect theatrical makeup latex would bit a bit too thick much like mold makers latex.
Old 03-07-24, 06:38 PM
  #3218
Biker Pete
Bikes: Kestrel Legend SL, Motobecane Grand Record
Quoted: 74 Post(s)
Liked 104 Times in 45 Posts
Hey, sorry, this question is probably answered somewhere in this long thread, but are 22-23mm silk tubular tires with latex inner tubes for the road still being made? I’m in the US. Thanks in advance.
Biker Pete is offline
Old 03-07-24, 08:39 PM
  #3219
seagrade
seagrade's Avatar
Quoted: 107 Post(s)
Available direct from FMB in France…
https://fm-boyaux.cc/en/route/28-82-.../36-largeur-22
No affiliation.
seagrade is offline
Likes For seagrade:
Old 03-08-24, 07:43 AM
  #3220
Biker Pete
Quoted: 74 Post(s)
No affiliation.
Excellent…….thanks!
Old 03-12-24, 12:56 PM
  #3221
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,827 Times in 1,543 Posts
rene herse has fmb https://www.renehersecycles.com/shop...-700c-x-23-mm/
squirtdad is offline
Old 03-13-24, 04:55 PM
  #3222
Biker Pete
Quoted: 74 Post(s)
Originally Posted by squirtdad
Thank you!
Old 03-23-24, 02:36 PM
  #3223
Biker Pete
Quoted: 74 Post(s)
No affiliation.
Got them, I’ll install them soon!
Likes For Biker Pete:
Old 03-31-24, 07:31 AM
  #3224
Biker Pete
Quoted: 74 Post(s)
No affiliation.
I read on the FMB and René Herse websites that these tires are hand made in a small shop in Brittany, France. Yet on the tires I received directly from FMB there is embossed an inscription in English: “Made in Thailand”. Hmmm.
Old 03-31-24, 02:11 PM
  #3225
Classtime
Classtime's Avatar
Just the tread?
