why in the world would you buy SRAM?
Bikes: s-1
Quoted: 221 Post(s)
so I'm a shimano guy, and I have had lots of fun with microshift and sunrace products mated to my shimano drivetrains.
I have been doing more and more work lately, and some SRAM doubletap stuff has come across my workstand . . .
TERRIBLE
expensive, finicky, not intuitive to adjust, no FD trim (resulting in mega chain rub even 2-3 cogs in), and doubletap has to be the worst designed levers I've ever seen . . . long throw, touchy so you're always missing gears, the ergonomics of the hoods are weird and not human . . . I could go on.
why does anyone like this crap? shimano and shimano compatible sunrace/microsift/etc. parts are cheaper, easier to fit, more intuitive, and except at the extremely high end just as lightweight. what gives?
more important, why can't SRAM get it together, IMO?
TERRIBLE
Quoted: 1438 Post(s)
Liked 1,092 Times
I had a neighbor with an old Jaguar; expensive, finicky, not intuitive to adjust, Lucas electrics(eek!), but he loved it. De gustibus non est disputandum.
Quoted: 2026 Post(s)
Liked 1,096 Times
SRAM developed the "Doubletap" shifting system because Shimano and Campy had all of the better configurations locked up with patents and, obviously, were't willing to license their designs. It was a design of necessity, not choice.
Bikes: s-1
Quoted: 221 Post(s)
Bikes: s-1
Quoted: 221 Post(s)
and if you say it's because shimano has all the patents, then why can companies like microshift make totally novel, and interesting, and functional, and cheap parts, that have good ergo and good durability, and are totally shimano compatible, but SRAM can't?
Hell I haven't needed to "upgrade" in decades, I jumped ship from derailleurs, to IGH..
I leave the trend following to you youngsters..
Latest bike deal ; a Used Bike Friday Tikit with a , yes, SRAM i9 , 9 speed close ratio IGH, grip shifter..
Non omnino gravis
If you're in the select few who are looking for 1X, SRAM is really the only choice. Apex and Rival are inexpensive, and work fantastically well. The Rival 1 RD is light years ahead of Shimano in handling big cogs. As a longtime Shimano user, I thought DoubleTap was going to be finicky, but as of today I have zero complaints.
And at least in my limited case, the SRAM setup was significantly cheaper than a comparable Shimano group.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I have limited exposure to SRAM gear, but I don't find it inferior to Shimano. There are pros and cons, many of which are simply a matter of preference.
Trim is accounted for, either via lever functionality or Yaw.
I actually prefer SRAM lever ergonomics to Shimano, although Campagnolo ErgoPower levers are my favorite.
...but whatever floats your boat. Campy, Shimano, and SRAM all make good stuff. Pick what works best for you.
Quoted: 18378 Post(s)
Liked 4,512 Times
Actually, SRAM owns Sachs, so they should have access to any Sachs technology including their shifters (unless they were licensed copies).
So far, I've used a couple of Shimano shifters, Microshift, and Campy. I haven't tried SRAM shifters, in part because of the double tap. I do use SRAM ferrules.
If SRAM made a 10/24 cassette, I'd love to try it out.
Liked 4,512 Times
Quoted: 440 Post(s)
Liked 264 Times
Why would anyone want to have to use a brake lever to shift? Dumbest design ever thought of.
Truthfully I have SRAM force on one bike and Di2 on another and I like them both and never a problem adjusting the SRAM equipt bike.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
SRAM had used a better, longer cable pull for RDs for ages. Shimano "discovered" it with 10+ speed MTBs and newer (as of Tiagra 4700) 10+ speed road systems. Until then, SRAM was better for that at least - less troubled by derailleur housing and cable imperfections. They still are for systems with up to 10 speeds IMO. Though even Shimano 8 speed and below has enough space between adjacent cogs and enough cable movement, in spite of the same RD movement ratio, for that not to pose a problem. 9 speed being borderline, while (old road) 10 speed being the worst system for that reason.
However, Shimano is still the easiest to source parts where I live, so I stick to it for better or worse.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I try to stay away from dogmas and pick and choose and adapt components to fit my needs. For derailleurs I tend to go with Shimano, as sturdier, but for the main bike I tweak them. For shifters I tend to go with Gripshift because I find them more intuitive and versatile. I can overshift, if I need to, and can constantly toggle between two gears, if I want to. Again, I tweak them to my needs on the main bike, making them skip microshifts I do not use.
Quoted: 1944 Post(s)
Liked 2,164 Times
I know some mountain bikers who love SRAM's higher end gripshift for a 1X setup. I have not used them, but I can see how it could be a lot quicker to dump gears in massive terrain changes. I use Shimano rapid rise with triggers for the same reason.
John
John
Because quality is notably higher.
Nope.
False, adjusts the same way as any other equipment.
A direct lie?
Ham-fisted, poor mechanical skills?
Quite the opposite, DoubleTap is a must.
Huh? SRAM rules it all. Shimano is just... well... cheaper and inferior alternative.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I dunno about SRAM's other stuff, but I am fairly pleased with their chains. Any of the models with chrome-hardened pins just last and last.
Brad
Pokemon Master
My Apex has trim on the FD. IMO, working on both Shimano and SRAM day in and day out, once you get above the super cheap 6, 7, and low end 8 speed stuff, they are pretty interchangeable. SRAM uses a bit more plastic than I like, but I love how solid the brake lever feel is on my Apex bike. You aren't upset at SRAM for the right reasons, though. They just can't compete with Shimano when it comes to hydraulic disc brakes. From the Avid days to today, they just can't get their stuff together and make a decent brake. If it's not porous magnesium, it's the crappy coating they put on the magnesium to keep it from seeping through flaking off because they didn't alter any dimensions to account for the coating. And if the crappy plastic lever internals aren't so loose they blow seals regularly, then they're too tight and seize in their bores when the master cylinder gets hot from being in the sun. And why do they continue to use DOT fluid?! GAH!!
Quoted: 1638 Post(s)
Liked 741 Times
My Red and Rival 10 spd both have trim on the front derailleur. I prefer the hoods on both over Shimano. Double Tap is far superior to swinging the brake lever on a Shimano brifter to change gears.
The ridiculous cable tension required to make the front derailleur function on current Shimano is absurd. Using a little plastic gauge to determine how to attach the cable to begin with??
The current crop of Shimano Road cranksets are the ugliest design I've seen. There are very few bikes out there where it even begins to look like it belongs.
No thanks for Shimano Road. I will keep my SRAM.
nine mile skid on a ten mile ride
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
WTF is going on with that acronym, and HTH do you pronounce it?
(My only genuine objection to them is their hydraulic brakes.)
Originally Posted by Wikipedia
SRAM is an acronym comprising the names of its founders, Scott, Ray, and Sam, (where Ray is the middle name of company head Stan Day).
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Also... Wth is the deal with strawberry ice cream? There's chocolate and vanilla and that ought to be good enough for everybody.
