Aligning Handlebar With Wheels
Quoted: 4396 Post(s)
Liked 1,555 Times
Because the stem is in the way of getting the edge of the square directly over the tire. Viewed from the side, the tire is no longer a straight line but a curve. You can't align a line with a curve.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Hmmm.. I would think the first thing that has to be established, is how do you first determine that the front wheel is pointing straight ahead?
EDIT: and oh yeah.. and do you want your handlebars aligned perfectly if you have an arm-length discrepancy?
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
Looking down from the top, beside the stem, there's barely an inch and a half of space between the edge of the tire and the square's edge, not much parallax, not much curve. Move the square to the other side, then compare the difference. Not much to it.
Use a drywall square, line up long edge along top tube to saddle.
Quoted: 1743 Post(s)
Liked 1,281 Times
I think if you use the method I suggested it doesn't matter if the wheel is pointed straight ahead relative to the frame. If the lengths of string from stem to each hood are equal, the wheel will be "vertical" relative to the bars. By "vertical" I'm really saying 90 degrees.
Liked 1,281 Times
FWIW you can hang the bike from the front wheel and let gravity work for you.
Quoted: 35 Post(s)
Liked 11 Times
last time I set up my road bike I used a 6 ft level, placed it on top of the seat and on the center of the stem
used blocks to align both wheels with the straight edge, then once everything was straight, used another square to the side of the level to get the handle bars straight, and made the seat straight.
once everything was in line, I measured from the front point of the seat to both hoods, and made the two measurements the same.
it was a lot of work, but now everything on the bike is straight, and lined up with the wheels
Quoted: 5224 Post(s)
Liked 3,581 Times
Wifey crashed the other day & twisted her wheel/bar alignment. grabbed the wheel with my knees then firmly gave the bars a quick twist to align them. no back & forth. I'll take another look whenever she gets back on that horse
Liked 1,555 Times
But too much to make a line and a curve parallel. And impractical if your bar has as 31.8 bulge, front or rear cables or any other non-straight shape.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Also, with quill stems I think you'd run into difficulties in keeping the stem at the right height with that method.
Quoted: 622 Post(s)
Me too. I straddle the tire and move it until it looks perfect with one eye closed. I partially tighten it. I get on the bike as best I can in a stationary position and eyeball it with one eye closed, and move it until it looks perfect. I tighten everything down and get on and it's nearly always clearly slightly off. Too slight, I live with it. Not slight enough, I loosen everything and start over.
Liked 1,555 Times
Quoted: 622 Post(s)
I know I mentioned OCD but that's probably a bit of an exaggeration but it just annoys me so thought I'd see if anyone has a simple way of getting it spot on.
Loads of other tips though I've picked up like using one eye instead of 2 so thank you to everyone for their input
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
OMG. I can't believe I'm posting to this one. Seriously, this is so easy. The fork doesn't even have to be in alignment with the frame -- it simply doesn't matter.
Stand over the top tube, look beyond the handlebar down to the front axle, drop out, fender eyelet, whatever. Align the bar evenly (parallel) with the farthest point you can visualize on the fork. Done. It helps if you use one eye and make sure the bar is parallel looking down from each side of the stem.
-Kedosto
(slightly off parallel to the left because my left arm is slightly shorter than my right)
-Kedosto
[QUOTE=Kedosto;20432665] it simply doesn't matter.
/QUOTE]
F**&-g does when you're OCD about it
/QUOTE]
I use one of those park tool handlebar holder thingies. You know, so the bars don't swing when you're working on your bike. That aligns the handlebars to the frame, then I align the wheel to the frame by touch. Meaning actually feeling with my fingers that it's centered on the down tube. No parallax error, no monkeying around. Takes 2 seconds.
Farmer tan
It's so simple, I can get it right with both eyes closed.
However, I do have a 6ft straightedge I place against both wheels simultaneously to check their alignment after tightening the QR. Sometimes they're not aligned on their own.
Quoted: 1607 Post(s)
Liked 2,216 Times
Incredible thread! So many solutions to such a simple adjustment! I am surprised one doesn't include a transit, though the laser was close!
I always eyeball. If this doesn't work, take off your front wheel, brace a straight edge against the front of your fork blades, sight down your handlebars to the straight edge, align the tops of the bars with the straight edge with one eye closed, job done.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
That I find is the key for me- your hands AND your eyes working together will tell you when you start to move it whether it's equal or not. Then loosen, fine tune, try again, crank it down. Maybe not 100%, but functionally usable and if not wanting to use a string method kind of measurement as mentioned above, this will essentially do it.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
As for the handlebars, I used to think I did a pretty good job by eye but it turns out I’ve got astigmatism. So here’s a countervailing theory. Is it important that it be perfect?
