Bike touring with a trailer?
#51
Harsh Adventurer
I recently replace my beloved 2010 Trek 520, with 46,000 miles on it, with a CO-OP ADV 1.1, which I hope to continue to tour with. I only have about 1000 miles on it now, but I REALLY like it. It's a bicycle designed and built with touring in mind. Best value I could find after quite a bit of research. Hope your son enjoys his.
#52
I used an ExtraWheel trailer for 500+ miles in Alaska, on both paved and gravel roads. I have nothing but good things to say about the trailer. If your bike doesn't like the extra weight of racks and panniers, you might consider the ExtraWheel trailer instead of buying a dedicated touring bike that can haul your luggage on the bike's racks.
#53
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
#54
My daughter and I used a BOB trailer for several multi-week trips on our tandem, including a coast-to-coast ride. They are not cheap new, but you might be able to get a good deal on a used one. They track wonderfully. On climbs, you know they are there, but that is their one drawback.
#55
Harsh Adventurer
I am not sure I would own one if I had to pay retail, but given the quality and durability of the BOB YAK, I would have no hesitation with a used one.
#56
I don't personally tour with a trailer for a variety of reasons. Currently I pack light enough that most trailers weigh empty as much as my total base gear weight. When I packed heavier I chose panniers instead of a trailer. That said I have used trailers to haul heavy stuff around town.
I owned a one wheel trailer like the BoB and found the handling fine. Handling wise it was almost like it wasn't there. Weight wise... Well weight is always weight. I wouldn't want to go single tracking with the trailer, but, it would be nice to be able to quickly disconnect the load to go explore some single track.
I currently own a two wheel trailer. A cheap nashbar one. It hauls stuff like groceries fine. It also works as a garden cart. I could see someone happily touring with one. Again it weighs as much empty as my total base gear weight so it isn't for my current style of touring.
Trailers can be great for someone who wants to carry a lot on a bike that isn't up to the load. As I mentioned they can also carry a load on a mountain bike and allow you to disconnect the load for some quick single tracking. I can see someone using one for those and maybe other reasons. Me, I am not too likely to use a trailer for touring unless I were to want to do some very different style of touring than I have been doing in recent years.
#57
Quoted: 605 Post(s)
Liked 285 Times
This is an interesting single wheel bike trailer. Has anyone had any experience with these Maya Cycle trailers? Comes with a kickstand, turns itself into a "wheelbarrow" and is only $219 with dry bag.
https://www.mayacycle.com/bike-trail...icycle-trailer
#58
When you add in the weight differences between those two types of bikes, you get a weight advantage on the trailer as well as significant aero advantage with a very slight (as to be almost insignificant) increase in rolling resistance from an additional lightly loaded tire or two.
When you then look at buying a full on touring bike too, then the cost equation goes from even to way tipped in favor of a trailer.
#59
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 188 Post(s)
Liked 103 Times
KFC, my wife and I are working on a tour using our tandem, we like the idea of a trailer to get weight off the rear wheel. I found a BOB trailer for sale in our area and picked it up for $70 so a similar deal to what you paid. It is one is the older design, which I think yours is too, which has a little different configuration for the cotter pin. Mine trailer did not come with the pins our quick release, I've gotten a quick release in the tandem sizing so that's good. Now what I'm trying to figure out is how the cotter pins fasten, I picked up a few from home depot which look to be correct size. If you wouldn't mind, could you snap a picture of how they attach to the BOB specific quick release? The fork ends of the trailer have holes drilled but I'm not sure I'm seeing how to fasten things. Thanks in advance for any help you can provide.
Likes For Paul J:
#60
Quoted: 188 Post(s)
Liked 103 Times
KFC, my wife and I are working on a tour using our tandem, we like the idea of a trailer to get weight off the rear wheel. I found a BOB trailer for sale in our area and picked it up for $70 so a similar deal to what you paid, mine included the dry bag which is black rather then the current yellow. It is one is the older design, which I think yours is too, which has a little different configuration for the cotter pin. Mine trailer did not come with the pins our quick release, I've gotten a quick release in the tandem sizing so that's good. Now what I'm trying to figure out is how the cotter pins fasten, I picked up a few from home depot which look to be correct size. If you wouldn't mind, could you snap a picture of how they attach to the BOB specific quick release? The fork ends of the trailer have holes drilled but I'm not sure I'm seeing how to fasten things. Thanks in advance for any help you can provide.
#61
Harsh Adventurer
I too, purchased my 'cotter pins' at Home Depot. I recommend stainless steal. I keep the pins attached to the trailer with a lanyard and always carry a spare set while on tour.
#62
Quoted: 188 Post(s)
Liked 103 Times
Hi Paul - I am happy to post a picture of my trailer attached to the QR skewer. I am out on the rode today and tomorrow, but I should be home (where the trailer is) on Thursday. I hope that is not too late.
#63
Quoted: 18483 Post(s)
Liked 15,776 Times
I crossed the country with a small group in 1999. A few had BOBs. Back then, the pins did not have rubber attachments to secure them to the frame in case they popped out or you removed them and dropped them, like the newer models. One guy tied pink day Glo ribbons on his pins in case they came out in order to make them more easy to locate.
Likes For indyfabz:
#64
Quoted: 3483 Post(s)
Liked 1,481 Times
Many hardware stores have a generic selection of pins like that old style pin. My Yakima bike rack that mounts on the receiver hitch has a similar pin, as does the carrying yoke for my solo canoe. It took me several tries on google to come up with a name.
https://en.wikipedia.org/wiki/R-clip
But that one for the trailer has an unusually large spring, that might not be stocked at most hardware stores.
Another name is "hitch clip pin"
#65
Bikes: Trek: 7200 > 7.2 FX > FX 4 Sport
Liked 28 Times
I have had the Maya single wheeled trailer for about a year and absolutely love it. Tracks great and as long as the load is balanced you almost dont know its there!
If you go that route be sure they include the "improved axle". It looks much easier to work with than the original.
#66
Harsh Adventurer
I am so sorry for the delay in getting this to you. I have been organizing a tour and it wasn't until I check the trailer that my ageing memory got jogged. Please let me know if I can be of any assistance.
Stay SAfe...
/kfc
Stay SAfe...
/kfc
Likes For KFC:
#67
Isn't that upside down @KFC? I believe the cradle of clip snaps OVER the allen key nut on end of skewer to lock it in. See my photo/sketch at post 64 above. That photo is from BOB and it shows the big loop facing upward. I could be wrong. It's been a long time since I had that old clip so my memory may be bad. Try inserting yours my way and see if it works better.
#68
I bought a Circe Atlas Folding Trailer which assembles without tools and folds down into it's own small carry bag when not in use.
The MRSP was £199 and I bought mine for £150 which I considered to be excellent value for such a well designed and manufactured, high quality trailer.
I specifically wanted a folding bicycle trailer to go with my folding bike and the Circe Atlas had excellent reviews and there's a great video of it on YouTube which shows the simple, fast assembly.
If I ever lost mine I'd replace it with another in a heartbeat!
#70
Harsh Adventurer
[QUOTE=BobG;21574839]Isn't that upside down @KFC? I believe the cradle of clip snaps OVER the allen key nut on end of skewer to lock it in. See my photo/sketch at post 64 above. That photo is from BOB and it shows the big loop facing upward. I could be wrong. It's been a long time since I had that old clip so my memory may be bad. Try inserting yours my way and see if it works better.
I don't think so. I bought my trailer second hand and it came without the clips, which I subsequently ordered from 'BOBGEAR'. The picture shows the only way I can install the clips. I tried to insert the clips the way you show and they will not go. I designed the length of the straps I use to secure the clips so that you have to actually stretch the strap to get the pins in or out. Having said that I have toured over 2000 miles with this trailer, in all types of terrain and have never had a problem with the trailer detaching or the pins getting loose.
#71
Quoted: 188 Post(s)
Liked 103 Times
Thanks so much!
[QUOTE=KFC;21577097]
This discussion was exactly why I had asked KFC for the picture. The way the picture above shows with the two different clips, I couldn't get it to work as there was no way you would get the curvy wire into the holes. So that was why I had asked for these pictures. Thanks again KFC for the picture! If someone does see a way to attach the other way please chime in. :-)
#72
@Paul J- If you PM me with your mailing address I'll send you several of the newer style pins with lanyard for the price of postage. I have ten of them sitting on my basement shelf. If you're handy you could drill a hole at the right spot on your old dropout and attach small bolts spaced out a bit to serve as the peg should your HD pins not fit.
Apparently KFC is right about how the old style attaches. It's been 25 years since I had that one. I wasn't trying to put the curvy side through in my sketch. I was thinking it went above the skewer nut, with cradle locked over nut with the straight side through the holes.
#73
NB: the piece in # 71 is common, not unique to BoB trailers, They got the one seen in # 64 made for themselves ..
#74
Yep, KFC is right, I was wrong. And Paul J, a Home Depot pin (pictured below just for a test) fits my newer style BOB well. That said, the diameter is ever so slightly larger than the original pin. I drilled out the holes with a 7/64 bit to make it fit. The cradle snaps right over the rearward part of my more pointed drop out. My trailer is retired, I was just curious.
HD pin in newer style BOB dropout
Last edited by BobG; 07-10-20 at 05:33 AM. Reason: original erroneous post deleted
#75
Quoted: 188 Post(s)
Liked 103 Times
