C&V people indoors.....and the arms race rant.
#102
Quoted: 378 Post(s)
Liked 1,409 Times
Saw a CL post today for “free motion rollers”. Has anyone tried this? I am not inclined to increase the roller footprint, but I like the concept. Lots of other examples on YouTube.
https://www.google.com/amp/s/www.ins...famp_page=true
Period.
Inside Ride are very good.
I think Tacx has come out with some.
I found another set of the Inside Ride here for sale, and they’re burning a hole in my mind.
#103
Ok, my curiosity was running wild and I had some old skate wheels from the 80’s, and a garage full of woodworking tools. Here’s the result.
It works fine. The travel when I ride them is minimal - maybe 1/4” back and forth. Probably around an inch when I stand. But it feels like enough to make a difference. I don’t feel it in my quads as much when I stand, and first impression is there is less “roller fatigue”. A pretty simple project. Btw I noticed while I was riding that none of the four center wheels were in contact with the rails, so I removed them.
#105
Quoted: 378 Post(s)
Liked 1,409 Times
So if anyone feels so inclined...
#106
Quoted: 3241 Post(s)
Liked 2,512 Times
Sweet looking DYI examples. Do you need a preexisting set of rollers? I don't see any instructions for making your own.
#107
I had the rollers (a cheap Performance unit), and I had the skate wheels, but you can find cheap sets on eBay. I took the rollers apart and drilled for the wheel bolts on a drill press, but you wouldn’t have to do that - a hand drill would work fine.
#108
Liked 2,512 Times
I posted an Instructable link at #100. But the one I made is simpler. I just used 2x4 lumber, ripped it to about 2” on a table saw, and made a simple frame. The 2” height is just tall enough to get the roller legs off the floor. The plywood on the ends adds a bit of structural stability and gave me room to attach the tie downs for bungies. That’s it for the frame. The length is 6-1/2’, which is what I saw suggested on a couple videos.
#109
Quoted: 1829 Post(s)
Liked 3,376 Times
Are people flinging their weight fore and aft and coming off of the rollers, and this makes it less likely?
Or is there something else going on?
Steve in Peoria
#110
I've ridden rollers enough to ride no-hands, etc., and I'm scratching my head trying to figure out what the benefit of the extra complexity is.
Steve in Peoria
Steve in Peoria
The effect is pretty subtle. The wheels are just rocking back and forth a few degrees, for the most part. The only time I feel a substantial difference is standing, which always felt a tad sketchy on stationary rollers.
So I wouldn’t call it a must-do game changer, but it does feel like incremental improvement. Ymmv.
#112
Liked 3,376 Times
I was like you, which is why I decided to try it. I already had most of the bits on hand and it was an easy evening’s work.
... but why would you stand while riding rollers?.... and I'm pretty sure the answer isn't "to get over the next hill".
I honestly don't recall ever standing while riding rollers, but perhaps I did??
Steve in Peoria
#113
My rear is much happier when I stand occasionally, if only briefly.
#114
Liked 2,512 Times
#116
Quoted: 472 Post(s)
Liked 1,028 Times
An example of simplicity but these rollers are suitable for purpose. I ride these for bike handling skills - improve how smooth my pedaling is, increase comfort with higher cadences, apply power throughout the crank cycle, and maintain a steady line. These are the advertised benefits and I think I do actually get those. I'm sure it's all developing muscle memory that I can use on the street. Cardio is not bad either and, of course, just sitting the saddle and leaning on the bars prevents those very painful restarts in the spring if I just do nuttin all winter.
This roller set is an old Kreitler all aluminum 4" unit. I have the front set just ahead of the axle. I built the step platform you see in the center so start/stop is easy. I developed a way to "lock" the sliding door in place to provide a bump stop on that side and the door jam is the right bump stop. No reason not to use these as falling from a bike that's 6 inches higher off the ground than normal is not what I need. I obtained a separate 700c wheel and adjusted the OLD so it slides right into the DOs for the winter. An old worn road tire is also good enough. I never see any scrubbed off rubber on the floor.
As mentioned above, staring ahead of the bike is important to me. I have a dot on the wall about 12 feet ahead of the front wheel and I start out staring at that and concentrating. After a few minutes I can let my gaze wander but I start with a fixed stare. CD playing loud. Crank away smoothly for 6 or 7 tunes then call it quits. Neither my shop nor that dark room behind the bike is heated so I don't need a fan. I need to cycle to stay warm. This all goes back into storage come April.
#117
Quoted: 111 Post(s)
Liked 213 Times
I haven't put up the trainer yet. I stopped riding outside three weeks ago after the first layer of road salt was applied.
Since then I've been walking everyday.
Found twenty $ in the road this morning, so that's going towards some new tires.
#118
Quoted: 4236 Post(s)
Liked 2,949 Times
This is my zwifting setup (excuse the mess):
A projector is displaying the Zwift on a wall ~15-20' away.
