LeMond Nevada City is a good value?
Quoted: 7 Post(s)
There is a LeMond Nevada City 53" being offered for $400 near me and I am considering it.
I'm curious to know more about the frame and if it is a good value? Can anyone tell me more about these frames and if they are a good value? Anything about the frame geometry?
I would have liked to post a picture but the forum won't allow me because I am too new on here. :/
Still any help would be greatly appreciated.
Thanks!
Thanks!
Quoted: 7 Post(s)
Thanks!
Thanks!
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,568 Times
Thread moved from C&V to C&V Appraisals.
Please do not make junk posts just to get to 10. They will be deleted.
Likes For cb400bill:
Quoted: 7 Post(s)
cb400bill is there any way that I can post a picture. It's not really possible to ask the question that I would like to ask without being able to post a picture...
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
ezmiller, maybe tell us a bit more about the bike as you see it. And where are you located?
Quoted: 586 Post(s)
Liked 612 Times
Quoted: 7 Post(s)
High quality Reynolds 853 steel tubing. Ready to ride triple crank road bike by lemond. 53cm frame originally from Greggs. I have the owners manual if you want it. Shifters are sora brifters. Compare this to a new steel bike like surly crosscheck or specialized and see the savings. Bike fits people 5'6" and taller best. 52cm 53cm 54cm
Thought somebody here might know about the model, and when it might have been made.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,178 Times
OP there is a lot of information on the bike if you search the web
https://products.roadbikereview.com/...ty-290574.html
https://www.bikeforums.net/classic-v...vada-city.html
Voltaire
Voltaire
Likes For xiaoman1:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 809 Times
If it's dark blue it's a 2001, if silver it's a 2002.
2003 was a black bike with 520 tubing. 2004 was blue with white decals and aluminum tubing.
If it's an '01 or '02, then the frame makes it a fairly desirable bike(853 main tubes, 525 stays). $400, I'd think, is about a max value, depending on condition, wheels...location matters.
Quoted: 759 Post(s)
Liked 809 Times
Has a steel fork..(nothing wrong with that) rather than the carbon fork that the higher end models had. The geometry should be the same as the higher end models. 853 "designer select" tubing seems the same as the second-tier buenos aires. Overall..it should ride very nice. A Zurich (top tier model) would run $500-$700 depending on condition and reality-state of the seller. Lots of ebay examples can be more$$..but there's less reality on ebay.
Bikes: Specialized Allez Pro(2003); 1994 Cannondale R 800
Quoted: 5 Post(s)
Liked 12 Times
Have you checked this site: Untitled Document It gives catalogs for all the years they were made. Lots of useful info.
For what an opinion is worth, it does not matter much whether it is 400 or 500 dollars; it depends where you live; what the market is like; and most importantly, what you want. I bought a 2003 Buenos Aires with full ultegra groupset in pretty good shape for $425 six months ago; I thought it was a great deal. I have been trying to sell it for a few bucks more and have not had a bite. The seller of my bike happened to find a guy who wanted a Lemond so it was well worth it to me. I have not. I think I will just keep it even though I found a bike a like even more, mostly because it is still a very cool bike.
Bill McKay
Bill McKay
Quoted: 7 Post(s)
I bought the bike for $370. I rode it and it felt good. Needs a cleanup, but the shifting and breaks felt pretty good. The paint job has some blemishes in spots, which is too bad but maybe not surprising. Now I'm curious what kind of improvements could be made. I'm wondering if it makes sense to upgrade the components and wheels to more modern components.
I'm curious how people here might approach making improvements or fixing up a bike like this...
velo-dilettante
Quoted: 1627 Post(s)
Liked 3,113 Times
lemonds from that era tended to ride a little more relaxed seat post was a little more set back so instead of pushing directly down on the pedals,
you pushed down and forwards to take advantage of (different) muscles differently.
you could spread/cold set the rear triangle to accommodate a bigger cassette/gear range if you're going to do hills, tour, etc.
really just depends on the riding you're planning on doing/is readily available to you. whatever keeps you returning to the bike is the key.
the goal is to avoid it, and you, collecting dust and cobwebs.
Quoted: 759 Post(s)
Liked 809 Times
$370 is reasonable. It's a nice ride by any measure. Good tires are always worthwhile investment. Mount the widest, fastest tire you can get on there. I can't see the what the wheels are. Even a nicely decent new set of wheels will run as much as you paid for the bike..and you may not(probably won't) feel much of a difference.
The most significant differences between this bike and a couple levels up are lighter wheels, carbon fork, and groupset. I personally have nothing against a good steel fork. The groupset you have will be heavier than 105, Ultegra, or DA, but if what you have works well(and it likely does) then any changes will offer very marginal improvements.
If you dropped a significant amount in upgrades ($1K or more) you'd notice it initially, but then you'd do better to have spent more than $1400 to begin with.
Tune it up as needed(derailleur adjustment, cables, brake pads, true the wheels), put good tires on it and ride it.
Quoted: 789 Post(s)
Liked 1,739 Times
Quoted: 7 Post(s)
In terms of other improvements, my thought was in part to use this bike to learn some stuff about bike maintenance and building. So I wouldn't mind putting some money into it. Upgrading or renewing the wheels seems like it could be a good place to start. I suppose swapping or renewing the groupset would be a bigger lift.
Any suggestions on where to focus if I did want to spend a bit o money / time on making this bike markedly better? I'm also curious how to think about making it better? With a bike like this, from 2001, does it make sense to put newer components on it because of improved tech? Or does it make more sense to improve it within the set of components that would have been available in 2001, for example maybe looking at the higher end versions of the frame and trying to find some of those components to put on the bike?
