Component set from '72 Raleigh: Simplex, Nervar, Carlton hoods, etc.
"SURE!"
Quoted: 65 Post(s)
Liked 56 Times
All this came off a shockingly crusty 1972 Raleigh. Everything metal here still works, but anything plastic is not to be trusted. I nudged the left/front shifter lever wrong and it cracked. The brake hoods are surprisingly pliable, but I don't recommend trying to remove them from the levers.
Nervar cottered cranks with pedals and the bottom bracket. I have the cotter pins, but the threads are messed up. One pedal clip missing.
Weinmann brake levers w/Carlton hoods, and Weinmann calipers. Calipers are extra tasty crusty, but work.
Suntour V-GT Luxe RD, Simplex FD, Simplex shifters. The plastic ring on the FD and front/left shifter lever are cracked.
Stem.
Sold as a lot, no picking. Pick what you want, $25 + shipping, CONUS only.
Stem.
Last edited by cog_nate; 04-13-21 at 08:17 AM. Reason: Price drop, minor change to ad, spelling correction
Likes For cog_nate:
Quoted: 4512 Post(s)
Liked 6,382 Times
Those hoods and levers should be worth $30 alone, pretty hard to find the hoods if you want a set.
