Tire Width Myths
Tire Width Myths
https://www.renehersecycles.com/bq-tire-test-results/
Pretty interesting read.
This comes after a long (and friendly) debate with my local Trek store manager. After throwing Aeolus Pro 37s on my Checkpoint SL6 for better road days he was pretty passionate about the 44mm extralight supple tires.
I've been back/forth thinking I was silly for this setup when the general forums and friends vibe is "put 28mms on your road bike" But I found the article quite convincing. I did buy some Conti GT5000s in 32 and 28 to compare but while they're being shipped figured I'd turn it over to the community for thoughts since much of it is above my head.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
The current belief that fat tires at low pressure have 'almost' the same rolling resistance as skinnier hard tires is 100%BS.
Yan is selling superb fat tires at high prices - you need alternative facts to do that with a straight face when talking rolling resistance.
Gravel riding = fat tires help with control on descents or if the gravel is thick, soft surface, etc
Off road = fat and soft absorb bumps which IS a big advantage.
That's why my mtn bike is a rigid, cross country style.
Likes For Wildwood:
Quoted: 6193 Post(s)
Liked 4,809 Times
You should try tires out for yourself and see what they do for you. Run them at different PSI's and note your perceived effort and your actual ride metrics over the course of your experience with those tires. If that is till they wear out, that's fine. When you put another tire on there start all over with your perceptions, ride metrics and eventually you won't have to ask others what you should do.
Likes For Iride01:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
The "alternative facts" in this case are backed up by data that contradict the functional equivalent of fakebook rumors and old wives' tales.
There are some very worthwile threads here on Compass/Rene Herse tires.
I am pleasantly surprised to hear that a Trek dealer would advocate for them.
Likes For Cyclist0108:
Quoted: 6963 Post(s)
Liked 10,963 Times
I've been back/forth thinking I'm a fool for this setup, or maybe I was upsold yada so I did buy some Conti GT5000s in 32 and 28 to eventually compare but in the meantime he sent me this pretty convincing argument.
Figured I'd turn it over to the community for thoughts since much of it is above my head.
Randomhead
Liked 3,696 Times
Many of the guys I can't keep up with on long distance rides use RH tires. I don't think it's the tires making them faster, but it could be. Jan is also quite fast.
I ride with someone that uses 44mm tires. He's about my speed or maybe he's a little slower on average . The thing I noticed was on rough chip seal it's hard for me to keep up with him. So it really depends on what you are riding, but I expect a fit rider on wide tires could stay up with a group without issue.
Me too! I really like this dude personally and trust him, I don't think I was being upsold at all, he was just passionate that I'd enjoy them so much more enjoyable over 28s or 32s. He even offered to let me return them if I still hate them though it's typically against policy. That said he's a avid MTB dude so I know he's a fan of wide! Much of his argument hinged on that my Checkpoint is truly meant to run 40mm+ tires for optimal handling because of the design of the bike which seems reasonable.
Likes For bigevil:
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
Thanks for posting this article. These are closer to the kind of tests that should be done, not the mostly useless indoor drum rolling resistance tests.
What I would like to see though is an independent study with similar tests, I don't trust any tire company testing their own tires against the competition.
Likes For scottfsmith:
Veteran, Pacifist
Liked 4,832 Times
Just read your referenced post. At 123 lbs rider weight you really don't have to run much pressure in the 1st place.
You would greatly benefit with any tire that has supple sidewalls. 320tpi casings.
Likes For Wildwood:
Liked 4,809 Times
The way you ride your bike, hard and fast, leisurely or somewhere in between. Your terrain, rough or smooth road, your own perception of ride comfort and many other things will make tire sizing a variable for all. That's why we argue about it so much.
If there was a perfect tire width that was appropriate for everyone,. Then we all would be riding that one perfect tire.
Be a pain in the butt having to take it off and share it with the next person though <grin>
Jedi Master
I have been using compass/RH tires for a long time, I'd guess 8 or 9 seasons maybe, If you're going with a fat tire, they are hands down the best. I have bikes with a lot of different tire widths and have pretty much settled on 25mm for road rides 200k and under, 28mm for longer than that, maybe 32 if there's a little gravel thrown in, 38 if there's a lot of gravel, and >50 if its all off-road. I've ridden a lot of road miles on wide tires and prefer 25-28 almost all the time, and at that width there are lots of less expensive/almost as good-just as good alternatives to RH tires. I think 44mm RH-EL's are a fine choice for a checkpoint, but it wouldn't be my first choice for a road bike
Likes For kingston:
Liked 10,963 Times
T
Is this one of those "you're fitness isn't good enough to tell the difference" arguments? Bottom line no my fitness and skills likely aren't good enough. I'm a newcomer to the sport but I do ride 3x week building speed/FTP over past few months (not to mention at 124lbs small changes definitely make a big difference). That said I'm more curious about the article and its points more even than my personal experience.
If you're not racing or struggling to keep up with faster riders, maybe just ride the fatter tires because they're more comfortable. Because they are definitively more comfortable.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I clued into this around 10 or 12 years ago. While it was absolutely true that my wider tires were slower, at any pressure, it was because I'd buy the most inexpensive durable wide tires that I could find. By wide I mean 32's. Even when I wanted more supple 32's they couldn't be found, unless you were willing to pay 5-10 times the price for them.
I came to realize that if width and pressure make a difference - and I still don't doubt that they do- it's much less difference than the makeup up tire makes.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I am a fan of wider tires- don't ride less than 32's. As has been stated I find higher quality rides nicer. Though I think width and the higher weight do affect efficiency.
If you sign up for BicycleRollingResistance.com professional service you can change the rates to match your weight and speed. GP5000's go from 10 watts to 24 watts for me. I think this is nice to know though having a consistant method provides a better tire to tire comparison.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
Because I BMX maybe I have a different perspective. A big change in the world of BMX was tires going from 20 x 1.75 to 20 x 2.5. If I have a low amount of tire pressure lets say 40 psi then the smaller tire feels much faster. I could be wrong but I believe it is because the larger tire has a lot more flex/deformation because the volume of air pressure is much lower. The small tire is at 80-90% air capacity where as the bigger is a little less then 40%. This allows the bigger tire to make more contact with the road. But if I take the bigger tire and fill it up to 100 psi which takes the flex away and the tire is making less contact the rolling resistance is going to decrease and feel the same as the small tire.
With cars it's well known that lighter wheels = better performance. Some call it "un-sprung wheel weight". The bigger tire is going to have more rubber and more air volume so it's going to be a tiny bit heavier. But again other things are going to effect this like rim weight. Or the bigger tire being made from lighter material then a smaller tire. Also if the PSI matches the riders weight, as I am a bit heavier and need that extra PSI to not flatten out the tire. I think some people would notice the difference in wheel weight and others won't.
Occam's Rotor
Liked 2,331 Times
They aren't a tire company. They are a boutique vendor. The tire company that makes the tires is Panaracer. The Rene Herse people come up with the tire specs and test the prototypes and final products. They do have a stake in the outcome, and they do publish their results in their in-house publication (Bicycle Quarterly). But Jan is also a PhD-level scientist, and the results they publish have been corroborated by completely independent testing. (Bicycle Tire Rolling Resistance, for example, comes to mind.)
Quoted: 1944 Post(s)
Liked 2,164 Times
If I recall the premise is that real life roads are not the perfectly smooth surface of a drum and the width and pressure maintains contact and rides more smoothly than a harsher narrower and higher pressure tire that bounce off the bumps.
Except for those competing, tires are usually a compromise for everyone else. Comfort, handling, durability, etc. all factor in since most of us don’t replace them monthly to maximize performance.
The bottom line, regardless of which side of the forever ongoing argument you are on, is to ride what you want. There are also psychological advantages to riding a tire you really like. I’m sure that on descents, improved body position would more than offset for perceived speed differences, but that doesn’t really matter.
The only problem with these threads are the passion in which some people feel a need to convince others that their position is correct. The problem with that is no one really cares who thinks what.
John
John
Likes For 70sSanO:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
The BQ claims/results hardly surprise me - fat tires don't have a rolling resistance penalty, aero isn't very significant under 20 mph, and weight is weight (the article basically sidestepped weight). Seems to agree with most of the recent "real world testing" that's come out.
The most surprising thing was that the pedestrian $54 650x47 WTB Horizon was only 1.07 kph slower than the $84 RH 700x28 extralight with latex tubes at 400 watts - this is at 38 kph+ where I thought the fat tire would have more aero impact.
Likes For tyrion:
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
This discussion, wide vs narrow vs high pressure vs low pressure or any combination of them will never end. Way, way too many variables to arrive at a definite conclusion for all riders.
I'll stick with my trial and error method that always works, but always pay attention to any real quantitative analysis that can shed some light on new tires, methods, etc.
Likes For dmanthree:
fwiw I'm def potentially not even experienced enough to know the real difference of any of these yet. But I did just spend a small fortune on the wheels and just want to make sure the tires I throw on are optimal. Especially as I'm set to start training with a coach and digging into longer road rides.
Likes For bigevil:
Not that will in any way settle this debate, in fact, probably the reverse, but you can find out if more or less pressure is faster in your tires by "brushing" with a friend.
Start out coasting eat the same speed, next to each other on a nice down hill. Then repeat with more or less pressure in your tires, and no change to your friend's. Similarly, keep the weights, positions, etc. unchanged from trial to trial. You should be able to see the effect easily. You can call sprinting back up the hill for another run "intervals."
Likes For Pratt:
Quoted: 1561 Post(s)
Liked 1,734 Times
Not that again. That 'debunking' has already been debunked:
https://www.bicyclerollingresistance...000-comparison
They tested the same GP5000 tire in 23,25,28, and 32mm against their rolling road drum, and found that the wider width tire only gives you better rolling resistance when pumped up to the same pressure as the narrow tire. Nobody does that in real life. Because that wide tire, pumped to the same pressure as the narrow tire, will actually be stiffer than the narrow tire! If you pump each tire to the manufacturers' recommend 15% drop (ie. the height of the tire is squished in 15% when you get on the bike), they are roughly the same, with a small edge going to the narrower tire.
Conclusion: used as intended (ie. wider tire gets lower pressure), there is no benefit with the wide tire. Once you take into account aero and weight, the wider tire is going to be the loser.
In the end, the simplest rule of thumb is this: Light rider= narrow tire. Heavy rider= wide tire.
Likes For icemilkcoffee:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Strange 'real world' testing IMO as regards tire pressure effects. They tested using knobbies on very smooth roads to draw conclusions?
Likes For Sy Reene:
