So what type of GPS is a good one?
Bikes: 2015 Giant Roam 2 Hybrid
Quoted: 91 Post(s)
Liked 6 Times
I have one for the car but like any of them the battery will only last about an hour or two. Can't read it for shucks in the direct sun either.
What is a good GPS that has the battery life of maybe 4-8 hours and a decent size screen that can be read in the sun? Or am I wanting too much? I'm far sighted (read here: an old man) so screen size is important. Anyone have luck with external batteries over the USB? I was kicking around getting a 7" Android tablet but carrying it might be a challenge and it certainly won't be visible in strong sun.
I went on a ride Saturday with a "friend" (posted about it elsewhere) got me a bit further than I was comfortable with and kept racing ahead. It would be nice to have a GPS to tell me where I was and how to get home if it should happen that way again.
Bikes: Giant TCR SL3 and Trek 1.5
Quoted: 12 Post(s)
Are you wanting one for your bike or a replacement for the one in your car? Visibility is an issue for many of the car ones because of the screen material used. While it helps make the unit durable, it's not always easy to read displays during the day. Most will let you adjust brightness and other screen settings, so you might try that.
If you're asking about the bike, a number of us have Garmin Edge devices of various types. Even entry level models are 2-3 times more expensive than GPS devices for your car, though.
don't try this at home.
Quoted: 964 Post(s)
Liked 496 Times
Small screens.
Do you use reading glasses? Stick-on bifocals work great with non-prescription sunglasses. For example.
Garmin bike GPS devices have 12-16 hour run times, can be seen in bright sunlight, are waterproof, and have backlights for night riding.
You can quickly draw a course on ridewithgps.com, and upload the file to the Garmin. Then you follow the course line on a map that orients to your ride direction.
Garmins aren't perfect. Mine occasionally locks up, but just powering it back on lets me continue. I no longer bring paper backup maps.
I got my Garmin Edge 705 for the mapping. But I found I like to see the stats that are recorded from my rides. It shows the track on a map, the grades on the climbs, and my speed, heart rate, and cadence.
Quoted: 14 Post(s)
Liked 13 Times
There are many good apps that allow you to use a smart phone for navigation on a bike and as a cyclometer, and there are accessory mounts and sensors that allow recording hear rate, cadence, power, etc.. The usual issue is battery life with the screen on continuously . Auxiliary battery packs can resolve that issue.
Bikes: 1982 Fuji Supreme, Specialized 2012 Roubaix Compact. 1981? Raleigh Reliant mixte, Velo Orange Campeur (in progress)
I like my Garmin Oregon 450.
I have used it in car, while hiking, and it makes a very good cycle computer (will record/display ANT+ speed/cadence, heart rate, and power)
It uses two AA which are easily replaceable, though am planning on adapting my car power cable to use the B&M Luxos U usb port on my touring bike I am building.
The screen is very visible in most lighting situations, though some sun angles require shading the screen with my hand to read.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
If you want mapping, the Garmin 810 and 800 are very good
https://buy.garmin.com/en-US/US/cInt...ycling-p1.html
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times
My group has standardized on the etrex-20 ($168 from Amazon), ridewithgps web site, and OSM free maps. Sooo much simpler and cheaper than what I used to have to do. Even one of our 800 users is considering converting down to the etrex-20. The transreflective display is great in sunlight (brighter the better), don't have to touch the screen and get it all sweaty, --perfect device in my mind.
An Average Joe
Bikes: '13 Orbea Orca
I am a Edge fan and have the new 810 so is it easy to read and in all lighting conditions???? No, but that never really last long so no real problem as far as I am concerned. Plus I like being able to map out new routes and send to the unit.
Si Senior
Quoted: 23 Post(s)
Liked 10 Times
Not that I am considering buying one but what you said here is interesting. Can't beat the price. I'll assume you get no audible prompts if running a set route (?). This would mean paying close attention to the screen so you don't miss your turns if I'm correct. ( Do you still use a cue sheet? ) You also didn't mention how you mount it but that shouldn't be too hard to do.
Quoted: 4222 Post(s)
Liked 1,322 Times
Routes can/do include audible prompts and zooms but we don't use routes anymore but rather tracks. For our big annual trip I get gpx files (as well as pdf maps) that I upload to ridewithgps and write directly into the device. The problem with routes is that the devices (all Garmins) recalculate routes for themselves based on the waypoints. And it almost never matches our paper maps perfectly. Tracks, however, will match perfectly once defined. For a couple of years I did both tracks and routes just to get the beeps and zooms but it was a little confusing watching for the differences between routes and tracks.
To clarify the terms (as ridewithgps basically uses them):
"Route": a list of points at turns (connected by straight lines).
"Track": a list of points very close together connected by (very short) straight lines.
Tracks are much more accurate: they follow the roads (the path you basically travel on). Routes, on the other hand, "cut corners".
gpx (or tcx) files can be either "routes" or "tracks".
The Garmins (at least the Edge 800) doesn't work very well with "routes". You want to use "tracks".
(People often use "route" when they are referring to "tracks". As long it's clear that one wants the thing with lots of points, that isn't much of a problem.)
"ridewithgps" is a course planning website (it's one of many). You can upload tracks and routes to use as a basis for a course. You'd usually edit the uploaded course so that it follows roads cleanly.
Once you have the course in "ridewithgps", you can export the data as a "route" (not really useful for the Edge 800/810) or as a "track". The export can be as a file (gpx or tcx) that you can later copy to the device or you can have "ridewithgps" copy the file directly to the device (there's no magic being done by "ridewithgps": it's just doing what you'd do to copy the file to the device).
The Etrex 20 should work well. But, if you already have an Edge, an Etrex isn't really going to be better. (Except, maybe, for battery life.)
Can I assume then that the track file doesn't include turn by turn prompts? If so you have to be watching the screen constantly to get your turns or am I wrong about that? Personally I've used GPX route files and have no problem 90% of the time. ( Garmin 705 and Android with "Cue Sheet" app )
I think the thing I like about audible prompts is that I can turn the screen off and just turn it back on when I hear a prompt. Saves battery power. ( as long as you don't miss a prompt you're fine. ) Works well when on regular roads but if on bike paths you have to pay more attention to the screen so you don't go off course. No tracking system is perfect but not having to stop to look at maps all the time is just great.
Liked 1,322 Times
A "course" or "track" or "route" is a path on a map (one particular path drawn on a map).
The Garmins (for example) do extra route processing on a course. The reason you want to use a "track" ("snapped" to roads) instead of a "route" is because the track reduces the extra processing the Garmins do to follow a course.
That is, when you use a track, what the Garmin gives you (remember, it doese extra processing) is much, much more likely to match the course you planned. In other words, because a track indicates "all" the gps coordinates you have to hit, it constrains the Garmin processing (which means the course the Garmin produces will end-up matching (very closely) the course you planned). If you use a "route" (just the "major" turns), the Garmin has more freedom to figure-out the path between the "major" turns).
This is an important thing to understand: you have to think (a bit) about what the navigation device is doing and how it works.
Okay, about all this..^. I think I get it. Took a look at the RWGPS site again and noticed that they explain things a little better now, including some new information as well.
When I said I was running GPX routes I was wrong about that. ( Sorry, my bad ) I've been using GPX tracks all along. I know that because the RWGPS site recommended that type of file when using the 705. That's why when I use the Garmin 705 I get full written cues ( road names not just arrows ). At some point I might try adding some custom cues and try downloading a route as a TCX file. I can live without the road names as long as I still get a prompt.
I've only used the 705 a couple times. Pretty much I'm happy just using the Cue Sheet app on the Android, not to mention the Android screen is much nicer to look at if you have any location issues ( and is much easier to work with ).
Anyway, I was just curious as to how the etrex-20 worked with RWGPS ( since they make no mention of compatibility with that model on the website ). If the etrex-20 gives simple prompts while using a GPX track file and works with RWGPS like the other Garmins than that is quite interesting.
Si Senior
Quoted: 23 Post(s)
Liked 10 Times
Si Senior
Quoted: 23 Post(s)
Liked 10 Times
Okay, I think I follow you. So you upload a track file which which creates a more accurate map.
No prompts with tracks. But your comment about having to watch the screen... true but still way easier than staring at a map or queue sheet on your handlebar bag and wondering if that next road is the turn you're looking for and, oops, no street sign, so now what do I do?, etc.. And I find bike paths is where gps really shines over paper maps. Urban bike paths are notorious for branching unpredictably.
And regarding battery power... you might be thinking of smartphones and their terrible problems with gps navigation sucking power. I find the etrex 20 to last a LONG time. Sometimes I forget to turn it off at day's end. The next morning it's still running and has plenty of battery life left. One spare set should last you a week of riding all day long.
Si Senior
Quoted: 23 Post(s)
Liked 10 Times
Lest I sound like the gps is all "pros", here is one "con"
Sometimes maps are wrong and you need to get a bigger picture to plot your alternatives. These little gps devices are very poor for that. That's when I pull out the smartphone or the backup paper maps (if I'm carrying one).
Liked 1,322 Times
(ridewithgps lets you turn on/off your subscription level.)
That's the Etrex 20.
Just to be clear, you do get prompts with tracks on the Garmin 800/810 (and 705).
Because the "route" (the list of major turns) can be so wide-apart, the Garmin has to figure out what to do in between the listed turns/points. What the Garmin decides to do might not match your planned course very well.
Using a "track" (lots of points indicating the detailed path being followed) means the Garmin has to do less (next to none) figuring out what to do.
Note that you can load custom locations to the Garmins (and have the unit compute a route to a location).
It's even not that hard to keep track of the purple line when you are off course (that does often require some zooming/panning of the device while riding).
The Garmin continues working while being charged (you do have to be able to put the external battery somewhere and you might not want to do any recharging when it is raining).
I, too, use a smartphone as a backup.
The standard mapping/navigation apps (Google and Apple) work pretty-well but they (basically) require access to the cell network.
If you carry a phone, you might consider a mapping program that lets you download maps before-hand. (Note that some of the apps make downloading maps really hard.)
Note that some of the mapping apps also let you display tracks and waypoints/points-of-interest.
Quoted: 91 Post(s)
Liked 6 Times
Yeah boy. I once took my mother to visit an old friend and my BRAND NEW Garmin GPS kept telling me I was off-route and telling me to turn around. Seems like they moved a hefty piece of highway a few hundred feet and it was enough to throw it for a loop. I finally figured out how to adjust what it thought OFF ROUTE was to a more generous setting and it shut up.
Liked 1,322 Times
Yeah boy. I once took my mother to visit an old friend and my BRAND NEW Garmin GPS kept telling me I was offroute and telling me to turn aroun. Seems like they moved a hefty piece of highway a few hundred feet and it was enough to throw it for a loop. I finally figured out how to adjust what it thought OFF ROUTE was to a more generous setting and it shut up.
I think that either the map was stale (and didn't have the exact location of the newly-widened/moved roadway). Or that the GPS position was not accurate enough.
It's actually amazing how well the devices work. Knowing how they work (and their limitations) lets you roll with their quirks.
(Next time you feel you need to trow it, throw it my way, gently!)
just some other follow up...
About the "premium service" from RWGPS; Yes, nice to be able to download directly to the unit. With the 705 since I'm not using the P-Service it is not so easy to download the route. The problem seems that once I've down loaded the route I have a hard time finding just where it is on my computer so I can send it to my 705.
I eventually find it but damn, I wish the process was more intuitive. I guess the next time I use the Garmin I'll have to write the procedure down so I don't forget. Sorry but I'm not going to pay $10 a month just so something is easier to download. That is a complete rip-off. With the smartphones you don't have this problem. You just press "download route" on the phone and it is done.
Liked 1,322 Times
About the "premium service" from RWGPS; Yes, nice to be able to download directly to the unit. With the 705 since I'm not using the P-Service it is not so easy to download the route. The problem seems that once I've down loaded the route I have a hard time finding just where it is on my computer so I can send it to my 705. I eventually find it but damn, I wish the process was more intuitive. I guess the next time I use the Garmin I'll have to write the procedure down so I don't forget.
??? Are you talking about the Edge 810? If you are talking about apps, with the iPhone (at least) you typically have to email the file as an attachment to be able to open it in an app.
Flounce
19
01-15-18 07:26 PM
