what is that thingy on the fork
I wanted to search for a video about how to remove and replace this if it can be done, but I don't actually know what this piece is called. If you guys can tell me I would certainly appreciate it.
Likes For FrozenBiker:
is this a joke? You've been here a long time...
A) it is a ... lower race or bottom race (or previous crown race) ...
A) Yes, it is removable/replaceable (Ever purchased a headset?)
A) Yes, numerous tools are available to remove and install it.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
It's called a crown race.
It is a bearing race & it is located upon the fork crown.
It is removed with a crown race puller.
Any bike shop should have the tool & be able to perform the removal & reinstallation for a small fee.
Car dependency is a tax.
Quoted: 6196 Post(s)
Liked 4,811 Times
The part of the crown race we can see in the picture looks in good shape. The discoloration or possibly ever so slightly pitted appears to be outside the contact points of the bearings with the race..
Thank you!
I've removed and replaced all the other parts of a headset, but never had to take this piece off of the fork.
I'm happy to get the tool and do it myself. I just needed to know where to start. Thank you.
That's kind of why I was looking at it and why I started thinking about what would be involved in replacing one. It felt good once I put the headset and fork back together and got everything adjusted, but it occurred to me while I was doing this whole thing that I have never had to replace one before and it's something that could conceivably need to be replaced.
I know what it does, I've just never replaced one before. And searching for an instructional video without the name of the thing is fruitless.
Thanks again.
I have this tool that somebody gave me to install a crown race, but I have never removed one
Thanks again.
Quoted: 4806 Post(s)
Liked 3,932 Times
A fun, sorta off topic too; I got to see in action Friday - a super race puller. It may have been a Park shop tool. (I think I recall seeing the Park logo colors on it.)
The story - I went to TiCycles with frame and fork of my Peter Mooney. (Frame's getting a braze -on moved, new WB bosses and a re-paint. Brought the fork just to show Dave Levy. I hadn't knocked off the lightweight aluminum Stronglight crown yet. (And I wasn't really looking forward to it. I've done it with steel crowns. a large screwdriver and hammer and not marred or distorted anything but it takes real time and attention.)
Showed the fork to Dave. He immediately wanted to show me his new tool. A cylinder roughly the length and width of a floor pump. Instead of folding foot tabs, it had screws with nice handles. Bigger screw emerging from the top. Insert fork steerer into bottom. Tighten the two bottom screws to grab the sides of the crown. Crank down top screw. Fork drops out the bottom. Crown stays immaculate. Takes not much longer than reading this!
Edit: except for that tool, I have all the rest of the headset tools, mostly for cheap. Common pipe and threaded rod do very nicely for installing crown races and that same pipe can be used to install crown races. I used 1/2" rod. Rounded, chromed, sorta nylock style nuts that fit nicely into the race inside and self center. All Home Depot; maybe $15 total. (Crescent wrenches and hammer also needed.) I did pay for the Park cup remover that also requires that hammer. Headsets are one place where special tools are not needed but boy! do they make the job faster and more fun!
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
There’s an even nicer newer Park crown race removal tool that uses three prongs instead of two and is adjustable about 60 zillion ways to fit all kinds of forks.
Got one last year for Christmas. Not cheap, but it removes a super lightweight Dura Ace 7410 cartridge race (IMO the most difficult to remove without bending) very nicely.
I also made my own installation tool. If I ever get to work on some ultra high-end fancy bike maybe I'll get something nicer with this seems to do the trick for now.
As for removals, I looked up a few videos and, again, for the kind of bikes I'm working on a hammer and screwdriver will probably be fine.
Likes For cyrano138:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
These are generally not on too tight. A 1/4 or 5/16 pin punch with light taps will get them off without damage to the race or one of your screwdrivers.
Likes For Chuck M:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Cheap screwdriver and a few taps of the hammer to remove, a piece of copper or pvc pipe to install.
You say you "replaced" the rest of the headset parts, didn't your new headset come with a new crown race?
These have to match the headset bearings etc and come in different sizes (JIS/ISO)
Liked 4,811 Times
I'm glad you brought that up. I had to sit on my fingers when I read that initially. Screwdrivers should be used for installation and removal of screws. I remember being aghast when a television DIY home repair person suggested and used one for grout removal when replacing a tile.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
ob
Yes, that will work, if you're careful. Don't try to knock it off in one blow; work slowly around the circumference of the race so it comes off straight, instead of going crooked and cracking.
A dedicated crown race remover is quicker, but not really cost-effective for a one-off job.
Liked 3,932 Times
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
ob
Yes, a dedicated crown race remover is a thing of beauty. But screwdrivers for crown race removal are the Devil’s tools! A bearing splitter works better and it’s the business end of the dedicated crown race remover. Looking at that bearing splitter, I see that it is threaded. It wouldn’t be too hard to DIY this splitter which is the Park tool without the fancy tube.
Stuart Black
Stuart Black
Quoted: 2026 Post(s)
Liked 1,096 Times
The screwdriver/punch approach to crown race removal works OK as long as the crown race is larger in diameter than the fork crown so the edges overlap and give the punch something to hit against. Many newer forks, particularly carbon or those made for integrated headsets, have a fork crown larger than the crown races so your punch can't reach it.
The Park Tool crown race remover (CRP-2 or it's predecessor) 79pmoony described above is basically a modified "bearing splitter" and uses opposing thin sharp wedges that are forced between the bottom of the crown race and the fork crown to get a purchase than pulled off with a big screw press. As a homemade version of this approach I've used a sharp wood chisel bevel side up and gently tapped into the seam between the crown race and the fork crown, working it around the entire circumference several times. Eventually it opens up enough of a gap for the race to fall off or be removable by hand. Be VERY careful not to drive the chisel so deep you hit the steerer, particularly with an all carbon fork.
Liked 1,096 Times
ob
I’ve used a large adjustable wrench to remove crown races. Adjust so it sits on the front and back of the crown race and tap gently, that way you’re pushing on both sides and it comes off straight. An appropriately sized piece of PVC pipe (cut square) can work as a setting tool to tap it back on.
Liked 4,221 Times
It shouldn’t. The pipe will just slide over the steer tube just like the tool you have.
Stuart Black
Stuart Black
For Removal (Pics):
I have old bikes. About the only thing the Campy does fit of mine are old bmx stuff sometimes. Newer forks it would have a problem with. The cyclus is newer and deeper which wouldn't be bad. Both of these assume the race is wider that the fork crown itself
For Setting, I have a Hozan C-435 tool I picked up used.
old
New cyclus tool
old
New cyclus tool
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
