Thumb vs Grip Shifters
Quoted: 29 Post(s)
I'm interested in hearing the preference between thumb (specifically Shimano Rapid-Fire) and grip/twist shifters (Microsoft). I'm building a 2005 Trek 520 but will replace the drop bars with either straight mountain bars with barrens or take the plunge with a butterfly bar. Looking for easy installation but reliable. Thanks in advance for your feedback.
Quoted: 1083 Post(s)
Liked 687 Times
I think you mean MicroShift, not Microsoft. But we know what you meant.
I don't think very many people will recommend grip shifters. The few times I've bought a used bike with those, they got removed and thrown away, whether they worked or not. Shimano Rapidfire always works well.
I had butterfly bars on several bikes for a while, but after the novelty wore off I switched back to either flat bars with bar ends (Ergon GP5) or drop bars. I felt like I didn't have as much control with the Butterfly bars, and found the brake lever position was awkward - too close together to maintain control under hard braking.
Likes For robow:
nearly give me a heart attack! MS-shifters??!!!! damn, imagine having to wait five minutes for your shifters to boot up, or having a 5-second delay in shifts because of a mandatory update!
oh!!! you mean microshift! yeah, been using them for many years.
reliable, dependable, less expensive than shimano.
they make various versions.........grip shift, trigger, brifter, bar end.
i think they might also have some basic thumbies, as well.
Likes For saddlesores:
Thumb shifters are super reliable and just work IME. All my experience with thumb shifters is with vintage Deore XT though. Twist grip are okay, but a bit less reliable of a shift IME, but I have used a cheaper line of those so that may explain the reason.
If you have really arthritic thumbs like me that might be a factor. I have trouble with thumb shifters causing me pain these days.
My wife developed some arthritis in her left hand and couldn't turn the front derailleur grip shifter on her Specialized hybrid. Had a bike shop switch it over to thumb shifters. Not only solved that problem but has required zero adjustment over the years. The grip shifters were definitely more maintenance.
Quoted: 3462 Post(s)
Liked 1,468 Times
What are barrens? Did you mean bar end shifters? I have never seen bar end shifters on straight bars before. I think some people use bar end shifters on butterfly bars.
If I had a flat bar touring bike, I would not want a twist grip shifter. My errand bike has lever shifters (one lever for up shift, other lever for down shift) on flat bars, I think that it is best, but I do not have arthritis in my hands.
I have a twist grip shifter on drop bars on my Rohloff bike, but the shifter is oriented differently (different ergonomics) and that shifter works very differently than a derailleur bike twist grip.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
Because of the hard plastic sleeve inside a grip shifter, the may not even go around the bends of a butterfly handlebar in the attempted installation. Since I was a bicycle store owner for over twelve years, I have a boxes of grip shifters and (Shimano) Rapid Fire shifters. I used to have a big bag of (top mount type) thumb shift levers, but went missing about 6 months ago.
Quoted: 5224 Post(s)
Liked 3,585 Times
Liked 687 Times
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I did write "may" not fit butterfly handle bars. I did not say they would not fit. I admit that I had seen pictures of grip shift on butterfly handle bars, but was to lazy to re-check to see if they would fit. Nice looking handlebar padding. Anything special?
Quoted: 62 Post(s)
Liked 255 Times
I prefer the rapid fire style shifters. They are more precise in their shifting, take less effort to shift, and are just as easy to install. Also, it can be much more difficult to replace the shift cable in a twist grip when the time comes. I won’t soon forget the fun I had trying to get a twist grip back together correctly that I accidentally allowed to spring open while changing the cable.
Quoted: 29 Post(s)
Thanks for the insight on these types of shifters, always been a 'bar end' guy. Also apologies for not checking that spellcheck did usurp my post. If I could, is there any advantage/disadvantage to combination shift/brake units over separate units? The Alivio sl/bl units I've been looking at have fallen into the 'unobtainium' category of bike parts.
Quoted: 1324 Post(s)
Liked 927 Times
Fir simplicity and reliability I far prefer the Old School Thumbshifters. No problem remembering which lever shifts up or down (Rapidfire type shifters) and no danger of hitting a bump and accidentally shifting into a harder gear (twist-grip shifters) and a lot of them have a friction mode too.
I like these Deore ones. I can use t hem with any number of rear cogs is I switch it to friction mode.
Cheers
Cheers
Likes For Miele Man:
Liked 1,468 Times
I had to replace a combination unit when the shifter gave up. But I bought a used one for a buck, so buying a combination one did not cost extra.
Speaking of used parts, many communities have bike coops or bike charities where there are bins of used parts that you can buy. If you have trouble finding the parts you want, see what there is locally. I have bought used parts that are on at least five of my bikes. I think my road bike that I bought new three years ago is my only bike without any used parts on it, but I bought that as a complete bike that did not need anything other than water bottle cages.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
Yep, I had a bag of five or six pairs of LX shifters (like yours/ pictured above) and a pair of XT's. Sadly, they went missing about six months ago. Note: Some of the Rapid Fire shifters are designed to only work with V brake calipers (They have a different cable pull ratio) Some have a set screw, and the cable ratio can be changed to work with cantilever brakes. I have seen over the years where people have put together V brake rapid fire brake levers to cantilever brakes, and they have very, very poor stopping power (no bite), because of the incompatibility.
Liked 1,468 Times
Headwind15 makes a really good point, if you use mountain bike levers, they need to be used with mountain bike brakes (sometimes called linear pull brakes). Road brake levers pull cable a shorter distance but with greater tension than mountain bike levers.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
For my own bikes with straight or riser bars I like Grip Shift/SRAM brand twist shifters and I insist on the front shifter being "friction" rather than indexed, many small clicks for precisely trimming the front derailleur instead of the three steps. Never liked Shimano's Rapid Fire.
Liked 687 Times
Double wrapped. The top layer is (was) Lizard Skins, with Cinelli cork tape underneath. It was good for one riding season but Lizard Skins does not last. I invested in Lizard Skin tape one year for four of my bikes. None of them lasted more than one riding season before they all started to peel. Expensive garbage, as far as I'm concerned. Now I just double wrap Cinelli tape and that holds up a lot better.
Liked 687 Times
It depends on the brakes whether they're unobtainium or not. Shimano EF-500 is available in 3x7 and 3x8, but they're long pull so you are limited to V-brakes (on your frame). The old EF-51 and EF-65 used to come in a "four finger" version that was compatible with cantilever brakes by moving a spacer, but those are indeed impossible to find. I've seen references to the new EF-500 coming in a four-finger version that accommodates cantilevers, but I haven't seen those for sale anywhere either. But if you're going to go with V-brakes, those shift/brake combos are available.
I have a vacation bike with grip shifters and do not like them at all. At first glance they look convenient, but there is the reliability factor mentioned above, Many times while hard pedalling, my hand accidentally changes gears because the grip is not wide enough
I have bikes with both. The grip shifters are fine, but more difficult to maintain. The thumb shifters are MicroShift, and are excellent.
I get stiffness and cramping in my hands from time to time that means I can’t close my hand properly to grip the grip shifters. With the thumb shifters I can nudge them hawing my entire hand so I can still easily change gear.
If I wanted to build something bombproof, I would use thumb shifters. I can change the gear cables easily. I bent a derailleur a year or so ago, and messed up the shifting on my gripshift bike. I couldn’t shift as indexing was way out of whack and I didn’t have my tools. With thumb shifters I could have just switched between indexed and friction mode and kept on riding.
Easy to shift, easy to set up, easy to maintain, cheap to buy, and the MicroShift ones I have are very well built, high quality, and look the part on my ECR.
Likes For jvt:
Quoted: 18424 Post(s)
Liked 15,580 Times
In '98 I won't a Cannondale M 300 MTB (really more like a hybrid) in a contest. It had grip shifters. They never worked as well as the ol' skool thumb shifters that came on my '92 Trek 930. Those things were super-reliable. They performed great for the 13 or so years that I abused that bike. I finally put it out in the alley with the trash behind my mom's house when she was cleaning out in preparation for sale. It was gone in fewer than 2 hrs. I like to think they are still out there somewhere shifting.
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 209 Post(s)
Liked 178 Times
Just a note that thumb shifters, like the Deore up above, are not the same as "trigger shifters," like modern Shimano stuff, right? Thumb shifters are the best - I think of them as knuckle shifters. Don't have to use your thumbs, just nudge it with a knuckle. The motion is almost like a grip shift.
