What do you guys think of modern internal hubs?
I've looked at some of the Shimano and Sturmey Archer branded models... (rohloff is way beyond my price range)
Are they any good? I know that's a general statement. Reliable? Unreliable? noisy? Inefficient?
Liked 6 Times
For me, the benefits are outweighed by the downsides. The biggest benefit I could reap would be... uh... that I wouldn't be likely to break my chain from vicious power-shifting. Something else might break, like a planetary gear... but the chain would be fine. The next-greatest benefit would be immunity to slush buildup between my cassette cogs when the weather is hovering just around freezing and I'm riding in snow, but that's not a very frequent problem.
In general I'm pretty picky about a good drivetrain. I like it quiet and smooth. I don't want to know it's there. I really only ride fixed gears but want to build up a 1x8 (standard cassette) or a 1x(whatever internal hub I find)
Liked 6 Times
If you know anyone who has IGH, give it a try. But if you know anyone with a walk-in freezer, also march in there with an IGH bike and try a complete rear flat-tire repair with numb fingers, by the light of a small flashlight. You'll be WISHING the drivetrain weren't even there
Have 2 Sturmey archer hubs,UK AW3 & TW BSR, updated version of the same.. they are fine .
Also Have a Rohloff a 7 speed in 2 ranges, the planetaria roll on needle bearings in those ,
an oiled bushing in the simpler hub.
OEM Torque stop following the hub into a longer Dropout , on the QR axle Rohloff
is not too bad at puncture time..
The 3 speeds are on Bromptons, so there is 2 nuts on the right side
1 holds on the Chain-tensioner , the other holds on to the frame..
pull the indicator chain, unscrewing at both ends,
it and the wheel will come out..
Bikes: 2000-something 3 speed commuter, 1990-something Raleigh Scorpion
Sturmey Archer 3-speeds are virtually indestructible when properly adjusted and lubricated. Their 5-speed hubs are effectively two 3-speeds with different ratios. The older versions used a second cable and shifter to switch between close and wide range, but the modern ones do this with a single cable. Removing the wheel isn't that difficult- aside from the axle nuts, all that needs doing is disconnecting the gear cable. If you patch the tube rather than replace it, you don't actually need to remove the wheel anyway.
Any difference in efficiency between a well-maintained derailleur system and an equally well-maintained 3-speed is on the order of a few percent, certainly not enough to worry about for general transportation riding. Using a chainguard makes the hub gear system easier to keep clean, and sturdier 'single speed' 1/8" chain can be used.
In terms of noise, I find my derailleur bike to be far noiser than the 3-speed. There is a constant buzz from the derailleur pulleys as you ride along. With the 3-speed hub, everything's nice and quiet.
I like the ability to change gears stationary with an IGH bike, something which makes a lot of sense for stop-start town riding. In addition, the whole setup just looks neater- just a chain connecting the front and rear sprockets. This has a practical benefit as well- there's no extra hardware hanging off the side of the bike waiting to get bashed by debris. This is particularly useful if you ride away from paved roads.
Also, Older 5 speeds narrowed the inner ratios , new 5 speed adds 2
to the AW3 like ratios ,
So , wider % high to low , wider jumps.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
I have one and I love it.
I also have Sturmey Archer -S2C 2 speed
-XRF5 5 speed
-XRF8W-8 speed
Shimano - SG8R25-8 speed
Rohloff 14 speed speedhub X2
In the past, I have had the lesser version of the 8 speed Nexus (SG8R20), Sachs Super 7, Sram iMotion 9.
All function superbly well, though not all are silent.
Apart from the fixe, the quietest of these hubs is the Shimano Nexus, and newer, updated versions are quieter still.
Dan
Certified gearhub nut.
New SA are very nice. SRF-3 is quite a good update of the classic AW 3 speed. With an IGH you can achieve almost perfect chainline smoothing your drivetrain quite a bit. You do get some small and i mean small frictional losses with IGH, however, nothing you will notice. SA is good, Shimano Alfine 8 speed as well although more pricey. SA imho you get the biggest bang for the buck. If you are the tinkering type you can get an older SA hub off ebay for 10-20 bucks.
-Carcinogent
-Carcinogent
Dan, That's what I wanted to hear! I looked at the Sturmey Archer S3X and kinda loved the way it looked on paper... I think that one is even available in 120mm widths...
S3X is different from the AW3, as It is 2 reduction gears , with 1:1 top gear
where the AW3 is a .75 low and a 1.33 high a 3/4 & 4/3 ratio ..
1:1 is in the middle .
the 8 speed is 1:1 bottom and 7 overdrive ratios.
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
https://www.bikeforums.net/showthread...ight=Alfine+11
https://www.bikeforums.net/showthread...more-I-ride-it.
Don in Austin
I think it's gonna be an S3X for me. It will be going on this bike: https://imgur.com/a/igsIR - I like the ability to switch cogs and go to a freewheel. I travel a lot and sometimes it's nice to coast for a few minutes
Senior member
Quoted: 943 Post(s)
Liked 658 Times
We'll be waiting to read all about the conversion and how you like it. I can't get the smile off my face when I ride mine. It's just too much fun.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Compared to what? A complete mid level derailleur group with cassette, shifters and everything will cost as much or more than most gearhubs.
I ride a recumbent tadpole trike (heavily modified). I have a Schlumpf high speed drive on the front (34 and 85 tooth effective rings) and a nexus inter7 on the rear. The net effect is a 610% gear range, fairly quiet, and a chain which stays in exactly the same place all the time and never falls off. To remove the rear tire you just unhook the chain (about a 3 second process) and undo the two retaining nuts, that's it. I really like being able to shift from any gear to any gear while sitting still, coasting or pedaling. Both drives are very tough. (JMO)
I got both drives on ebay and paid substantially less than 1/2 price.
Bikes: Puch Brilliant 8 speed, Batavus Barcelona 3 speed
Sturmey Archer 3-speeds are virtually indestructible when properly adjusted and lubricated. ....... Removing the wheel isn't that difficult- aside from the axle nuts, all that needs doing is disconnecting the gear cable. If you patch the tube rather than replace it, you don't actually need to remove the wheel anyway.
I've very recently posted on here a walk-thru of getting the rear wheel off an IGH Dutch bike with a full plastic chaincase. It's no big deal really -- I suspect someone's impressions of that task will depend on when and where they first had to do it. By the roadside on a dark rainy night without the right tools, you'd get a dreadful first impression and would never want to do it again. But in a planned scenario, with time on your side, the right tools and resources, and at home -- well it won't seem so scary the next time.
Quoted: 1529 Post(s)
Liked 718 Times
Quoted: 19 Post(s)
Liked 7 Times
I'm used to riding in town with downtube friction shifters on a 3x8 system so all that "shift before stopping" is second nature. I changed to a Shimano Alfine systems for more carefree city riding and that is exactly what I got. I find that I have to pay less attention to dealing with the bike so I can pay more attention to traffic, whats for lunch, pretty girls, mmmm beer.
Wheel removal is a little bit more involved but not much. No cable adjustment is needed when refitting.
The bike collects less dirt esp during dark, damp winters so the only regular maintenance I do is lubing the chain. In 3 years I have stripped and oil-dipped the internals once and they were in fine condition.
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
I think the SRAM iMotion3 and Sturmey RSRF3 are the best three-speed hubs ever, even better that William Reilly's "X".
Palmer
Liked 1,825 Times
The fastest bicycle ride around the world record is currently held by Vin Cox who rode a bike equipped with an Alfine 8-speed IGH.
