Fitting experts, I need a second opinion
So I currently ride a 54 Caad10 and it fits almost perfect. Top tube c-c is 54.5 and seat tube is 54
I'm considering purchasing an older steel frame that has a 56.5 top tube c-c and 56 seat tube
Any idea how things will shake out or am I missing too many inputs for this calculus to work out...
Thanks guys.
Oh yeah, I don't plan on training on this bike, plan to just make it a nice weather, tool-around town machine
Thanks in advance guys!
Thanks guys.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
So assuming equal angles, you'll have 2cm less seatpost showing and require a 2 cm shorter stem. Don't know your handlebar drop, but I'm sure you can figure it out.
Is your 54cm CAAD10 small for you? If it fit great, then you might want to rethink buying this bike. 2 cm in top tube is a sizable change. While it might work, trying to ride a frame that's simply too large is a formula for long term pain.
seat tube fit is easy, just lower your seat post.
To get the top tube fit right, you can do three things (individually or in combination):
1. get shorter stem.
2. move saddle forward
3. Raise handle bar
3. Raise handle bar
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Is your 54cm CAAD10 small for you? If it fit great, then you might want to rethink buying this bike. 2 cm in top tube is a sizable change. While it might work, trying to ride a frame that's simply too large will be a pain.
seat tube fit is easy, just lower your seat.
2. move seat forward
3. Raise handle bar
3. Raise handle bar
Quoted: 1814 Post(s)
Liked 923 Times
Not that much of an expert, but if it's an older bike with a threaded headset, most of them have pretty long stems, and a short enough stem might be a hassle to come by.
OTOH, if you're putting few miles on it, the fit is not as critical.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
How long a stem do you run on the CAAD10?
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
If you get one with a 26.4mm bar then you pretty much have to go eBay these days, however.
I'm lucky enough to live near good bike shop territory so scored a used 90mm cinelli with 26.4mm clamp for $20.
I pretty much have a 5cm range of bike sizes I can work with, generally.
Bikes: Motobecane Vent Noir, Specialized Crux, Specialized Carve
Quoted: 14 Post(s)
This.
& This.
If you run a 110mm+ stem on the CAAD I think you'd be okay.
If you have to push your saddle forward you could cause knee pain.
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
Keep in mind older "classic" geometry typically called for much less seat tube than modern bikes. So, in a *very* general sense, I would not find 56cm in a classic frame terribly shocking compared to 54cm in a modern frame. I can usually find a reasonable fit for myself with bikes ranging from 53-57cm, but as someone said, there are variables that you can not adjust away, so none of that (for me) is true in all cases. If it's cheap enough, try it out & if it still doesn't work, flip it for one that does.
3. Raise handle bar
3. Raise handle bar
Quoted: 14 Post(s)
I would disregard seat tube length, I would only consider horizontal top tube length. My Specialized Crux has a 52cm seat tube, and my Allez has a 49cm seat tube. Yet both have 53.7cm top tubes and fit perfect. If your already running a 90mm stem on a 54.5cm top tube I wouldn't get something with anything longer.
56.5 is too long for the guy. My best guess is that you will end up with a 8 or 7 stem to make it work, if the bikes have the same angles. IF the steel bike has shallower angles then the reach might be the same or close and maybe the 9 stem will work, but IMO like 3 cm in length is too much to make it work. Unless you really dont care at all if the fit is tiny off.
Quoted: 25 Post(s)
You are forgetting that the seat post is not vertical. When you go from 54 to 56 seat tube, the point where the seat tube meets the top tube is moved up and backwards. Assuming equal angles, the switch from 54 to 56 would move the junction up 19 mm and back 6 mm. There's a good chance that angles aren't equal either: bigger bikes generally have more off-vertical seat tubes. Going from 54/74° to 56/73.5° would move the junction up 18 mm and back 10 mm.
Since the top tube is measured from that junction to the top of the head tube, this backwards move "eats" some of the extra top tube length. So, instead of 20 mm you only have to deal with 10-14 mm.
Generally speaking, TT length is a bad metric. It's easy to measure, but it's too confusing and easily misunderstood, even if the top tube is horizontal. It's almost totally worthless when the top tube is slanted. There is a better metric called "reach": horizontal distance between BB and the top of the head tube. It varies a lot less than TT length. For example, on a Trek Madone 5.2, the difference in ETTs between 62 cm and 52 cm frames is 64 mm. The difference in reach is only 19 mm: the rest is eaten by the move of the junction point.
Bikes: everywhere
Liked 7,695 Times
I second pdede's most recent post. If you're running 90mm stem and have a good fit then you're pretty much at the big end of your useful frame size range.
Thanks guys.
Thanks guys.
The biggest potential problem is that the 56 will have a higher head tube: the top of the head tube will be 2-2.5 cm higher from the ground than it is on the 54. The best way to compensate for that is to use fewer spacers below the stem. If you don't have any spacers below the stem on the 54, it's probably not a good idea to get the 56, because you'll not be able to get into the same posture (you'll be forced to be slightly more upright.)
Bikes: everywhere
Liked 7,695 Times
The biggest potential problem is that the 56 will have a higher head tube: the top of the head tube will be probably 2-2.5 cm higher from the ground than it is on the 54. The best way to compensate for that is to use fewer spacers below the stem. If you don't have any spacers below the stem on the 54, it's probably not a good idea to get the 56, because you'll not be able to get into the same posture (you'll be forced to be slightly more upright.)
Good point. Possibly even more. Nowadays most stems are +/-6 deg. It's less of a problem, then.
Quoted: 14 Post(s)
That's what I was getting at. I ride a 53.5cm top tube with a 110mm stem. My bike actually has a longer reach than his 54.5cm and a 90mm stem. There's no way I'd ride something with a 56.5cm top tube.
TheOtherZach
14
08-13-12 02:19 PM
OneArmedScissor
Road Cycling
7
07-25-10 07:24 AM
