What range do you think this will go?
Quoted: 5 Post(s)
Nominal Power 250W/350W
Throttle Only Range 50km (31 miles) For someone who weighs 220lbs
Main Use On road, commuting, recreation and leisure
Max Weight 330lbs
https://dillengerelectricbikes.com/e...dillenger.html
I weigh 280 pounds and i would use this on flat road
How far do you think i would go then?
Max Weight 330lbs
Quoted: 5 Post(s)
Yeah well the company called me and told i should get about 25 miles they think. So thanks
This is the kit i think i will buy because its got warranty and its made in USA it was recommended by a forum member here and its saving $400 from $1000
I think this would be the best kit for range and speed for me.
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
Dillinger isn't made in the US, it's from Australia. They have warehouses here in the US where they ship stock.
Quoted: 5 Post(s)
Quoted: 44 Post(s)
See for some user experience:
https://www.bikeforums.net/electric-b...t-hub-kit.html
Also a search for Dillenger on this and other Forums will show more experiences.
Quoted: 5 Post(s)
If it's been working for 2 years or more for him and he was the one who's suggested it I'm going for it.
Liked 374 Times
Quoted: 5 Post(s)
It's not I care for results not locations
Nothing wrong with them, just wanted you to know they weren't an American company, in case that was important to you. Have you looked at these kits: https://www.e-bikerig.com/about-us/ This is a USA based company.
Quoted: 340 Post(s)
Liked 275 Times
Tell us when you get 25 miles on throttle only. I'm 100 pounds less, and don't have a bike or battery that I would commit for that.
It's still a good solution in my opinion, and well priced for a low power front drive kit.
Quoted: 5 Post(s)
I contacted company they said I can easily hit 25 miles.
Upon weight check I'm now 269
Bikes: Kent DIY Road Ebike build
Quoted: 15 Post(s)
Liked 12 Times
there is a good ebike simulator that you can adjust the weight and amps watts ect to find out want it will do. but I don't have 10 post yet to post a link. but here the web site electricbikesimulator.com
Bikes: As my watts decline, I’m amping up!
Quoted: 153 Post(s)
STATED: 36V 13Ah (470Wh) - 100 km (62 miles) Max Range
RULE OF THUMB ESTIMATED MIXED USE RANGE: (36V * 13Ah) / 20 = 23.4 miles
Being a low watt front hub motor, no pedaling throttle only use pushing 300lbs+ (you and bike) I'd say you'll be very lucky to get 25 miles range. Remember batteries don't like to be ran until drained, it shortens their life.
IMHO at 300LBS+ you should go for a 500W-750W / 48V system and a bigger battery. Just being realistic and honest about personal experience use. Do yourself a favor and prevent disappointment.
Just my 2-cents worth, YMMV.
Quoted: 5 Post(s)
Well does anyone have a good kit+battery that isnt super costly????
Because the bikeshop i went to they told me that the 250w or whatever it was kit was going to help me out getting roughlyish 20miles-25miles
I called the company they said my weight 280+bike+kit+battery they told me 25miles
I tried that simulator out but some other information i dont have.
Quoted: 153 Post(s)
It will help you out greatly if you pedal too. Throttle only isn't what a 250W hub motor is really designed for at the weight you are pushing.
Quoted: 5 Post(s)
Quoted: 153 Post(s)
I have no personal ownership experience with hub motors at all. I prefer mid-drives because they leverage the gearing of the bike making them better for variable terrain and conditions; such as hills and headwinds. IMHO the easiest, quietest and most used mid-drive is the Bafang BBS02-B 750W/48V "completely unmodified" for most peoples use needs. Getting the color screen has huge advantages for access to settings without a USB programming cable and all the hassles that go with messing with that; like knowledge. The newest BBS02-B models also have a gear shift sensor and headlight wires coming out of the motor, if those features are important to you. Look into this option. Bafang BBS02-B ~$500 and battery ~$300-$750 depending on size and quality.
