Cornering Tip
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Keep your inside pedal up.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 897 Post(s)
Liked 9 Times
Practice a lot. I like doing tight figure 8's for balance. I don't worry about where the pedals are, it's impossible for them to scrape while doing this, at least on any of my bikes. You should be able to do a u-turn inside the width of a narrow traffic lane (~6-7 feet).
Stay relaxed and don't turn too sharp or the front wheel will "scrub".
BloomBikeShop.com
Look where you want to go. Your body (and bike) will follow suit.
Start slow and increase speed as you increase confidence. It is also very helpful if you can find someone and watch them do it.
And never stop practicing!
Quoted: 897 Post(s)
Liked 9 Times
Confidence is key. If you panic during the middle of a sharp turn, nothing good can happen. Stay relaxed, as any hint of tension, hesitation, or uncertainty in your body will manifest itself in bad cornering lines, and lost traction.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Go to a parking lot, and practice doing figure-eights using the lines to guide you. After a couple of minutes you'll start making them tighter, with more confidence. I ride 5K to 7K miles per year and I still do this sometimes. Even just a minute or two is helpful.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
break pretty hard going into the turn while you're still going straight, I mean you're doing a u turn so speed is not a concern/factor. Slow way down then turn and burn
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Get your body weight back and to the outside of the saddle. Slow earlier, let off the brakes, then hit the turn. Flatten the turn out as much as possible by going from outside, apex, outside. Pull your bike up level as soon as possible to begin pedaling.
Bundesminister
Commuting
27
01-07-15 08:59 AM
Banded Krait
Advocacy & Safety
5
08-18-13 10:30 PM
