1K+ Watt Hour Battery Kits?
It seems I'm most likely to get a pre-built electric bike but am curious about higher powered kits. I would be interested in a 1K or higher watt hour kit. Either mid drive or hub motor conversion.
I've done a cursory search but it seems like most kits are 750 watt hours or lower.
Quoted: 883 Post(s)
Liked 823 Times
Power is watts (amps X volts); battery capacity is a-h. The probable reason for the 750w limit in all OEM (AFAIK for Specialized, Trek, Haibike etc) is that's the maximum allowed for Class 1, 2, & 3 designation. My 1000w kit has a 30 amp controller, so with 52V battery is considered 1500+ watts (not considering efficiency). Electric motors normally are rated by the maximum power they can produce consistently, but most are capable of 2X - 4X that for short bursts. There are many kit motors and some bikes with much greater power than 750w.
I meant a battery with 1K+ watt hours. For example, a 52V/21Ah battery yields = 1,092 Watt Hours.
Or, a 52V/19 Ah battery yields = 988 Watt Hours.
I'm looking for a kit with a battery in that range or higher.
Quoted: 883 Post(s)
Liked 823 Times
Sorry, misunderstood. I've purchased two 52V batteries from Luna, and both have been excellent. em3ev as well as other companies will fabricate a custom battery.
