To cold-set or to just shove in..126mm->130mm
Which would you guys advise on? Ive spoken with few and was told that shoving it in would be more a temporary fix, and that a professional cold-set (through a framebuilder, not LBS) would be the most proper, which is fairly obvious. 126mm ----> 130mm Any problems with causing stress to the dropouts? Misalignment? Thank you for all responses.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
If it were mine, it'd depend a bit on the value of the frame. If it's super-rare and expensive, then by all means take out your wallet and bring it to a pro.
But 126mm to 130mm isn't massive (unlike 120mm to 130mm). Just to confirm, this is a steel frame? Cold-setting it yourself isn't difficult, lots of YouTube videos on how to do it. It'd certainly make it easier if you have to change the rear wheel, in the case of a flat tyre etc.
Quoted: 2026 Post(s)
Liked 1,096 Times
Cold setting and aligning the dropouts is the ideal way to do it if your frame is suitable, i.e. steel. If it's carbon or aluminum, you really can't cold set ii. Ti can be but it requires a real expert to do it right.
That said, just forcing a 130 mm hub into 126 mm dropouts is done all the time and isn't a big deal. The misalignment of the dropouts is very minor and generally harmless. Assuming typical 40cm chainstays, the angular change going from 126 to 130 mm is 0.5º.
Likes For oliver1850:
And, How did it go when you tried it ?
often a hub has spacers on the left end to thin a bit so rather than 130 it can be 128 , so only a 2mm spread rather than 4..
Quoted: 18378 Post(s)
Liked 4,512 Times
If you want a temporary solution (use a wheel set until you find something better), then just shove the wheel in and ride.
If you want a permanent solution, either build a 126mm wheelset, or coldset the frame.
One note, if you do cold-set the frame, I haven't done it yet, but lots of people strongly encourage clamping the brake bridge.
Quoted: 4208 Post(s)
Liked 3,874 Times
Never had a problem with brake or chainstay bridges coming loose when spreading a frame. But I have opted out a couple of times from doing this for various reasons so maybe I have avoided the worst potentials.
What is the frame made of? Steel is the only frame material to spread. Can you remove the BB yourself? I find that clamping the BB in a big bench vise makes for far better control of the bending then working freehand or on the floor. I would strongly suggest that the drop outs are realigned after spreading. While you're back there a hanger check isn't a bad idea.
A competent shop can do this easily enough but the qualifier is competent. This isn't what I would ask a LBS to do during their busy season. Certainly a frame person is a good choice too but if one's not local getting the frame/bike to them get's costly. No mention of locality (no surprise, most posters don't bother with this info) so no ability to offer where to go advice. If you're local to me this could be a pretty quick and low cost deal. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1104 Post(s)
Liked 1,825 Times
I spread my Crosscut frame (steel) a couple of years ago using a piece of threaded rod, some nuts, washers and a couple of wrenches. Took a couple tries to hit the mark, but has worked fine...no alignment issues.
Quoted: 605 Post(s)
Liked 480 Times
I watched a Youtube video of a guy who said you can use a 2x4 on it's edge levered against the seat tube to bend out one chainstay at a time If I were to think of all the ways to dent or bend a seat tube, THAT would have to be at or near the top of the list. But hey, it's OK, he put a towel under it
https://www.sheldonbrown.com/frame-spacing.html
Liked 1,825 Times
In fairness, it'd take a lot of aggressive and ham-fisted levering with a 2x4 to hurt an old steel frame. I've used this method (from Sheldon Brown) with no ill effects on an old steel Bianchi, it worked beautifully:
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Cold setting a frame is not difficult. Ensuring that the setting was equal on each side is the important part. If shopping for a bike shop to do the work, ask to see their alignment tool. If they don't have one, or say they do the "string" method, either find another shop or do it yourself.
Good luck.
Quoted: 1438 Post(s)
Liked 1,092 Times
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
Last year , I upgraded my old Ciocc frame (Columbus Alle) 7 speed to 10 speed, no issues. I first, tried putting the wheel (130mm) without cold setting, and it went right in, so no cold setting. I have 72 year old fingers with arthritis . Ridden hundreds of miles. Chainstay is 41cm. KB.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I was using 130 mm wheels on a 126 mm for the past few months, '91 Ochsner steel frame. The only problem I experienced was having to really tighten done the quick release skewers. I was using the friction setting on the down tube shifters and they worked fine with 8 speed cassette. Recently I found replacement dust cap and 6 speed freewheel for the original Mavic MA 2 rear and decided to go back to the original set up. I did all that work this morning, plus new gear cables and brake pads. Took It out for a 15 mile shake down ride and it is operating Great! STEEL IS REAL!
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I did not mention that with the 130 set up I had to manually spread the stays a bit to mount the wheel.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
My only experience is with a ti frame. 135 hub in a 130 OLD frame. Easy to install and remove. If spring ever gets here, will start fourth season with hub/frame combo.
Measure and/or just try it first. I checked a newly acquired '86 Centurion Ironman (thinking of upgrades of course) and found it to be 127.5 !
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
As noted, it is safe to clamp the brake bridge - no downside to clamping, but really should not be required. If the brake bridge did let go, it was like to let go soon even if you didn't spread.
After spreading, check the fame alignment with string method (see Sheldon for technique); re-align the drop outs (us micrometer and small square to measure gap and front and rear of drop out, use medium-large crescent wrench to bend (align) and finally re-align derailleur hanger.
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
Apparently Campagnolo made 126mm 'cassette' hubs which were compatible with any 8 speed Campagnolo cassettes. This is perfect as I dont mind going above 8 speed, just need to get the gear ratio of my liking. Id rather not do anything 'detrimental' in any way as this is a pretty rare frame..
Quoted: 569 Post(s)
Liked 583 Times
A few points for a "pretty rare frame":
1) I have a son-in-law who would do a nice job and a son-in-law that knows it would be unwise for him to try this alone, he is just not mechanically inclined
2) Is the frame straight now? Can you ride around the block hands free? If so, the string test should work well. If not take to to a frame builder.
3) reducing the NDS by 2 or 4mm and I would want to re-dish the rear wheel so the track is not offset by a mm or 2. Works well on my Vitus 979 (aluminum frame).
4) In the unlikely event the steel is Reynolds 753 caution is needed. I rescued a very nice custom Reynolds 753 frame which had a bent fork and frame. I tried straightening the offending blade and as soon as I mounted the bike the blade would snap back. The internet and Reynolds engineering docs will tell you 753 can't be cold set. Took to a frame builder with many years behind him who knew better. Applying his Marchetti frame alignment table and massive fork table it is now a beautiful ride, however the string test is 1.5mm off which I can not explain.
I have not seen a 126mm Campy hub that would take an 8 speed, would love to see more info. I do have a Japanese frame running Sheldon's "8 of 9 on 7 trick" on a 126 frame.
Also I have read there is a trick to using 8-9 speed Ergo shifters with 7 speed freewheel. Is this true and straight forward? Or will it require a combination of parts? (Ex. Campagnolo 8-9 speed brifters, shimano rear derailleur etc.)
Quoted: 569 Post(s)
Liked 583 Times
Shimergo
I ran a mix successfully for a time years ago, still using a shiftmate on one bike, after reading this site:https://www.cyclinguk.org/cyclists-l...gears/shimergo. There has been more work on shift ratios, sprocket pitch, RDs, etc., if you google shimergo.
