Ideal Front Travel for Trail Bike
Quoted: 5 Post(s)
Hey!
I just bought the new GT Sensor and I'm excited to get it built up. After doing some reading online, it looks like a lot of people are swapping the front fork for a 140mm travel (comes with 130mm). What are the benefits of that additional 10mm when it comes to trail riding?
Thank you,
Ryan
Thank you,
Ryan
Quoted: 2975 Post(s)
Liked 1,181 Times
A little more cush for drops and jumps.
Raises the bottom bracket up a little higher.
Rakes out the front end a little more for downhill.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Hey!
Thank you,
Ryan
Thank you,
Ryan
If you want to slacken the front end there are other ways to do that.
Otherwise, 10mm is a pretty small difference performance-wise. Other differences (spring curve, damper design, rigidity) are going to make a bigger difference than 10mm travel.
Many times you do not need to change the fork, just the tokens or cartridge.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I'm with Leebo, tune what you have unless you hit its limits and need something more. The best reasons to get a bigger fork are bigger need for suspension and more stiffness. 120-130 is sort of a middle ground... a bit short for a trail fork but long for an XC fork. You could also see if your fork can be converted by getting a longer shaft or removing spacers.
Genesis 49:16-17
Genesis 49:16-17
