Crankset for 2018 SuperX
Because this frame uses Cannondale's "Asymmetric Integration," and a wider 86 mm bottom bracket shell, does anyone know whether any crankset beyond the Cannondale Hollowgram or Si crankset will fit (or can be made to fit) on the SuperX? I am considering purchasing a 2018 SuperX frame but not if the only crankset it will accept is the Cannondale models.
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
I think this pretty much covers it: https://weightweenies.starbike.com/f...c.php?t=147045
Liked 692 Times
Thanks I have reviewed that string from weight weenies and I still don't understand what it means. That thread seemed to deal with fitting and crank plus power meter on a SuperX and I'm not sure it answers the question about that other types of cranksets are compatible with Asymmetric Integration.
2019 Salsa Warbird
2019 Salsa Warbird
OK that is helpful. The longer spindle in the 125mm spindle sold by Cannondale. One of my questions is whether that spindle is compatible with a SRAM crank. However, because is pictured is a 1x setup, it does not need the 125mm spindle, so I can't be sure that the spindle on this particular set up is a Cannondale spindle. I have asked Cannondale and they don't know whether there spindles fit on the SRAM crank. No one seems to have the answer to this question.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Thanks. What is the Paceline forum? Is it cyclocross/gravel bike specific or would they have any specific expertise in this area. I've already tried Bike Mechanics here and their recommendation was to buy a different frame I will not give up that easily.
Liked 692 Times
https://forums.thepaceline.net/index.php
Post your question in the General subforum.
2019 Salsa Warbird
2019 Salsa Warbird
What did you end up doing? I'm dealing with a 2019 SuperX that came used with a SRAM Red crankset on which I'm trying to add a power meter to.
2019 SuperX Crank Fit
I am currently building up a 2019 SuperX with the Easton EC90 crank, 50-34. I think going the way of the longer mtb spindle and spacers may be the answer.
Similar to what I was thinking. Or the cheaper EA90 alu crank arms, with the right-length RaceFace spindle, and spacers.
