How to set up a flat mount rotor for 160mm from 140mm
Quoted: 800 Post(s)
Liked 512 Times
I have a Shimano flat mount disc brake on my front wheel/fork. Currently the setup is for a 140mm rotor and I want to switch it for 160mm.
Question. I know I need to flip the flat mount over, so the 160mm arrow marked on the flat mount is pointing up. What I don't know is, how does the caliper and the flat mount come apart. Or do they even need to come apart?
For example, do I separate the flat mount from the caliper, turn the flat mount upside down so the 160mm marking is pointing up , re-attach the flat mount to the caliper, and then re-attach the whole thing to the fork?
Or does the whole unit get switched upside down? This makes no sense to me though, as there will be cable issues.
I did some web searching but couldn't find any tutorials on what to do, and my Zinn maintenance book doesn't talk about either.
Thank you.
Thank you.
Quoted: 184 Post(s)
Liked 67 Times
Arrows point to direction that the rotor rotates when you're riding the bike.
https://www.bike-discount.de/en/buy/...adapter-732856
Flip the adapter around, not the adapter and caliper.
Quoted: 630 Post(s)
Liked 369 Times
Unscrew the 2 bolts holding the caliper/adapter to the fork. Take the adapter and rotate it 180 degrees. Reinstall and torque to spec
Quoted: 800 Post(s)
Liked 512 Times
Successfully installed the 160mm rotor on my bike tonight. Thanks for all of the help/guidance.
