School me on tooth difference in performance
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Just replaced a triple ring 28/38/48 with a triple 22/32/42.... Haven't put my bike through the paces yet. What can I expect and why? Make the explanation as semi-technical as you like... I enjoy learning new things, especially on my bike!
Expired Member
Quoted: 3665 Post(s)
Liked 5,412 Times
Your bike will be easier to pedal.
Bikes: Specialized Roubaix Exp ert Road and Specialized Stump Jumper FS Mountain; De Vinci Caribou touring, Intense Tracer T275c, Cramerotti, Specialized Allez, Condor
Quoted: 166 Post(s)
Liked 99 Times
☝️ I agree!
Every time you pedal a circle you move the bike ‘X’ teeth. So with your new gearing you will move the bike fewer ‘teeth’ than with your former chain ring. Now, of course, that also depends on your cassette, but since you don’t say you have changed that it should be irrelevant.
If the gear on you are using on your cassette has 24 teeth then with every cycle the old chain ring (large gear) would rotate the tires 48/24 or 2Xs. The new one will rotate the tires 42/24 or 1.75Xs. Less distance equals less effort.
Quoted: 741 Post(s)
Liked 818 Times
It will easier to pedal up hills, but on flat roads you will go slower with similar effort.
Quoted: 3375 Post(s)
Liked 5,513 Times
Lemme get this straight:
The OP substituted smaller chainrings, having no idea what difference will be?
Likes For Digger Goreman:
If the gear ratios you mostly find yourself using are within the overlap between your old and new crankset, you won’t notice any difference.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
You'll have easier gearing for going up hills in the small chainring, but assuming the same rear cassette (gearing), you will have to spin very quickly to make the bike go the same speed in the big chainring.
I enjoy numbers, and there are a few gear calculators that can give you additional data using chainring and cassette sizes. First, this one (https://www.bikecalc.com) gives you a bunch of information, including the useful speed at cadence, or how fast the bike will go given the RPM of your pedaling. Green combinations are faster/harder to pedal; red combinations are slower/easier to pedal.
There's also the Sheldon Brown gear calculator (https://www.sheldonbrown.com/gear-calc.html) which provides the very interesting meters of development - how far your bike will travel forward with each rotation of the pedals. You can do some math and, for example, calculate how many times you'll need to turn the pedals per mile in each gear. This is probably useful only if you're on long solo rides and need something to focus on while passing the time.
Quoted: 18373 Post(s)
Liked 4,507 Times
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Your lowest gear combination will be easier to pedal than before. Your highest gear combination will be easier to pedal than before. Why? Because, you changed your gearing .
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
Likes For mstateglfr:
Quoted: 18410 Post(s)
Liked 15,530 Times
Quoted: 1572 Post(s)
Liked 643 Times
If you had difficulty climbing up some of the hills in your area with your previous crankset, you are going to have less difficulty climbing up the hills with your new one.
If you found yourself running out of gears and freewheeling on the downhills previously, you are going to run out of gears and find yourself freewheeling even sooner with your new crankset.
Quoted: 2494 Post(s)
Liked 738 Times
Is the o.p.'s chain slightly too long now? Seems like it should need a link out. At least the chain should have been thought about. Ignorance is not always bliss.
Liked 15,530 Times
Quoted: 331 Post(s)
Liked 415 Times
Maybe no performance difference at all, particularly if you ride mostly flat roads.
Quoted: 331 Post(s)
Liked 415 Times
Quoted: 1856 Post(s)
Liked 664 Times
