Sugino zen vs FSA pro track chainring
You probably won't notice a difference.
If you do a ratio of difference in price/ difference in cost, you will see the FSA ring is where it's at.
Your cog is slipping.
FSA rings are a great value and very stiff - but I've noticed on the ones I've used that the teeth get dimpled by the chain fairly easily, which doesn't happen to my Sugino rings.
Bikes: Pegueot UO8, Tommaso Augusta
Also, what is the difference between these two Zen rings? Is it just the branding mark or is one a better make?
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
More Jakarta points. Go with the English branding for bonus SJ points.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
I own and race both brands. The only difference that I can see is that the Zen are lighter and have a better finish, which explains why they cost more.
The Zen are lighter because the backs are milled-out to remove material:
The FSA are not. This is the reverse:
Both the front and reverse have "FSA" printed on it, but the reverse uses a smaller font.
Front:
Solid rings are prefered over standard cut-out rings because the cut-out rings warp under heavy sprinters. If you aren't going to warp one, just use the standard Sugino 75 type rings, which are lighter and cheaper than the Zen:
The FSA are the best bang for the buck in terms of solid race gear. They are even cheaper and stronger. But, not as light as the others.
Front:
Elitist
Liked 92 Times
This is race-spec equipment, all of which will perform the same for non-race use. So, with that being said, pick the one that you like the most.
